Jotne
IOT MQTT shows the password on export
Wed May 01, 2024 8:23 am
When having IOT package on your router and export the config, you will see the MQTT password.
That should be only shown when doing an export show-sensitive
So MT please fix.
msatter
Re: IOT MQTT shows the password on export
Wed May 01, 2024 9:52 am
Did made also a ticket with support or did you just put it up here? ;-)
Jotne
Wed May 01, 2024 7:18 pm
SUP-151732
Jotne
Wed May 15, 2024 11:13 pm
It will be fixed :)
Our bug tracker reports, that your issue has been fixed. This means that in the upcoming days, we plan to release a RouterOS update with this fix.
Users browsing this forum: BartoszP, Bing [Bot], karid, Valerio5000 and 47 guests
