Tue Sep 14, 2010 4:40 am
Got it...
Sprint 250U on RB433...
1) Create the ppp-client settings.
2) Enable the ppp-client (Yes it will apear hung)
3) LEAVE THE MODEM ALONE.
4) Reboot the Router. (Soft seems to be fine)
Upon reboot the modem will connect....
OK I just scored a 8 of 10 on the weirdometer....
DONT open a terminal from winbox and "print" the PPP-Client information.
The modem will disconnect and lockup into an "initializing modem" state...
I found out the hard way...
Settings:
0 name="ppp-out1" max-mtu=1500 max-mru=1500 mrru=disabled port=usb2
data-channel=0 info-channel=1 pin="" user="" password="" profile=default
phone="#777" dial-command="ATDT" modem-init="" null-modem=no
dial-on-demand=no add-default-route=yes use-peer-dns=yes
keepalive-timeout=30 allow=pap,chap,mschap1,mschap2
I dont have clear docs on the Ant ports yet, but the port nearrest the "Sprrint logo side (With the LEDs of the "puck" is the 3G and the one at the rear is the 4G.. I am waitng for a Sprint Eng to verify it for me..
