Hello, i need better understand how to set dual WAN the correct way
Currently i have most basic setup - pppoe in port 1 made by quick set, router mode + i added 4 wireguards (and firewall rules). ISP1 provide static public IPv4 + static IPv6 /56, speed 120/25Mb. Everything work fine.
Because ISP1 cannot provide more speed i bought 5G 250/25Mb as second connection. ISP2 provide CGNAT + single dynamic /64 (routerOS lack ND-proxy IPv6 is out of question)
Main reason for this is offset heavy usage streaming videos on TVs (UHD in 60fps) and phones.
What i tried:
1) Client IP load balancing - Based on this video: https://www.youtube.com/watch?v=oRu03tdOrak a manage it to work (video is based on ROS6) but all wireaguards and LAN was not accessible (Winbox was accessible only by MAC address), later i managed to LAN work but Wireguard was never resolved, also IPv6 was assuming control sometimes so i have ISP2 IPv4 but ISP1 IPv6, it was not reliable to work with so it was scratched
2) PCC - Based on this video https://www.youtube.com/watch?v=nlb7XAv57tw it was half working solution but some pages started behave strange (they were load, then blind to later been loaded again), it had also problems with banking apps on phones so i scratch that too
3) EOIP - I tried EOIP two routers but i cannot make it work but based on forums it is promising to interconnect networks
4) Two LANs, Two Bridges - basically one physical router behaving as two virtual. Before i start i need to ask if this is even good idea.
I basically want - port 1 as WAN1, port 2-4 bridge1 ,, port 5 as WAN2, port 6-8 Bridge2 then i physically will switch cables, not desired but i can utilise power of one device and later try EOIP the two bridges. It is even reasonable or it will have unforeseen consequences?
Current setup until i resolve this
ISP1 -- Modem (bridge mode) > RB5009 > devices as PC, NAS, Consoles (preventing NAT problems), Main access point
ISP2 -- ODU (5G modem) > Hex S > Switch > devices as secondary access point, TVs, phones
Both routers are interconnect with wireguard
What is desired - Use one physical infrastructure but move heavy traffic to ISP2
That will be the best solution but other reliable solutions will be also welcomed.
