pwac092
Bringing my own router to work - idea validation
Sun Apr 28, 2024 10:57 pm
Hello!
I trying to validate an idea.
I want to have some protection while at work. Protection here is primarily minimising the chances of it people to look at my data. Naturally, my computer (I bring my own to work) is forcing https on all sites and I tunnel my traffic via WireGuard to my home or protonVPN.
In any case, I was thinking it could be a nice idea to have my own ap in the network. I was thinking just plugging it in on an available Ethernet port, register the mac with the it guys for it to get an ip address and presto.
I was thinking using some hap variant, bridging all Ethernet’s and allowing wan to get ip via dhcp. This is pretty standard out of the box config.
I was also thinking to have two wireless interfaces. One would send traffic via wire guard to my home and the other through protonvpn and the other directly through the local network at work.
Does this make sense or am I being an idiot?
Cheers
anav
Re: Bringing my own router to work - idea validation
Sun Apr 28, 2024 11:54 pm
First thing to do is check with the department or persons responsible for both IT and security to ensure that its within the rules of the company.
pwac092
Mon Apr 29, 2024 12:14 am
Yes of course. That goes without saying.
I am just thinking in terms of “does it make sense”
fragtion
Mon Apr 29, 2024 3:30 am
Yes, why not?
Sounds like you know what you're doing, so you should be able to decide whether it's going to be worthwhile for yourself
Amm0
Mon Apr 29, 2024 5:09 am
Well is the office Wi-Fi crappy? Then it make sense.
If your need is "security", I guess an extra router add additional layer beyond whatever your laptop's default firewall is doing. Just seems like marginal benefit, since I suspect you may also use your laptop on other WI-Fi networks too - so likely best to focus on laptop's security IMO.
And...adding a router on top of existing LAN is going to create a double-NAT... For regular web things, this is not an issue. But since your using WG on your laptop to home, you're home need to have public IP.
pimmie
Sat May 04, 2024 4:35 pm
There was a similar post some time ago and that op posted more details: viewtopic.php?p=1068656#p1068656
Ignoring the exact use-case, I have used a mAp lite myself when traveling to 'bridge' hotel wifi networks for my laptop and/or phone. I guess that's similar as what you are planning to do.
Users browsing this forum: Demidrol, john533, Majestic-12 [Bot], PrimeYeti, tryrtryrtryrt and 50 guests
