is the following situation possible with RouterOS?
I have two pppoe connections: pppoe-out1 and pppoe-out2
They have the public IPs 80.1.1.1 and 80.1.1.2
Also the ISP routes two subnets to those IPs: 1.1.1.0/24 and 2.2.2.0/24
Now given that the ISP will also prevent IP spoofing so that traffic from and to 1.1.1.0/24 can only pass through pppoe-out1...
Will this still work?
I'm not too experienced with IP routing but I suspect as both pppoe-interfaces will add a default gateway rule the traffic might take the wrong interface on it's way back.
Best regards
Max
