haggis
CPU OID data not showing
Wed Oct 08, 2008 3:57 am
I have an odd issue, i have set up all our servers to show CPU, HDD and RAM information by adding the appropriate OID information in the label window of the appearance properties. This is working very well, except that the 2 servers that we have that are single processor CPUs, they show the OID ie:'CPU: [(oid("1.3.6.1.2.1.25.3.3.1.2.1")]' and not the value they are supposed to call.
Also we have a UPS that is doing this for all values, it will enable me to do an SNMP walk, but it wont show the actual values associated with OID.
adamd292
Re: CPU OID data not showing
Wed Oct 08, 2008 4:13 am
If you look at how Dude calculates the CPU:
In Functions, look at cpu_usage:
It is defined as:
average(
oid_column("iso.org.dod.internet.mgmt.mib-2.host.hrDevice.hrProcessorTable.hrProcessorEntry.hrProcessorLoad")
Which means:
1) Get all of the values that start with "iso.org.dod.internet.mgmt.mib2.host.hrDevice.hrProcessorTable.hrProcessorEntry.hrProcessorLoad" (this is the oid_column function)
2) Take the average value (so works no matter how many cpus you have)
It would be nice if the functions were documented in "The Dude" manual. You can puzzle things out based on what has been posted to the probes thread on this forum.
haggis
Wed Oct 08, 2008 4:32 am
Actually i did it a slightly different way, i simple specified each different CPU oid and added them together and divided by the number of CPUs e.g: [(oid("1.3.6.1.2.1.25.3.3.1.2.7")+oid("1.3.6.1.2.1.25.3.3.1.2.8"))/2]%. This works nicely, but as i said for some reason if i have only 1 CPU on a server, hence only one CPU OID to display.
I entered the average statement that you suggested and it works, thanks!
Any suggestions as to why i am not seeing OID values on my UPS? What is the syntax to use this format (oid_column("iso.org.dod.internet.mgmt.mib-2.host.hrDevice.hrProcessorTable.hrProcessorEntry)] for viewing something that is not an average, instead of this [(oid("1.3.6.1.2.1.25.3.3.1.2.3))] in the appearance windows?
I am trying to see the time remaining and %battery capacity.
lebowski
Wed Oct 15, 2008 1:58 am
The apc ups probes I built are in the probe thread... I highly recommend reading the whole tread.
http://forum.mikrotik.com/viewtopic.php?f=8&t=12402&p=127893&hilit=apc#p127893
OH do you have the correct SNMP strings?
GL
SD
haggis
Wed Oct 15, 2008 2:19 am
I managed to find the issue though i do not understand why it needs to be done. Instead of having the whol eOID as numbers it wanted a combination of both and now works perfectly e.g:
[oid("iso.org.dod.internet.private.enterprises.318.1.1.1.2.2.1.0")]%
lebowski
Wed Oct 15, 2008 3:21 am
There are a lot of quirks in "The Dude" I hope they keep fixing them !
Users browsing this forum: No registered users and 5 guests
