Hi everyone, i´m new in the forum.
I have a mikrotic RB1100AHx4 and the thing is that I´ve been trying to deny all traffic between vlans but it´s been impossible.
I´ve been doing the following steps (In the GUI):
1. Identify VLANs
2. Navigate to Firewall Rules: In the Winbox GUI, go to IP -> Firewall.
3. Add New Rule: Click on the "Filter Rules" tab and then click the "+" button to add a new firewall rule.
4. Configure Rule: In the new rule window, I've configure the conditions under which traffic should be blocked.
5. Set the Chain to forward.
6. Define the source and destination addresses, ports, and protocols for the traffic I wanted to block.
7. Set the Action to Drop to block the traffic.
8. Apply the Rule
9. Move the rule up the list to give it more priority.
10.Test: Ping between vlans ips (But they never stopped reaching out to each other)
(I´ve some rules created that allows conection VPN and two others that allow traffic from the vlans to the wan and from the wan to the vlans. (I don't know if this can affect the rules I'm trying to create but just in case I'm clarifying)
The Switch i´m using has a Realtek RTL8367 chip, i don´t know if this has anything to do with it but just in case I'll clarify it too)
I would really appreciate if anyone can give me any ideas on what to do.
Thanks.
