Jotne
Re: Feature requests
Tue Sep 27, 2022 6:46 pm
I would like to have a possibility to create a crc hash for local file. This way I can make a backup file every day. If the file today is has a different hash than yesterday, I know some has changed and then send the file to external server.
pe1chl
Tue Sep 27, 2022 7:07 pm
It would have to be more intelligent than a simple hash, because the backup includes a stamp of the date/time it was made, so each time the hash would be different.
(unless the hash function would be smart enough to skip that timestamp)
Znevna
Tue Sep 27, 2022 7:22 pm
Weird, they look the same here.
PS D:\Temp> Get-FileHash .\GW-R4-20220927-1916.backup
Algorithm       Hash        Path
SHA256          9732B4DD495D13E49B875D3C2862F5AC606DAE6349C1A1AE6A0128542F1D99D0       D:\Temp\GW-R4-20220927-1916.backup
PS D:\Temp> Get-FileHash .\GW-R4-20220927-1917.backup
Algorithm       Hash        Path
SHA256          9732B4DD495D13E49B875D3C2862F5AC606DAE6349C1A1AE6A0128542F1D99D0       D:\Temp\GW-R4-20220927-1917.backup
pe1chl
Tue Sep 27, 2022 7:27 pm
Ok you mean a .backup file... I never use that because it is impossible to restore it on a new device when the old one breaks.
I use .rsc files and they do include a timestamp.
Jotne
Tue Sep 27, 2022 11:42 pm
@Znevna You are 100% that some config has changed, not just the file name?
Znevna
Tue Sep 27, 2022 11:46 pm
I was just proving that backup files don't contain a timestamp inside.
But pe1chl was referring to rsc files, and not to the backup files that you were talking about.
Try to keep up.
eworm
Wed Sep 28, 2022 11:05 am
I would like to see the functionality to create checksums as well. But please do not limit this to file, but support it via parameter:
:put [ :sha256 input="foo bar" ];
:put [ :sha256 input=[ /file/get content your-file name ] ];
That way you can also strip the timestamp from export files to check for differences. 😉
pe1chl
Wed Sep 28, 2022 11:25 am
There is a separate topic about suggesting new features for the scripting language: viewtopic.php?p=913066
Maybe this fits better in there...
However, it was started in 2018 by mrz but it does not look like any of the useful suggestions made in there has ever been implemented...
One problem with the scripting language is the fixed 4096 byte limit on string values, even within expressions, which means that a file larger than 4K cannot be processed this way. It would have to be processed in a "open/read records in a loop/close" fashion, but the scripting language does not support that.
akakua
Wed Sep 28, 2022 12:38 pm
Create dynamic vlan entry with added tagged bridge to it in "interface/bridge/vlan/" when i set interface vlan on bridge with vlan filtering enabled, like you alredy doing it with pvid.
MikeTkatchouk
Fri Sep 30, 2022 7:30 am
A very simple element will help make it easier to put things in order in the winbox window. Attached design example.
Keljian
Mon Oct 03, 2022 1:50 am
Would love to see some of the CAKE functions offloaded to the packet filtering engines on various low/medium range devices.
arnaudf92
Mon Oct 03, 2022 12:28 pm
Dear Mikrotik,
Is it possible to fix the vlan priority tagging issue concerning firewall or bridge rules ?
Pls see this forum topic : viewtopic.php?t=189628
Regards.
colin
Tue Oct 18, 2022 8:26 pm
Add Support for "Virtual Interfaces"
-MACVLAN
-IPVLAN
More info
https://developers.redhat.com/blog/2018 ... networking
+1
pe1chl
Fri Oct 21, 2022 5:14 pm
Please implement PPPoE hardware offloading on devices with chip that supports it.
PPPoE data packet processing should not load a CPU core.
ahmedramze
Wed Dec 21, 2022 11:02 pm
Hi
Can add comment on view list of columns ? its easy to view/edit/sort by comment some time need it specially in ip firewall address list
rextended
Thu Dec 22, 2022 12:51 am
Hi
It already exists
Don't you read what appears in front of you?
Instead of clicking "Show Columns..." it's just the top row option... "Inline comments"
May the peace be upon you.
ahmedramze
Thu Dec 22, 2022 12:57 am
ah done I think I need to renew my mikrotik certificate very old
Reason: removed excessive quotting of preceding post; be wise, quote smart.
p3rad0x
Long time Member
Long time Member
Thu Dec 22, 2022 11:34 am
Not sure if this is supported or I am being an idiot.
Handing out /32 dhcp leases using radius and unnumbered interfaces.
currently using dhcp lease script to add the correct address and network in the address table of the dhcp server
ajgnet
Thu Dec 22, 2022 7:35 pm
Would love the ability to specify a DoH server but also FWD entries to specific DNS servers. Currently, enabling DoH disables all FWD entries.
eworm
Thu Dec 22, 2022 10:39 pm
Me too... But all comments here in forum are ignored by Mikrotik. 😢
pe1chl
Thu Dec 22, 2022 10:59 pm
The DNS resolver is a joke... just see how many new bugs there are in every v7 beta/rc release.
The fact that a DoH server should just have been another server in addition to the plain servers (keeping the same functionality for the static entries) is just the most obvious problem.
Amm0
Fri Dec 23, 2022 12:35 pm
I just wish there was some clarity when folks should use the "Feature Request" in the new-ish help.mikrotik.com. I'd like to think some the items here and above link are at least being tracked by them – but hard to know.
Just for example, should everyone who needs JSON support, file a feature request in Jira / help.mikrotik.com? That seems a bit silly. At the same time, it be good to know an item is "on the list" with some ACK in forum to some of the reoccuring themes.
spippan
Wed Dec 28, 2022 5:53 pm
+1
oeyre
Mon Jan 02, 2023 10:04 pm
Are there plans to add support for additional LACP hashing algos? encap2+3 and encap3+4 would be greatly appreciated
Rpopas
Wed Jan 04, 2023 12:21 pm
Happy new year everyone and great Mikrotik Tip shared today:
https://www.youtube.com/watch?v=BbDnBxlBTdY
Feature Request:
Possibility to disable the anti-replay protection
Description:
This feature request is probably very specific, however don't think it would be hard to implement, at the moment the replay value seems to be always ON and hard-coded to 128B:
/ip ipsec installed-sa> print
Flags: H - hw-aead, A - AH, E - ESP
0 HE spi=0x70426F0 src-address=162.159.65.18:4500 dst-address=192.168.1.100:4500 state=mature auth-algorithm=sha256 enc-algorithm=aes-cbc enc-key-size=256 auth-key="<REDACTED>" enc-key="<REDACTED>"
add-lifetime=24m19s/30m24s replay=128
This anti-replay protection it's actually a problem when trying to use the Mikrotik IPsec with anycast networks like Cloudflare:
https://developers.cloudflare.com/magic ... rotection/
Many devices allow disabling the anti-replay protection but i wasn't able to find a way to do it on Mikrotik, which is why i mentioned above it's hard-coded, if there is one way to do this please let me know.
While i'm not able to make the IPsec work, the alternative will be to set up GRE tunnels, which due to the lack of encryption not everyone is willing to use.
sirpkc
Fri Jan 20, 2023 5:31 pm
Feature request is to move the "Disable" button away from other common actions such as "Comment" or to add a "Confirm" dialogue. Too easy to disable an interface accidentally by being a few pixels off target when you are trying to click on "Apply" or "Comment".
volkirik
Multiple Feature requests and a bug report
Mon Jan 23, 2023 6:16 pm
[feature request]
pppoe-relay
and broadcast-relay
could be extra package possibly bundled with other relay daemons
[feature request]
ipsec alg (helper)
[feature request] dhcpv6 server - address (/128) distribution
[feature request] dhcpv6 client: ability to change DUID manually
would be useful if you have lots of links from same provider.
[feature request]
configurable looking glass package for ROSv7
[feature request]
Please add routing-table support for ping and traceroute
[feature request]
Please add clear-DF and strip-IPV6-options actions for IPv6 firewall (mangle)
[bug report]
4 uplink with 4 VRF
each had add default route feature with distance:10
VRF confuses and one pppoe interface has TX drops and shows RX bytes/bps: 0
thanks for reading hope it can be fixed.
changing default route distances fixes the problem temporarily. i guess VRF conflicts with ECMP. fyi.
[feature request]
please add wireless DTIM and beacon interval setting.
[feature request]
please add TCP_RTO_MIN, TCP_RTO_MAX and the tcp_retries2 settings
[feature request]
Please add target and destination to queue tree rules
Please add 'any' packet mark matcher to queue tree.
[feature request]
Please add;
expired DNS cache size
and
expired DNS cache TTL
and fallback to expired storage when resolver is unable to resolve something.
something like recycle bin
[feature request]
regarding wireless ANI feature; add one another choice line below: REQUIRED or just ENABLED.
thanks for reading and considering, regards
spippan
Wed Jan 25, 2023 2:35 pm
[feature request]
WinBox Keyboard hotkey navigation
to be activated for example pressing [ALT] twice
then the menu items could, for example, be iterated through a-z and on submenus (like MPLS, etc.) the iterations could move over to the submenu
so navigation could be much faster, hence one can navigate with the keyboard anyways for adding entries ( [INS] key) or de/activating items ( [STRG]+[D] / + [E] )
imager
Tue Feb 14, 2023 8:13 pm
Add to Winbox a menu section with commands for automatic arranging multiple windows (cascade, side by side, in a stack) !
imager
Tue Feb 14, 2023 8:18 pm
I suggest in Winbox program implement the ability to display two additional columns in the window of the "IP - Firewall - Connection" section: the first should display the number # of the rule line from the "Filter Rules" section, which allowed packets to pass, and the second column should display that " comment" which is recorded for the corresponding rule with line number # from the "Filter Rules" section. This functionality will make it possible to significantly simplify the process of debugging firewall rules, i.e. it will become similar to modern Next-generation firewalls.
Amm0
Tue Feb 14, 2023 8:21 pm
Wow. That's a good one! +1 for #HotLockWinbox
pe1chl
Tue Feb 14, 2023 10:38 pm
You can already do some of that yourself! In the firewall you can apply connection marks and you can see them in the connections window.
Also, in the firewall you can enable "log" (+ optional tag) and see the matching packets in your log window.
benel
Thu Feb 16, 2023 12:05 pm
[feature request]
Hi all,
On my Tik I am using few VLAN's, multi Wireless networks and about 10 DHCP servers due to a need of splitting the connection to different sectors that should not communicate one to the others.
I also need a way of seeing in one place all the connected devices for all the network's , and the best way of seeing this closer to my need is similar to Quick Set - WISP AP - Local Clients (but the Quick set is intended for other purposes, and not for "viewing things, or so).
I would like to see something similar on the main menu, maybe on the Interface menu would be a good place for this; to create a tab about "Connected devices", or maybe a dedicated place on the main menu for this would do the trick.
I would like to see over here:
- All the local clients listed (IPv4 and IPv6)
- The type of the client connection (wifi / ethernet)
- The total number of clients connected via Wifi / Ethernet - if possible listed also by each network (VLAN / VPN / each Wifi network), e.g 2 clients VLAN 22, 3 clients Wireguard, 22 clients VLAN 33, 1 client IPSec
- The MAC of the device
- The IP of the device
- The VLAN, VPN (Wireguard, IPSec or whatever) and the DHCP server used
- The comment of the DHCP Lease for the static IP's (i am using this for naming the clients in case of the client does not have a defined name - some IoT and not only IoT devices does not have a device name on the network provided by the device itself for the identification)
- For the Wifi devices - the signal straight and the 2.4 / 5 GHz, whatever connection it uses
- The up-time
- The current up/download speed, the average rate, the Bytes and the packages, the top up/download speed on the last hour / day / week / month
- The Brigde used for the client
- The Interface used for the client
It would be also nice to be able on this screen to enable/disable the view of the entire DHCP leases that uses a static IP that are not connected at the current moment and to see the last connection time..
Amm0
Thu Feb 16, 2023 12:43 pm
You do some of this in webfig with the Status page. Any of the controls in webfig, from any page, can be add as an element on a Status page. See https://wiki.mikrotik.com/wiki/Manual:W ... tatus_page
benel
Thu Feb 16, 2023 3:24 pm
When you start the phrase like "You do some of this into other whatever" you troll me.
My request was:
1. for Winbox
2. more complex than what the Webfig offer's on that cripy interface for your own puzzle that puzzled you from the start
If you cannot add value, or, if you do not understand the request, please keep your words for yourself.
pe1chl
Thu Feb 16, 2023 3:43 pm
You did not mention that your request was for Winbox! How can anyone know that?
Of course it is possible to do what you want using an external program and scripting and/or API calls.
Maybe a useful feature request for Winbox would be to have some capability for user-defined menu entry that opens a form (or even a generic terminal window) that can be populated using a script.
I have seen uses for that as well. And it would be more generic than to have them implement exactly what you need in that much detail.
benel
Thu Feb 16, 2023 4:08 pm
Sorry, my bad, i had lost some text and missed that; the request was for Winbox indeed, even if it is not mentioned :(.
It would be a huge effort to make the Winbox able to be manage a sort of lego screen composed with whatever you like as columns from the entire RouterOS available screen's, i do not think that this is a bad idea; but the first thing to do is a "Status page" that may be used to see all the connected devices from all the network's in one page. I have just made a list of what i consider, but the software architect and the Mikrotik team will be the ones that will decide if this is manageable, if this is required and what should contain. My feature request and my list is just a start for whatever may be, if it may be anything on this side.
The first step is to have something like this build in into Winbox from the start; API's, script's, lego and puzzle's may be developed afterwards.
Not to have something so basic into Winbox is worse than having something that does not satisfy all the client's. Scrip't and API's are not for the basic users of Tik's (e.g. soho users)but i agree that are a good ideea; but, let's nail them one by one.
In fact, they got all they need to do this, is that screen from the Quick Set that may be improved a little bit and placed as independend window or a tab, is not so difficult i assume.
pe1chl
Thu Feb 16, 2023 4:41 pm
Well, I hope that (but I have never researched that) winbox, webfig and command operate using some form of table that defines how a dialog is presented (layout) and what data it shows.
I.e. that this is not in code, but it is data-driven. The capability should already be there, it just isn't exposed to the user.
Similarly I would like to have the possibility to add an extra field in a form, especially on the Status tab of some items, where it can show the output of a user script.
I have worked with a Windows application that has that capability, and it is very convenient to have that. It also reduces the number of feature requests a supplier has to implement, because users can resolve some of them on their own without bothering the supplier.
benel
Thu Feb 16, 2023 11:57 pm
Not any controls, and by the way, the Design is extremely buggy, slow, crashes with Firefox and even with Chrome, log's you out random sometimes. I never manage to add more than few things (basic). You were never able to add the mentioned list and status of the Local client's (the one that i was referring to). To be honest...could that feature be ever used by the users that want a Status of the clients, interfaces, VPN connections, signal and other real time data; or is it only for static fields data meant to be usable ? No, to honest, not even if I try (i have just tried now to do my setup on Webfig), I could not get what I need from that functionality, because you simply cannot.
Amm0
Fri Feb 17, 2023 1:28 am
I'm not the target. Especially as someone who design configs so they don't break "QuickSet as a status page" & too familiar with limitations of the webfig. All I was saying it's not like they are starting 0% on a "status page" & more trying to be helpful to readers here who may not even know the webfig status page part existed – it is useful, but could be better for sure.
<rant>
But I'll be honest it's the talk of "Multiplatform Client" I fear (in "WinBox for MacOS" from @Normis (in 2021)):
We do have plans for true multi platform Winbox. Finally. Let this be a teaser for 2022 :) No ETA and no promises though.
I even use a Mac, and I want winbox fixed up rather than some new client... Maybe with 60+% of internet traffic mobile users (and growing), fixup the existing, languishing mobile apps? So this Mac user wants the same incremental progress on winbox as the "Desktop solution".
Anyway, this forum is littered with reasonable and somewhat smallish feature-ettes and/or "bugs" – some more trivial than others no doubt. But progress on some of the small items here (and other threads too), but especially on the tools like Winbox, Dude, etc. is extreme slow or non-existent. Obviously I'd like them working innovative new things. But so many good features...that are missing a few minor things that really make them shine. Instead I get the impression they get lumped into future/mythical "new multiplatform winbox". For what? to solve theoretical concerns about wine...
</rant>
pe1chl
Fri Feb 17, 2023 11:37 am
It is still my opinion that effort spent on a MAC-specific Winbox (and then a Linux-specific one? What about *BSD?) is better spent on making a modern web-based config tool that has the same functionality as Winbox but runs in a browser like Webfig.
It would have been difficult in the days when Webfig was first created, but nowadays other companies show what is possible and it is way more than what Webfig does.
The advantage is that there is no more need for specific client OS support, there would be only some simple "agent" that can perform tasks like MAC-level connect, RoMON, and Netinstall, and that you can run only when you want to do that (and which you manage via your browser to a port at localhost).
benel
Fri Feb 17, 2023 1:29 pm
But wait, there will be no more Mikrotik way of being in that case. There will be no more pain all over the place and obscure tools and settings that only the Mikrotik guy knows and then Mikrotik will be more and more like all the others and there will be nothing special about them, they probably will just work without bug's and so and you will forget them at all.
It is so fun to discover the wheel all and all and all. I must agree that they are doing a lot of things in a very particular way (very advanced and a high modularity) and they are so good of creating their own ecosystem that they go sometimes to such complicated things that lead them to discover the AX standard or the WPA 3 after such a long time after low end companies and the entire planet; and lead them to create an ecosystem (v7) that still does not have a long term version after few years of development and another one year and (almost half) of releases (not to count that there was 17 !!! official releases from the v7.1.1 launch until now).
No, "simple" is not a good word to place in connection of your Mikrotik.
pe1chl
Fri Feb 17, 2023 2:42 pm
To make my point clear: in that proposal I do NOT intend to indicate that the entire management interface of RouterOS should change towards what a home router is!
What I propose is that Webfig is upgraded to supply what Winbox now does (interface with child windows, selectable columns, dialogs with tabs, etc). But the function of the dialogs in that revamped Webfig would be exactly what it is now in Winbox. So the same "knowledge about obscure config" would be required, only it could be applied from any device with a modern internet browser, with no software to be installed or run except in cases where low-level access is required. (e.g. to rescue a device where one has been locked out, or that has been bricked)
Amm0
Fri Feb 17, 2023 3:05 pm
I guess I'm saying fix up the existing tooling for advanced users. A few small things would go a long way... AND, give some breathing room for MT to create some great new tools, even if that meant whatever "multiplatform client" came in years (like V7 ended up taking)...
For home users, fix up the mobile apps. They already do setup (for a single WAN), status, and port forwarding, so starting in a reasonable place. But things like adding device notifications, would avoid needing scripts for what is obvious need. Or use the mobile OS to store passwords, etc. Or having some "multi WAN" or "VLAN" wizard that do the [cleaver+ridiculous] recursive routes for the user. Sure there are others that make it easier for a neophyte to setup/use Mikrotik. Put those in the mobile apps.
Bundling up everyones needs into some great new thing is why there isn't a more keyboard shortcut, status page in Winbox, or important things like BFD.
benel
Fri Feb 17, 2023 3:16 pm
^^^ Best way of saying where Mikrotik lose themselves. Totally agree with you previous post as entity, not only the quote.
pe1chl
Fri Feb 17, 2023 3:27 pm
To be clear: I don't propose a great new thing, I propose reworking of an existing tool and after that is finished, end the maintance of another existing tool.
(including ongoing requests to port that tool to another OS, incurring more and more development work on what is essentially a dead end)
I agree that "feature parity of v7 relative to v6" (including support for BFD at least with the features it had in v6) should be the #1 priority, but all recent release notes show that MikroTik (unfortunately) does not see it that way.
Sob
Fri Feb 17, 2023 4:03 pm
Who decided that everything in web browser is the right way? I for one say it's not. Don't touch my toys! ;)
stevester
Mon Feb 27, 2023 4:54 pm
-MACVLAN
-IPVLAN
More info
+2, a little rediculous that RouterOS doesn't already have this.
phistrom
Wed Mar 01, 2023 8:04 pm
Multiple Connection Marks and/or Packet Marks
Would help a ton for people who want to use policy routing and QoS. As it is now, the number of connection marks you need is a cartesian product of (# of interfaces) X (# of things you want to QoS). For example, wan1-voip, wan2-voip, wan1-data, wan2-data, wan1-game, wan2-game, ...
  • Maybe rename it from "marks" to "tags"?
  • Or even just let me have 2 connection marks per connection.
  • Or allow me to have one connection-mark and one... conn-queueing-mark or something.
  • Or let me match by wildcard? connection-mark=wan1-* or connection-mark=*-data?
Port Lists
Similar to /ip firewall address-list but for ranges of TCP/UDP ports.
It would be very handy to specify a list called "http" for instance, and make it contain 80,443, and "ssh" containing 22, and "winbox" containing 8291, and then create a firewall raw rule that had something like port-lists=http,ssh,winbox to target all the ports in those lists. I think it makes it more readable with friendly names, and hopefully would be just as performant as the current way of specifying port=22,80,443,8291.
Fix the initial normis post for this thread
Here normis says to email Mikrotik with your feature requests. Maybe that can be expressed in the original post? or the dead link removed? Just for folks who aren't aware that the page was taken down in 2014 and don't waste time looking for it?
pe1chl
Wed Mar 01, 2023 11:23 pm
I agree with that! And I proposed it before, too.
At some point it seemed that in RouterOS v7, things were going to change. Suddenly there was a max of like 256 different marks, suggesting that they had now split the 32-bit field that is used for this in Linux into 4 bytes for 4 separate marks.
But the UI to put the marks in them has not appeared yet.
In theory, with a max of 32 different marks, you could have each possible combination of them, and with 4 classes of 256 different marks, for purposes like you describe it would work well too.
I guess they are busy with other things at the moment, but one time it could appear.
MakroTok
Thu Mar 02, 2023 6:58 pm
I'd like to suggest a dedicated "Feature requests" sub-forum. A sub-forum would allow one feature request per topic and discussion on this specific topic alone.
Having all feature requests thrown into one thread is not helpful on discussion or working out details on a solution which would work for most peopl. It's also very cumbersome to follow up on a specific feature request.
I would love to have a way address shortcomings / missing features though, but, and I apologize beforehand as I surely don't want to offend anybody, right now this thread looks a bit like a convolute of ideas where they let people play with ideas so that they don't bother support...
TomjNorthIdaho
Thu Mar 02, 2023 7:39 pm
Feature request for Winbox ( this is NOT a feature request for ROS )
I suggest an updated version of Winbox that includes the Mikrotik btest.exe functions.
Currently without this new feature:
Winbox can only btest ( speedtest ) between any two Mikrotik devices.
Currently , the btest results indicate nothing about how fast the Windows PC computer running Winbox is performng.
With an updated Winbox with a built-in btest.exe ( btest speedtest ) function - you gain these new features & abilities:
A Windows computer running Winbox can now btest ( speedtest ) from the Windows computer to a Mikrotik.
These btest ( speedtest ) results would now indicate the users Windows computer network speed to the remote test Mikrotik device.
*** Some background information to support this new feature request in Winbox:
Most of the text below is from a posting I previously made in the forum section --> Public-Mikrotik-Bandwidth-Test-Server(s)
When , you are using a Windows computer that is running a Windows Winbox program. Your Winbox is then controlling a Mikrotik ROS device ( router or switch ) - and your winbox has opened the btest functions on the Mikrotik ROS device.
If/when you run a btest , you are speed testing ( btest ) the TCP and/or UDP throughput of your Mikrotik ( to another Mikrotik ROS device ). When the btest is running , the Mikrotik is performing the btest ( speedtest ) and the CPU on the Mikrotik is doing all of the work. Your Windows computer itself is not speed-testing anything.
Here is an enviornment where a btest function in Winbox that is running on a Windows PC computer can provide much more useful information :
- 1) You have a nice/new/very-fast Windows computer
- 2 ) Your computer has a 10-Meg Ethernet connection ( or a wireless connection ) to your Mikrotik ROS router device
- 3 ) Your Mikrotik ROS router device has a 10-Gig fiber link to another 2'nd Mikrotik ROS device
* When your Windows PC computer running Winbox sends commands to btest between both of your Mikrotik devices , you should get very close to 10-Gig ( if both Mikrotik devices have a fast enough CPU ). This does not imply that your Windows computer can talk at 10-Gig.
* If Winbox had a built-in btest function -- then you could btest ( using Winbox ) on your computer to either Mikrotik ROS device and you would get 10-Meg ( nothing faster ). So why only 10-Meg instead of 10-Gig ? --- Because you only have a 10-Meg Ethernet connection ( or wireless connection ) to the Mikrotik ROS device your PC computer is connected to.
*** If you have multiple Windows PC computers/servers ( all running a Winbox with built-in btest functions ) , then you can btest ( speedtest ) from any of your Windows computers through your network(s) to another Windows PC computers/servers ( or Mikrotik ) and then get a better picture of how fast your network really is ( not just Mikrotik to Mikrotik ).
***** If somebody can run 1 mile in 10 minutes ( Mikrotik btest to another Mikrotik ) , the speed that somebody can run has nothing to do with how fast you or I can run.
( AKA - the current btest speedtest results do not indicate anything about how fast the Windows computer is performing )
Currently , there is a Mikrotik btest.exe ( x86 based ) btest ( speedtest ) program that runs on a Windows computer. Few end-uses know anything or use this Mikrotik program and have never used it.
I would think it would be somewhat easy to append the btest.exe x86 program/code to the end of the Winbox.exe x86 program/code ( combine both programs into one program ) , and then add some new/additional GUI buttons in Winbox which can then allow Winbox itself on the Windows computer to perform a btest ( speedtest )
* It might also be desirable to hard-code limit the maximum time best can run ( 10 to 60 seconds ) , to prevent users from creating a sustained I/O saturation of their network(s).
Also - add a new GUI button in Winbox ( Check for Winbox updates ). The current method to update Winbox is semi-hidden and you have to know where to look to update Winbox.
Does this sound like a good feature idea to everybody else ?
North Idaho Tom Jones
Amm0
Thu Mar 02, 2023 7:59 pm
So if I understand this, you're suggesting winbox.exe "embed" btest.exe so it can be used without having to download it? And some UI to winbox that launch it as a window within (or outside) Winbox...
It been long recommend to run btest's NOT from the router your testing & you're right, this would make that easier to do.
That be useful since there isn't a btest.exe for Mac....
Amm0
Thu Mar 02, 2023 8:09 pm
I used RouterOS/winbox for YEARS before I noticed winbox could update itself (e.g. it's ONLY in the initial "Discovery"/"Login" windows menus, NOT the main "session" window).
I'd like this more automatic to check on launch if there is a new version and prompts to update. Dude essentially already does this today. With some "Enable/Disable Update Check" hidden in the menu.
rextended
Fri Mar 03, 2023 1:37 am
You really care about your name, it's always the most prominent thing in each of your posts and it's repeated in a completely useless way,
since it's also the nickname and on the avtar...
TomjNorthIdaho
Fri Mar 03, 2023 1:47 am
is that better ?
rextended
Fri Mar 03, 2023 2:00 am
You couldn't wait to do it.
What a narcissist…
mozerd
Forum Veteran
Forum Veteran
Fri Mar 03, 2023 2:01 am
I see that you as a moderator are attacking North Idaho Tom Jones because he like to see his name prominently …
I 41 like his sig … an attack of this nature is not becoming of a fine Italian person like yourself…
rextended
Fri Mar 03, 2023 2:04 am
Thanks, but I didn't delete or edit his message...
I got bored like all those who let appear "Sent from my device using Tapatalk" and similar repetitive message,
but in his case he also gave him more emphasis than the whole topic......
rextended
Fri Mar 03, 2023 2:08 am
why this wiki pade have been removed ?
Because exist this topic....
TomjNorthIdaho
Fri Mar 03, 2023 2:33 am
One of the reasons I use "North Idaho Tom Jones" is that in the past when I simply use "Tom Jones" I will always get the following?
"Do you sing ? "
"Any relation ? "
"I bet you wish you had his money ? "
"Theeee Tom Jones ? "
"Do you know him ? "
... and about a million other repeating comments ...
No , No, Yes, No, No
Best I can say is that I have actually had my checking account mixed up with his ( my paychecks going into his account. Also, I've had Las Vegas hotel reservations totally botched up and given keys to a luxury hotel room he would be using ( way way way way above my pay grade ).
In this industry, you got to have a slightly sick twisted sense of humor and be able to survive light humorous criticism .
rextended
Fri Mar 03, 2023 5:14 am
All junk, your nick and your picture does not say Jones, only you are obsessed with adding it at the bottom, otherwise people would not even know.
ivn
Fri Mar 03, 2023 3:46 pm
SSTP AES hardware acceleration please!
SSTP is the only standard protocol for Windows road warriors (but also can be used on other platforms with additional software) which works nearly anywhere. All other options like l2tp, ikev2, wireguard etc. are sometimes blocked in public or hotel networks.
Now we have pretty poor speeds and high cpu load with sstp on Mikrotik.
spippan
Fri Mar 03, 2023 5:13 pm
what does it bother you?
does it hurt someone?
way less offensive than many of your posts anyways. just leave it be, fgs
rextended
Fri Mar 03, 2023 5:16 pm
I already wrote it a little while ago, just re-read.
I feel it is useless to continue the discussion.
gabacho4
Fri Mar 03, 2023 5:46 pm
I feel it is useless...
Like so many of your posts. No wonder your mod powers were revoked. You've contributed nothing to this thread today other than to attack someone. Now I've contributed negatively as well but after watching your interactions with forum users over the past year or so I finally cracked. If you are going to just take pot shots at others please STFU.
TomjNorthIdaho
Re: Feature requests ( AP log connection nv2 signal strength )
Fri Mar 03, 2023 7:06 pm
Years ago , Mikrotik added the ability for an AP to log " connected, signal strength " when a client connects to an AP.
Below is a log example of Mikrotik AP logs AP using the wireless Protocol: 802.11 :
mar/02 09:04:31 wireless,info A6:CE:45:00:11:93@wlan1: disconnected, registered to other interface, signal strength -62
mar/02 09:25:37 wireless,info A6:CE:45:00:11:93@wlan2: disconnected, extensive data loss, signal strength -62
mar/02 11:33:54 wireless,info A6:CE:45:00:11:93@wlan2: connected, signal strength -73
mar/02 11:34:15 wireless,info A6:CE:45:00:11:93@wlan2: disconnected, received disassoc: sending station leaving (8), signal strength -73
mar/02 11:34:16 wireless,info A6:CE:45:00:11:93@wlan2: connected, signal strength -63
However , a Mikrotik AP using the wireless Protocol: nv2 does not have this AP logging feature.
Example below:
mar/01 10:21:27 wireless,info B8:69:F4:E5:30:49@wlan1: connected
mar/01 12:54:30 wireless,info 6C:3B:6B:DF:16:04@wlan1: connected
mar/01 12:54:31 wireless,info 6C:3B:6B:0E:5E:61@wlan1: connected
mar/01 12:54:32 wireless,info B8:69:F4:E5:30:B8@wlan1: connected
I would like to suggest that Mikrotik add this logging feature into APs using nv2.
Background supporting information for this feature request:
- The current AP Registration table that shows the current Tx/Rx Signal Strength has little relation to the original connection Tx/Rx Signal Strength when the client first connected.
- A wireless Client device will normally connect to an AP using a lower/slower connection rate. At slower connection rates , wireless cards almost always have a higher transmit power and a better more sensitive receive capability. At the initial wireless connection, both the AP and the Client will have better stronger signal strength for both tx and rx and a slower connection rate.
- After a Client is connected to an AP , both the Client and the AP connection rates will begin to up-shift to the fastest stable connection rates the wireless link can communicate at. Almost all wireless cards have a lower transmit power at faster connection rates -and- also have lesser receive sensivity at faster connection rates. Thus , the original signal connection strength can easily be 15-dB to 27-dB stronger or more than the current Registration table shows.
Here is a partial example of the wireless specifications for a 5-GHz DISC Lite5 :
Connect rate Transmit (dBm) Receive Sensitivity
6MBit/s 25 -96
MCS7 19 -75
After the initial wireless connection at 6MBit/s and after the connection has rate upshifted to MCS7 , the transmit power on the AP and client have both gone down by 6 dBm and the receive sensitivity on the AP and the client have both gone down by 21 dB.
Thus , an original connection strength may of actually been +27 dB stronger in both directions than what the Registration shows.
This information should be logged when an AP is configured to use Access-List Signal-Strength-Range setting ( strength required to connected and signal strength to force a disconnect ). If/when these settings are incorrectly configured , you can easily have your wireless clients connecting and disconnecting over and over again and repeating this loop forever. Hense - the reason a logging of wireless nv2 connection strengths is needed.
North Idaho Tom Jones :) lol
petkodmitriy
Fri Mar 03, 2023 8:31 pm
It would be great to implement a ``routing table lookup'' . it is described in the WIKI, but there is no way to use it.
https://help.mikrotik.com/docs/display/ROS/IP+Routing
IN Extreme XOS thehe is this feature.
Amm0
Fri Mar 03, 2023 8:52 pm
In V6 there was /ip/route/check that gave a definitive routing result, but V7 removed it. See viewtopic.php?t=164150&hilit=route+check
I too like to see that back (or similar), it was a quick way to know your routing tabling was doing what you'd expect.
petkodmitriy
Fri Mar 03, 2023 9:06 pm
yes, it can be used in version 6, but I want a better implementation, and to see which route is active.
rextended
Sat Mar 04, 2023 2:19 am
Finally someone with just spirit....
@gabacho4 calm down, it was already over there, it's normal to disagree or send yourself to hell,
I'm not the hypocrite of the moment who gets along with everyone just to please.
Continuing to continue to continue is useless.
volkirik
IPV6 FASTTRACK PLEASE
Sun Apr 02, 2023 4:35 pm
IPv6 Fasttrack support, please
prawira
Trainer
Trainer
Fri Apr 14, 2023 7:57 am
hello,
i would like to request dynamic queues like dhcp for dot1x.
so every devices connected will create dynamic queues according to the parameter given on radius.
do not forget others parameter like insert before, parent queues, etc
cheers
P
volkirik
Fri Apr 14, 2023 12:13 pm
hello,
cheers
P
+1 for this one.
flydvorkin
Sat May 27, 2023 1:03 pm
console
It would be useful if "add" command (in all menus) return to script id of created entry.
Sorry, my mistake, add already returned ))
emunt6
Sat May 27, 2023 5:52 pm
OOB interface:
> IPMI/Redfish - management (no more "Netinstall")
https://www.dmtf.org/standards/redfish
qwerty77
Thu Jun 01, 2023 12:42 am
Feature request:
Add button to log entry so one can create firewall rule to remote address.
Log is seen by admin to reveal some undesired activity. Copypasting is time consuming.
Consider adding a button which will call New Firewall rule, with pre-filled IP from Log entry. This is supposed to improve usability.
Thanks.
TomjNorthIdaho
Thu Jun 01, 2023 1:43 am
Feature request:
Thanks.
FYI - PfSense has this feature, and it works well - The feature you are asking for might be very useful in Mikrotik ROS
rextended
Thu Jun 01, 2023 3:18 am
1) Why leave SSH open to the world (these are the consequences, if not also attract DDoS attacks),
2) Why don't you already have a script that blacklists the IP after the second failed attempt in not even 4 seconds?
pe1chl
Thu Jun 01, 2023 11:29 am
Of course you would not want to make a "new firewall rule" for that!
First learn a bit more about firewall rules. To block random IP addresses, make a SINGLE rule that blocks some traffic referencing an "address list".
Then put the address you want to block in the address list. You can add many addresses in the address list and they will all be blocked by a single rule. Better for CPU usage!
Also, you can have a timeout on an address list entry, so it automatically gets removed after some time.
And of course, what you want is already possible! You can write a script that reads the log, finds messages like the above, extracts the address from it and adds it to the address list.
No new feature required for that.
qwerty77
Fri Jun 02, 2023 4:00 pm
Thanks rextended & pe1chl, the script idea looks reasonable. Will consider this.
flydvorkin
Fri Jun 02, 2023 11:06 pm
Request scripting feature.
Modify commands
:local <name> <value>
:global <name> <value>
to make it possible set <name> from other variable.
also add $$ construction for access to such dynamically-named vars.
Example:
:local varname "newVar";
:local $varname "test";
:put $newVar;
test
:put $$varname;
test
rextended
Fri Jun 02, 2023 11:18 pm
I don't think it's a matter of implementing useless things or not,
but a question of knowing how to use what already exists...
Example:
:put $newVar; <<== this do not have any logic, if you already know the varname inside the script, no need to create it dinamically
test
:put $$varname;
test
working example code
:local localvars [:toarray ""]
:set ($localvars->$varname) "test"
:put ($localvars->"newVar") ; # the same as on previous comment, is illogic, but for example...
# previous :put wire "test" on terminal
:put ($localvars->$varname)
# previous :put write "test" on terminal
:local testip "newipvar"
:set ($localvars->$testip) 127.0.0.1
:put "Local variable $testip value is $($localvars->$testip) and the type is $[:typeof ($localvars->$testip)]"
# previous :put write "Local variable newipvar value is 127.0.0.1 and the type is ip" on terminal
And if the variable must be global, just create
:global globalvars [:toarray ""]
etc.
Or use another method:
viewtopic.php?f=9&t=178435&p=879152#p879152
flydvorkin
Sat Jun 03, 2023 10:03 pm
All this examples i understand and i know how to use it.
Feature request desire to simplify a lot of work.
pe1chl
Sun Jun 04, 2023 11:21 am
Simplify a lot of work?
I would say it is just a niche case that is mainly a trick, and associative arrays (as in the example by rextended) are the proper way to do what you want.
Sure there are some things that can be improved in the scripting language, and especially in its parser, but I don't consider this one of them.
rextended
Sun Jun 04, 2023 1:00 pm
[…] there are some things that can be improved in the scripting language […]
For example, decimal division...
RouterOS: 3 / 2 = 1 must be done (3 * 1000) / 2 = 1500, then split the string "1" + "," + "500" and remove last zeros at the end...
pe1chl
Sun Jun 04, 2023 6:18 pm
For me, the most important is to add a BNF definition of the language and make the parser adhere to it.
I have found many times that when combining various constructs that each are supported into a complicated expression, it does not work.
You need to break up complicated expressions into various steps. In a decent language that is not required, anything derived from the simple examples goes when combined in a complicated expression.
Amm0
Sun Jun 04, 2023 6:57 pm
Not BNF, but there is a "table" of the syntax in /console/inspect
/console/inspect input=":put \$" request=completion
Columns: TYPE, COMPLETION, STYLE, OFFSET, PREFERENCE, SHOW, TEXT
TYPE        C  STYLE        O  PR  SH  TEXT
completion  [  syntax-meta  6  75  no  start of command substitution
completion  (  syntax-meta  6  75  no  start of expression
completion  $  syntax-meta  6  75  no  substitution
completion  "  syntax-meta  6  75  no  start of quoted string
/console/inspect request=syntax
Columns: TYPE, SYMBOL, SYMBOL-TYPE, NESTED, NONORM, TEXT
TYPE    SYMBOL         SYMBOL-TYPE  N  NONORM  TEXT
syntax                 collection   0  yes
syntax  beep           explanation  1  no
syntax  blink          explanation  1  no
syntax  certificate    explanation  1  no      Certificate management
It's turtles tables all the way down.
pe1chl
Sun Jun 04, 2023 7:14 pm
The problem is that there is no BNF definition of the language that corresponds with the behavior of the parser.
So you cannot make arbitrarily complex nested expressions that would be valid in almost any language. At some point it just issues an error.
And of course, the indication and handling of errors also leaves a lot to be desired...
optio
Long time Member
Long time Member
Mon Jun 05, 2023 9:21 pm
Please add syntax error / bad command messages into log file (same messages when commands are executed from terminal like bad command name egdfg (line 2 column 1)) for uploaded autorun script (<something>.auto.rsc), into "<something>.auto.log" or "<something>.auto.err" if .log file is meant to be only for successful execution.
I'm trying to create IDE (VSCode) task configuration which uploads working script over SFTP and reads output from log file or error over SSH, but I'm unable to catch error for exact executed script, it is not possible to exactly match script error log with that uploaded script execution (ex. if other script is executed with error in that time) but it will possible if is error logged into file with same basename.
depth0cert
Fri Jun 09, 2023 5:58 pm
Please add sstp - authentication process using EC digital signature
AdruKO
Sat Jul 01, 2023 10:50 pm
Greetings. The feature request I recommend is that the host used to detect the Internet in interface/detect-internet can be customized to any other host (domain or IP).
spippan
Tue Jul 11, 2023 3:00 pm
[FEATURE REQUEST]
- Firewall History Log
could it be possible to implement a firewall connections log (a seperate TAB for example directly in the ip>firewall window/section)?
with maybe some settings like "max-conn-count", "max-lines" and/or "max-history-timeframe" (which could define for how long it is possible to look back)
something like CHECKPOINT or BARRACUDA NG Firewalls do have.
cheers
pe1chl
Tue Jul 11, 2023 4:15 pm
You can create that yourself by adding the proper /system logging definition...
pe1chl
Thu Jul 13, 2023 11:54 am
When adding a bridge filter to a vlan-filtering bridge, it would be nice when you could specify the VLAN id AND the MAC protocol.
As it is now, when you filter on a VLAN id you cannot filter on any other MAC protocol.
I would like to filter "ARP on VLAN 2", for example. So I want to specify MAC protocol ARP and at the same time VLAN id 2.
(of course the filter would match on the string of MAC protocol 8100, VLAN 2, MAC protocol ARP)
EdPa
Thu Jul 13, 2023 12:22 pm
Bridge filter rules have limited matching options for L3, L4 headers when a packet is VLAN-tagged (contrary to switch ACL rules). But there is a special "vlan-encap" matcher that will look for MAC protocol.
/interface bridge filter
add chain=forward mac-protocol=vlan vlan-encap=arp vlan-id=2
msatter
Thu Jul 13, 2023 12:26 pm
Now the 4096 byte limit on variables is lifted and variables are now limited by the amount of available memory.
https://help.mikrotik.com/docs/pages/di ... ersions=28
:too fetch is still limited to 64512 bytes when using user->data and it then depends to the target server supporting chunked transfers. My request is to able to also read download larger than 64512 bytes directly into a variable.
To avoid stuff more data into a variable/internal memory a check could be done in advance with: [/tool fetch url=$url keep-result=no as-value] or have an extra parameter indicating the expected amount of data to be stored. So that a unintended big download does not bring the router in any problems.
This could be automatic like ((available memory / 3) * 2) limiting to 2/3 of available memory to be used by one variable.
Preferred or even enforced is using :local for big variables over/instead of :global.
msatter
Thu Jul 13, 2023 1:23 pm
Second request on bigger variables.
Using fetch I can write a bigger file to disk in one go. But then I can't read those back when the file is bigger than 4KB, despite the variable in not a limiting factor anymore in ROS.
This could be first one, so the request above for direct download in variable can be done on a later moment. Then a work around situation is created by first saving to disk and then read the file back to a variable.
https://help.mikrotik.com/docs/display/ ... remotehost
There is stated that the limit for variables is still 4KB and that is limiting reading the file.
pe1chl
Thu Jul 13, 2023 2:14 pm
Ok thanks! I saw that vlan-encap parameter but I mistakenly assumed that it would select the type of vlan encapsulation...
Unfortunately, when configuring it like that, it does not allow filtering on the ARP parameters as it does when mac-protocol=arp
Is that a bug or is it just impossible to implement?
EdPa
Thu Jul 13, 2023 2:35 pm
Right, the arp-* matchers require mac-protocol=arp/rarp to be set. I believe it is a bridge filter (ebtables) limitation.
pe1chl
Fri Jul 14, 2023 9:06 pm
Pity... now I still need to have a dummy bridge on the VLAN CPU port on the main bridge. Then I might as well drop the entire VLAN filtering bridge on this config (it is the one where I tried to hw offload the bonding interface)...
On to the next (unrelated) feature request:
I would like to see an option in /routing/table to have connected routes automatically added to a user-created routing table.
Ideally it would be a pulldown selector similar to what is in the firewall for "interface list", where you can select "none" (default), "all", or a user-defined interface list. But when that is impossible, just a checkmark to enable this (for all interfaces) would be nice as well.
This function will put "C" routes (as seen in table "main") into the user-created table as well.
I think it is already available in VRF, but VRF is often too restrictive for what I want to do (overlay networks, balance/failover between ISPs, etc).
pe1chl
Sat Jul 15, 2023 11:29 am
The "Input accept NLRI" filtering in BGP would be more usable when there is an extra "accept default route" option.
As it is now, you can accept prefixes in certain subnets (as present in the address-list parameter of "Input accept NLRI"), but once you want to accept the 0.0.0.0/0 route, everything is accepted. It would be great when you could accept some networks in the address-list, and not the networks outside that, but still accept the default route.
spippan
Sat Jul 22, 2023 2:54 pm
+1 for that.
would be really useful
expo
Thu Sep 14, 2023 3:33 am
bump for RFC 2439 / route dampening
Kraken2k
Thu Sep 14, 2023 1:20 pm
I understand the need to restart interfaces/processes/policies/etc. on change, but it is possible to exclude Comments field from this rule? They does not affect the actual configuration of the item in any way.
It's a bit annoying if I want to change a comment for IPsec Policy or Netwatch Host and the item turns off and on again, causing connection reset / execution of Up/Down scripts etc...
Kraken2k
Thu Sep 14, 2023 1:34 pm
Also updating ciphers available for MT SSTP server would be a good idea, because the only ones offered now are TLS_RSA_WITH_RC4_128_SHA and TLS_RSA_WITH_AES_256_CBC_SHA
ammaree
Fri Sep 15, 2023 2:25 pm
Some Winbox related requests from me:
#1 I often use Winbox to support IOT devices behind a firewall. Access is based on Telnet or SSH using Tools->Telnet menu access. If this menu option could be accessed from the DHCP Server->Leases screen, possibly using Right click with the device highlighted it would save a LOT of time.
#2 Certain operations such as a firmware upgrade cause the device to reboot and the connection to be Disconnected. If a "Reconnect" option (or better keyboard shortcut) can be added to automatically reconnect using same protocol and credentials it would be wonderful.
#3 Ability to hide/remove certain columns from some of the screens would be wonderful. This will allow support staff to reduce the clutter by having fewer but relevant columns displayed on some mobile devices such as small laptops.
#4 If the above custom configuration can be saved as part of a user profile this will be wonderful and save time having to remove the same columns again.
pe1chl
Fri Sep 15, 2023 2:34 pm
This has been available for ages! You need to click the small triangle at the rightmost edge of the column titles and use "show columns".
This is also saved to the profile for that router when you click "session->save" or have "session->autosave on close" enabled and neatly close the session.
(does not save when you lose the network connection e.g. because the router reboots)
seriquiti
Fri Sep 15, 2023 2:36 pm
Ability to choose specific archive version in packages to downgrade/upgrade to.
RouterOS stable versions have proved to be unstable regularly. Having the option to just choose a version to install will be very helpful on devices with small flash storage where you can't just drop the file in and reboot.
pe1chl
Fri Sep 15, 2023 3:24 pm
Sure the System->Packages menu could have some very simple improvements! Not only selection of a version, but also selection of packages to install.
The packages are available from the update server, so why do we have to download them on a computer, finding the correct architecture, unzip the file, upload the npk to the router? There could be an Install button that shows the packages available for the installed version, and download and add one.
ammaree
Fri Sep 15, 2023 3:57 pm
Thanks, havent seen the right most side because we have always reduced the size of windows to fit in....
ammaree
Fri Sep 15, 2023 3:59 pm
And another (much repeated request) for a NATIVE MacOS Winbox version. Currently have to start VMWare Fusion just to start Winbox....
Amm0
Fri Sep 15, 2023 4:29 pm
100% agree. It comes up when a "stable" release isn't actually "stable" for a particular configuration/router/hardware/whatever. "Rollback" to another version is quite tedious/manual & requires a good how understanding of package management. e.g. you have to align the specific packages previously installed to manually copy the same set of "extra-packages" & knowledge of the "file copy" method of upgrade in first place.
Amm0
Fri Sep 15, 2023 4:34 pm
I use a Mac, just use wine, it works "natively enough". Now they should release a 64-bit Dude, because there you do need Fusion (or similar VM), which is annoying.
IMO Mikrotik should focus on fixing these little things, not worrying about multi-platform clients. And if they made their iOS app more functional, it work on newer Macs.
memelchenkov
Fri Sep 15, 2023 5:23 pm
WinBox works perfectly under CrossOver for ages, you do not need virtualisation software to run it.
kwagga
Tue Sep 19, 2023 5:56 pm
+1 to this!!
automatically add local routes to additional route tables
sas2k
Thu Sep 28, 2023 2:49 pm
I need either shadow socks or some kind of obfuscated vpn protocol (v2ray, vless, xtls reality, etc...).
Shadow socks seems to me more preferable, as it operates separately tcp-tcp , udp-udp, plus socks5 already in ROS.
UNFORTUNATELY nowdays most if restictions cannot be resolved with wireguard/ipsec, as these protocols are blocked easily and effectively.
LouisVisagie
Fri Sep 29, 2023 2:39 pm
It would be really nice if MikroTik would add the ability to graph health information such as voltage and temperature and no I'm not referring about SNMP and API, I am referring to tools->graphing,the same way as resources, queues and interfaces are graphed.
Yes please. With RouterOS 6 this could be managed with scripts and email, but I've yet to find a way to get a report of a router's voltage health for the duration of a day on RouterOS 7.
TomjNorthIdaho
Fri Sep 29, 2023 9:09 pm
IMO - if you want to graph your network , consider using something like Cacti, or Zabbix , or LibreNMS ( or any other Network Monitoring software ).
I prefer a fast non-bloated switch/router that is not also using disk space or cpu processes or memory processes to capture and store graph into.
Then you can also keep your graphs much longer ( years or more ) on everything ( cpu, mem, I/O throughput , voltages , temperature , connected users ... and/or anything your switch/router will allow your NMS system to SNMP read.
Normally , on a Mikrotik , I disable/turn-off all graphing to avoid tasking the CPU , consuming flash disk space to get the maximum throughput performance possible.
gfunkdave
Fri Sep 29, 2023 10:45 pm
What is the current correct way to submit feature requests to Mikrotik?
pe1chl
Sat Sep 30, 2023 4:02 pm
Make a ticket on the customer support portal at https://help.mikrotik.com/servicedesk
pedja
Long time Member
Long time Member
Sat Sep 30, 2023 5:24 pm
I stumbled upon "cannot run, not enough permissions." error while trying to run script from scheduler (MT 6.48.6). For years is worked fine and it seems with some upgrade it stopped working as something with permissions was changed.
While searching for a solution, I found out numerous issues reporting with NetWatch. People were unaware WHAT permissions are needed for script to be executable by NetWatch.
I resolved an issue. In my case I had to allow all permissions but romon and dude to both schedule and script to make it work. with less permission, although it was the same for schedule and script, it still reported permission error, but not what permission is required and missing.
I have a feature suggestion: When permission error is reported, post what exact permissions are not fulfilled. It would really help finding issue in quicker and easier manner, and with less frustration.
mickdoev
Fri Nov 03, 2023 1:50 am
When creating a GRE tunnel using IPsecret - the dynamically created IPsec peer uses exchange mode MAIN. It would be great if there was a way for the dynamic peer to use IKEv2 (without having to manually create the peer and identity under IPsec)
pe1chl
Fri Nov 03, 2023 11:36 am
+1! It would be great to be able to select a profile other than default (but I see exchange mode is not part of the profile)
It would be great when these settings would be moved into the profile, e.g. also "passive".
spippan
Fri Nov 03, 2023 2:59 pm
how would you like to move phase1 settings to phase2 around or vice-versa?
mutluit
Forum Veteran
Forum Veteran
Fri Nov 03, 2023 4:09 pm
We need wildcard searching (*) in address-list searches:
[xxxxx@yyyyy] /ip firewall address-list> add list=TEST address=192.168.128.3
[xxxxx@yyyyy] /ip firewall address-list> add list=TEST address=192.168.128.0/24
[xxxxx@yyyyy] /ip firewall address-list> print where address=192.168.128.*
Flags: X - disabled, D - dynamic
# LIST ADDRESS CREATION-TIME TIMEOUT
pe1chl
Fri Nov 03, 2023 4:15 pm
No need for that. I would (like the other request) just want to specify an initial phase1 profile.
pe1chl
Fri Nov 03, 2023 4:16 pm
This has been asked several times before by people who do not realize that it already exists.
print where address in 192.168.128.0/24
mutluit
Forum Veteran
Forum Veteran
Fri Nov 03, 2023 4:38 pm
Ah, cool!
Should be added into the documentation.
BUT: what about wildcard searching after domain names in such address lists, for example searching all related to "google", ie. "*google*" ?
rextended
Fri Nov 03, 2023 4:48 pm
Ah, cool!
You should read the documentation. Is already present, on both old and new.
https://wiki.mikrotik.com/wiki/Manual:S ... _Operators
https://help.mikrotik.com/docs/display/ ... lOperators
The documentation cannot provide all the examples of what can be done with scripting.
Simply (of what) it says 1+1=2, then (4 * 6 + 2 - 7 / 22) = 26 you have to do it yourself...
rextended
Fri Nov 03, 2023 4:54 pm
Added during previous reply:
literally where address have inside "google" on any point
(literally is not one script instruction)
/ip firewall address-list print where address~"google"
Still you do not read the already available documentation....
https://help.mikrotik.com/docs/display/ ... rOperators
So your "Feature requests" would be: "Someone read the documentation for me"...
rextended
Fri Nov 03, 2023 5:04 pm
In conclusion, for this:
The correct way is to use "in" but for paragonable/regex syntax is:
/ip firewall address-list print where address~"^192\\.168\\.128\\.*"
Amm0
Fri Nov 03, 2023 5:53 pm
The GRE IPSec profile suggestion is good one. Never thought about this approach:
+1 too. The "Use IPSec" checkbox is so handy, just limited today – a profile selector be useful .
I just add equally or more useful on EoIP too.
pe1chl
Fri Nov 03, 2023 6:41 pm
Why is this then not working?
[xxxxx@yyyyy] /ip firewall address-list> print where list=TEST
 0   TEST                                                         play.google.com        nov/03/2023 15:43:46
 1 D ;;; play.google.com
     TEST                                                         172.217.16.78        nov/03/2023 16:28:30
 2   TEST                                                         www.google.com        nov/03/2023 16:52:02
 3 D ;;; www.google.com
     TEST                                                         142.250.181.196        nov/03/2023 16:52:02
[xxxxx@yyyyy] /ip firewall address-list> print where address~"*google*"
because you did not read the documentation and the examples above. *google* is not a valid regexp.
pe1chl
Fri Nov 03, 2023 6:45 pm
Yes, of course when that is implemented for GRE/IPsec it should be added for *all* cases where automatic IPsec config is possible.
(IPIP/IPsec, EoIP/IPsec, L2TP server, L2TP client)
spippan
Fri Nov 03, 2023 11:25 pm
oh sorry, misunderstood
got it. indeed would be favourable
emunt6
Sun Nov 05, 2023 12:44 am
Add Support for "Virtual Interfaces"
-MACVLAN
-IPVLAN
More info
https://developers.redhat.com/blog/2018 ... networking
Finally
What's new in 7.12rc1 (2023-Oct-05 08:46):
*) interface - added "macvlan" interface support;
:D
emunt6
Sun Nov 05, 2023 12:46 am
Feature request:
- SOC/ASIC Hardware accelerated multi-bridge/interface support
(example: Microchip SparX-5 / Marvell OCTEON TX2 CN9670 + RouterOS)
eworm
Tue Nov 07, 2023 1:35 pm
I've ask support to modify ssh public keys (/user/ssh-keys) to expose a read-only property with the key's fingerprint (SUP-132909). Actually public key authentication works quite well, but there is no way to verify that a key is the one you expect it to be.
Imagine you import a certificate "ISRG Root X1" to verify websites, but there is no way to verify its fingerprint, which should be "96bcec06264976f37460779acf28c5a7cfe8a3c0aae11a8ffcee05c0bddf08c6". Pretty bad, no?
Support answered:
If there will be more requests, we will consider implementing this feature.
So if you think this is useful (or even mandatory) please open your own request!
kryztoval
Thu Nov 09, 2023 10:48 pm
Winbox Feature Request
In Container
  • when using copy put the "tag" value into the "remote-image" field. so you can effectively duplicate the entry when required.
  • allow to use a log prefix to easily identify which container is actually reporting the thing to the long
In IP / Firewall
  • Add the "log_prefix" as the "comment" to the "add ___ to address list" action. This would help tracking which firewall rule added the address to the list and could potentionally reduce the number of lists. For instance there would be no need for an ssh_stage# list and a winbox_stage# list if I could just use stage# and now where each address got added from.
In Files
  • Collapsible folders
maxten
Fri Nov 10, 2023 6:52 am
Add select kernel congestion to bbr
after container is stable, router os has can take more service function in network. It's worth to support BBR congestion control for internal service such as VPN, storage, although it has no effect as a switch or router.
spippan
Fri Nov 10, 2023 7:11 pm
In Container
+10
In Files
+1
Amm0
Fri Nov 10, 2023 7:50 pm
In Container
+10
I filled a feature request bug a couple months ago (SUP-128652) on copy problem and that it :export doesn't actually create a usable "/container add" with remote-image= set.
mywayteam
Sun Dec 03, 2023 7:07 pm
Totally agree!
Hardware acceleration for sstp is very much needed.
spippan
Tue Dec 05, 2023 11:43 am
would help implementing standard windows clients by a LOT
mszru
Sat Dec 09, 2023 12:35 am
Wouldn't it be cool to have signal strength graph in the Wi-Fi Registration table like in Quick Set?
Having that column one can easily identify problem clients at a glance.
optio
Long time Member
Long time Member
Mon Dec 18, 2023 1:13 pm
Please implement non persistent (no flash write) change configuration possibility. This could be implemented through some global command like
:nonpersistent do={ ... }
any command that is performed inside that command context block should not persist change in configuration.
Some practical usages:
  • disabling/enabling interfaces or VPN servers to force reconnect used by netwatch or schedulers
  • any short interval configuration change in loop where persistence is not needed, like LED light show script that turns on/off different leds in short intervals (it is possible on some routers), I know router is not Christmas tree, but it could be used for presentation, eg. on stores shelf
Benefits:
  • reduced flash writes
  • avoiding possible edge case scenario when netwatch script disables WAN (internet connection) interface to force reconnect (eg. lte) and while it's disabled power loss occurred, on next boot, because of persistence, internet connection is no longer available and can be an issue if user is not at home and wants to use for eg. BTH VPN - this is solvable with additional startup script that checks enabled states of interfaces, VPN servers, etc., but it just complicates things where it could be simpler with non persistent commands
kevinds
Long time Member
Long time Member
Tue Dec 19, 2023 7:47 pm
Export with "show-sensitive" to include users and their hashed passwords. Also the ability to import users and include pre-hashed passwords.
pe1chl
Tue Dec 19, 2023 9:17 pm
YES! The export should be expanded to (at least optionally) include all of the configuration, including users, certificates etc.
pe1chl
Tue Dec 19, 2023 9:21 pm
Please make IKEv2 roadwarrior split-include functionality actually interwork with other people's software.
As it is now, it only works with other MikroTik devices. Standard IKEv2 client software only gets the first split-include entry, not further entries (i.e. you can route only a single local network using this mechanism).
gunther01
Tue Dec 19, 2023 9:30 pm
Ability to color the winbox header differently per device type. Or somehow allow the changing of the color and keep it persistant once changed..
This would allow me to make sure I don't "grab" the wrong window when I have 20 of them open and make a change in the wrong one. ie, green for cpe's, red for core devices, etc...
chuq
Wed Dec 20, 2023 5:44 pm
extended logging for scripts etc, with ability to specify the topic
like this
/log/write topic=script,info message="Doing fine!"
and to create a user defined topic
/system/logging/add topics=my-scripts action=memory
chuq
Wed Dec 20, 2023 10:26 pm
script errors (syntax, runtime) must be notified somehow
with a log message I suppose
infabo
Long time Member
Long time Member
Mon Jan 15, 2024 3:22 pm
Winbox: I am requesting automatic window tiling like done in linux tiling window managers. Not as feature blown but at least some control over the window-sizes and the split mode (horizontal/vertical).
I am disgusted by the floating alignment of the windows as it is now. I am aligning and resizing windows so I am fine with it. But want to add another window? Hell no. Resizing again. It is a real pita.
rextended
Mon Jan 15, 2024 3:30 pm
Use session / windows layout:
viewtopic.php?t=203402
anav
Mon Jan 15, 2024 3:50 pm
Busy cat this morning, check emails ;-P
When you do perhaps give me a hint on how to use sessions windows or why it would be good for me.
rextended
Mon Jan 15, 2024 4:01 pm
(done)
Just for memorize windows positions, colum size, colum order, filed present on colums and tab open...
sadjoe
Wed Jan 17, 2024 11:15 am
@normis please check
viewtopic.php?p=1049302
infabo
Long time Member
Long time Member
Wed Jan 17, 2024 12:09 pm
Yes, but I still have to fiddle around with sizing the windows inside winbox. "Right-click -> auto-layout windows" I am aiming for.
pe1chl
Wed Jan 17, 2024 3:33 pm
Well, I would not know how it could meaningfully auto-layout different windows with a so much varying content and optimal size...
For a window with "IP addresses" or many other similar windows you can use a tiny window. For something like routes or firewall you need a much larger window.
And, I always put "log" as a full-size window as a backdrop of all other windows, so that I can keep an eye on what is being logged.
sadjoe
Tue Jan 23, 2024 1:16 pm
It would be great if this is implemented.
viewtopic.php?p=1050972
TomjNorthIdaho
Feature requests - CHR on Bare Metal for faster Network throughput
Fri Jan 26, 2024 10:54 pm
Note: This topic is about achieving very fast network/Ethernet throughput ( as in 10-Gig and faster network routing throughput)
I would like to see a CHR that can be installed on a Bare Metal server.
Here is my reasoning and justification why I would like to see a CHR that can be installed on a Bare Metal server.
Mikrotik's CHR ROS runs on a Hypervisor ( such as VmWare or ... ). This is a 64-Bit operating system and also does not have the ability to be directly installed on a Bare Metal computer/server
thus:
- CHR , does not run on Bare Metal
- CHR , no install ISO ( or any procedure ) to install CHR on a Bare Metal computer
- CHR , can be installed as a 64-bit operating system in many Hypervisor environments
Mikrotik's x86 ROS can be installed on most Bare Metal computers and under most Hypervisor environments. However, x86 ROS is a 32-Bit operating system.
When a virtual CHR sends an Ethernet packet out through the virtual Ethernet interface, the packet is first delivered to the Hypervisor virtual vSwitch , which will always require at least one ( 1 ) physical CPU clock-cycle - thus so far , the packet has not actually been sent to anything yet.
Now that the hypervisor's vSwitch has the packet , the hypervisor will always require at least one ( 1 ) physical CPU clock cycle to send the packet out through the physical network interface card.
* So far , we have consumed at least two ( 2 ) CPU clock cycles or more to get the packet from the CHR out on the physical network switches.
if the packet is destined for another CHR on another different hypervisor , then there is at least one ( 1 ) CPU clock cycle to get the paket from the physical Ethernet interface and place the inbound packet on the vSwitch , and one ( 1 ) more CPU clock cycle to move the packet from the vSwitch to the CHR.
The effective throughput result is that when a CHR is sending or receiving packets out or in through physical network interfaces, we are running at half CPU speed. Thus , it is almost impossible for a CHR to achieve sustained network speeds of 6-Gig or faster ... because of the hypervisor CPU clock cycle overhead to transfer packets.
Depending on the physical CPU processor GHz clock speeds that the hypervisor is running on , it is easily possible to have a wall of 6-Gig or 8-Gig that the CHR is limited to in throughput. This wall is there because of hypervisor CPU clock cycle overhead when moving packets. Even if you have 100-Gig physical network cards on the hypervisor , the packet transfer throughput wall is still there. ((( And - there is also the CPU consuming clock cycle resources of the hypervisor which may also be slowing down the CHR throughput - because the hypervisor is also doing other things at the same time)))
ROS x86 32-Bit does not have this hypervisor CPU overhead when installed on a bare metal box. However, this is a 32-Bit ROS router and may not have enough RAM memory for large RAM needs such as multiple BGP tables and multiple OSPF tables and/or other RAM consuming things such as firewall rules and large address-list tables.
I think CHR might support SR-IOV interfaces ( which should eliminate the hypervisor CPU clock cycle overhead) , but I do not know if a SR-IOV driver is in the CHR ROS software. Also , not all hypervisors and network cards and BIOS configurations have SR-IOV support.
If Mikrotik were to support a CHR install on a bare metal install, the packet throughput should be possibly double the speed or more.
To backup my claim of packet speeds and hypervisor CPU clock speed overhead, there is a VyOS open-source router that can be installed on bare metal and also has SR-IOv support. There are many reports of VyOS router installs sustaining 40-Gig and much faster (nearly up to 100-Gig) network transfer speeds.
My ISP network CHRs are hitting that wall. I am currently upgrading my physical servers and switches to 100-Gig. I am also upgrading my four BGP Internet feeds to 100-Gig. My current CHRs can sustain 6-Gig but it's impossible to layer-3 route faster than 10-Gig.
So , I ask ... Would Mikrotik please consider creating a CHR platform that can be installed on bare metal - and have drivers for 40-Gig, 100-Gig, 200-Gig and 400-Gig network cards -and- also include support for SR-IOV network interfaces?
If the future of CHR will not include bare metal install features, then I will be forced to migrate my layer-3 CHR routers to something else.
pe1chl
Sat Jan 27, 2024 10:49 am
The problem with that idea is that for every network card some user has, and for every new network card on the market, the whining about "can you please include the driver for my card??" will begin. And not only for network cards, but also for all other hardware in the system (disk devices etc).
We have already seen that in the x86 release...
Running CHR on a Hypervisor neatly separates the RouterOS from the hardware at hand.
And SR-IOV is indeed supported.
Larsa
Sat Jan 27, 2024 11:10 am
As I mentioned in another comment, in terms of CHR performance using today's modern drivers supporting DirectIO/DirectPath/SR-IOV, it's as fast as bare metal and the overhead of the supervisor is barely measurable. A properly configured virtual system can easly push many hundreds of gigabits without significant CPU load.
IMO, one of the major advantages of CHR is that the platform becomes hardware-agnostic and enables live migration including network sessions to new hardware without any downtime (aka Hyper-V/vSphere live migration). It's a perfect fit for data center solutions like virtual BNG's etc I might add.
Thus from a purely operational and production perspective, CHR has almost nothing but advantages.
EDIT:
Forgot to mention that CHR is in no way dependent on or related to DirectIO/DirectPath/SR-IOV.
Instead, these features are managed by the host virtual machine and implemented through the network card's drivers, and they are available from most manufacturers for mid-end to high-performance solutions (though I've seen support for cheaper NICs nowadays).
Jotne
Sat Jan 27, 2024 12:38 pm
I am still waiting for RouterOS logging in RFC 5424 standard. Requested this for more than 5 years???
viewtopic.php?t=124291
emunt6
Re: Feature requests - CHR on Bare Metal for faster Network throughput
Sun Jan 28, 2024 12:57 am
Let me explain, you start digging by hand you hit a rock, you get "new shovel", but you stuck again, cant pass through - you asking what improvements needed on the "new-shovel" to break the rocks - the answer is simpe: You can't - you need heavy-duty equipment for that job :)
CPU PCI-E lanes can't handle/sustain that speed - other factors will be problem too ( example: LATENCY ).
The ASR9K/NCS series can do that kind of job.
jp
Long time Member
Long time Member
Sun Jan 28, 2024 11:23 pm
It could be handy to have a VLAN setup script just like the DHCP server setup script...
Was reviewing the different ways of doing common VLAN setups on mikrotik router+switch hardware. It seems to differ based on the switch chips, etc..
e.g..
/int/vlan/setup
what is the VLAN ID you'd like to use? (1-4095)
5
what interface(s) should be tagged with vlan 5? /* tab completion would be welcome */
spfplus1
what interfaces(s) should be vlan5 without tags?
ether2, ether3, ether4
/* perhaps display a humanreadable summary and press enter to complete or control-c to cancel */
pe1chl
Mon Jan 29, 2024 11:19 am
RouterOS is not for the users that require wizards for everything...
infabo
Long time Member
Long time Member
Mon Jan 29, 2024 11:36 am
Could be added to QuickSet :D
gigabyte091
Mon Jan 29, 2024 11:53 am
You can forget about that... Quickset is not good for simple things, let alone VLANs that are whole different story on Mikrotik.
Larsa
Mon Jan 29, 2024 2:06 pm
CPU PCI-E lanes can't handle/sustain that speed - other factors will be problem too ( example: LATENCY ). The ASR9K/NCS series can do that kind of job.
ASR9x and similar models nowadays act more like "regular" linux blade servers with Cisco Linux (IOS XR). Blade cards mainly utilize standard buses including PCIe as interconnects. FPGA/ASIC switch fabric cards used for backplane intercomms currently yield approximately 230 Gbps per fabric with up to seven per backplane, totaling 1.6 Tbit/s.
Current PCIe 6 has a latency of a few nanoseconds and a transfer rate of approx 60 Gbit/s per lane. An internal fabric interface card using standard 16 lines provides about 960 Gbit/s and a blade card using 4 buses 3.8 Tbit/s. Even an old server from 2010 using PCIe 3 and a Xeon CPU can achieve over 200 Gbit/s line speed using a single bus.
CXL (explained) enhances the standardization with faster and broader utilization of interconnects based on PCIe for example within and between interfaces, backplanes, and servers.
Modern drivers with no-copy support operate solely with pointers to network data through DMA, meaning that the CPU only initiates the communication.
For standard systems, network cards generally constitute the main bottleneck.
Amm0
Mon Jan 29, 2024 2:29 pm
That may be true. But request is not far off from /ip/dhcp-server/setup which does prompting (and supports <tab>). So doing a /interface/vlan/add, /ip/address/add then /ip/dhcp-server/setup gets you a working VLAN in three steps (outside port assignment, and firewall which may solved with a another step by adding it to the LAN interface-list).
Bigger issue WRT VLANs is the port assignment – that's wouldn't be helped by a wizard. Better UI is what's needed there.
QuickSet could be improved. But the default configuration could just include "vlan-filtering=yes" as a default, so a router be "VLAN Ready™". It doesn't break normal case & safe to set if done as part of initial boot.
pe1chl
Mon Jan 29, 2024 2:38 pm
Probably instead of adding even more of these "QuickSet" and "setup" hacks it would be better to develop a newbie-friendly GUI tool that allows configuration of the router in the same way as modern consumer routers are configured (wizards, task-oriented screens) and configures the router accordingly via API/WINBOX. With the express warning that once you configure the router directly, that tool can no longer be used.
(preferably also with some real guard against that, which should also be added to QuickSet itself)
miller443
Mon Jan 29, 2024 7:25 pm
If the router does not have a public IP address (4G connection), all traffic is routed through MikroTik servers, right?
gigabyte091
Mon Jan 29, 2024 7:27 pm
Great idea, especially for routers that targets home users. I mean you have Mikrotik Home app and BTH app and those are nicely designed and user friendly.
Mikrotik should make RouterOS lite, just for home lineup of routers IMHO. And if you want you can netinstall full version. It's just the matter of licensing in that case.
pe1chl
Mon Jan 29, 2024 8:06 pm
It would not require a different RouterOS do do that, just an application that has many wizards and knowledge of the hardware (how many ports, what are they called, what kind of WiFi, etc). The application asks the users what he wants to have, and sends the correct configuration commands to the router.
Once you make changes outside that application, you are on your own.
This is basically how Cisco did it on their IOS routers.
gigabyte091
Mon Jan 29, 2024 8:38 pm
I never really saw Cisco GUI, last time i had interaction with Cisco was in high school 11 years ago and that was through CLI.
What I meant when I said that Mikrotik should consider RouterOS lite is that they should maybe create stripped down version without for e.g all that routing protocols that home user will never use. So leave functions that home user will use (VLANs, VPN and so on) and create nice GUI and maybe cloud management app like ubiquiti and TP - Link for eg.
Also I would like to see PPSK.
pe1chl
Tue Jan 30, 2024 11:47 am
I don't know how it works today, but in the past we had Cisco routers and at some point a new router came with a package
that could be used to configure it. Written in Java to be executed inside your browser. It presented a web page with some
use cases and parameter fields similar to QuickSet, but if I remember well there also was a little more advanced configuration.
It resembled the UI of a consumer NAT router.
As I did not require this I de-installed it and used CLI, which is what all our other routers had and for which I already had a
configuration file (where only IP addresses had to be changed).
MikroTik (or an independent developer!) could write such a thing and cover the most frequent use cases in it.
The unfortunate thing is that once you require one single feature that is not covered by that program, and you start changing
things on the router itself, it then becomes unreliable to change other things via the GUI program. Same as with QuickSet.
So it better be very advanced and cover almost everything. A lot of work to make.
Kedare
Tue Jan 30, 2024 2:26 pm
Omg not this one. Cisco Configuration Professional.
That .hta file that would start a tomcat via an ActiveX component then show a Flash/Flex applet that will itself also embed a Java Applet. WHY would you do that.
pe1chl
Tue Jan 30, 2024 4:49 pm
Yeah, the implementation was sort of sub-optimal, and it would no longer work today.
But the idea in itself is apparently what a lot of people want: manage the router at "application" or "task" level, not at "VLAN config" or "firewall rule" level.
When there is demand for that, someone could write it and maybe make some money.
(although it is doubtful that people would want to pay money to overcome their lack of RouterOS knowledge, so probably that would have to work via in-app advertisement)
Amm0
Tue Jan 30, 2024 5:31 pm
Omg not this one. Cisco Configuration Professional. That .hta file that would start a tomcat via an ActiveX component then show a Flash/Flex applet that will itself also embed a Java Applet. WHY would you do that.
And I must be old... because I recall cisco IOS's "ip http server" being a rather limited, style-less UI in times roman font that let you get a config or type a command using old-school HTML forms.
The original feature request that prompt this discussion was a "wizard for VLANs". Given VLANs are both pretty "popular" & non-trivial to setup – seem reasonable request. IMO, "wizards" belong in the smartphone apps.
But do think some visual "VLAN configurator" be handy to both newbies and pros. e.g. It's a lot of config-reading to know if VLAN are configured as expected.
pe1chl
Tue Jan 30, 2024 5:59 pm
VLAN configuration is tricky in many different products. Often there is no good overview of what you are doing.
It can be done VLAN-centric (you define VLANs and specify which ports are tagged members and which are untagged members) or it can be done port-centric (for each port you can set which VLANs it has tagged and which VLAN it has untagged).
And then you can do it MikroTik-way, which is a mix of these two, and very confusing. That PVID setting has to go, and should be put in the VLAN untagged member list only.
But MikroTik is not the only supplier that does that... in my Netgear switch at home (GS108T2) it is done the same way and even worse: you need to set BOTH the PVID and the untagged VLAN. At least in RouterOS setting the PVID automatically sets the untagged VLAN (which I discovered only much later).
This mixed config allows the "flexibility" of having different config in upstream and downstream direction, but I would not know a valid use-case for that.
TomjNorthIdaho
Tue Jan 30, 2024 7:56 pm
Re: ... and very confusing ...
IMO - I agree , extremely confusing - - - and not the same configuration procedures across all Mikrotik past and present products.
IMO - I would like to see all Vlan and switching features and functions completely removed from ROS - and replaced with a SwOS package that is part of ROS. Then instead of a Mikrotik ROS software product and also a Mikrotik SwOS product , to just have one ROS software system with built-in SwOS. Then , if you have any Mikrotik product with a newer ROS release ( with built-in SwOS ), all routing functions and all Vlan configurations and all switching functions could then be all configured one common procedure. AKA - make it KISS ( Keep It Simple Stupid -- and the same across all Mikrotik products ).
well - that's my opinion.
spippan
Tue Jan 30, 2024 9:29 pm
no. why would you think that?
jp
Long time Member
Long time Member
Thu Feb 01, 2024 1:10 am
More than I suggested, but that would be a game changer way to go!
I might be showing my age.... The Cisco 2501 CLI had an awful little wizard to set things up if you did not choose "conf t"
The very easiest hardware to do VLANs with is the old HP Procurve managed switches... 4000m, 2524, 2848, 5300 series...
Rows were ports. Columns were VLANs. play battleship. Every switch worked the same. You could use their text interface like this, or use the CLI which was formatted in the way the text configuration is written.
Every switch's web interface since has not matched the HP text interface.
We eventually moved more to Mikrotik for power savings, as battery run time at tower sites is very important. And noisy hot switches run down battery backups quick. Now, how vlans work in mikrotik depends on which mikrotiks because they differ in cpu/switch chips. e.g.. things ideally program different for vlans between a crs124 and crs326 I think.
spippan
Thu Feb 01, 2024 3:36 am
imagine a world/dimension where there is routeros feature richness and customizability and a GUI like from that "UB.." company
jp
Long time Member
Long time Member
Fri Feb 02, 2024 8:01 pm
It is already more feature rich and customizable. I think the other company's GUI is good for central monitor and easy admin tasks (like updates and wireless settings), but difficult for things I might consider advanced.
hoboristi
Mon Feb 05, 2024 10:50 pm
Please make dynamic vlan assignment possible for wifi-qcom-ac wireless driver
spippan
Tue Feb 06, 2024 1:14 am
do you mean via RADIUS?
rplant
Tue Feb 06, 2024 8:27 am
Bridge-To-Bridge joiner.
To be assumed it will not be high performance.
Uses:
- Legacy PPPoE pass through (My ISP uses PPPoE...)
- Natting Mac addresses from devices to the CPU. (Multiple devices with the same Mac Address)
- mDNS and SSDP pass through in a single router.
viewtopic.php?t=194842&sid=9823878ca8fa ... 9452b2a5de
- Bridging items with different MTU's
Notes:
- An item that has 2 interfaces.
- Can (only) use the interfaces as a bridge port.
- Transparently transfers ethernet frames between interface 1 and interface 2 (bidirectional)
including any vlan tags, low level bpdu's, etc.
- Allows both ends to connect to same bridge (eg. for mDNS between 2 vlans)
- Maybe loop detect option (for when accidently join both ends to same bridge and same vlan)
- All filtering done using existing bridge filtering functionality
- Each interface gets the MTU of the bridge it is attached too.
(Don't have to be the same on each end)
pe1chl
Tue Feb 06, 2024 11:21 am
Via RADIUS or via access list. I also want to have that, I use it in the old wireless driver.
pe1chl
Tue Feb 06, 2024 11:23 am
You can do that with two local EoIP interfaces.
infabo
Long time Member
Long time Member
Tue Feb 06, 2024 7:46 pm
It would be even cooler to have the "hostname" in the wifi registration table (like it was available in the wireless registration table). But unfortunately Mikrotik seems not to be interested to add it anytime soon.
rplant
Tue Feb 06, 2024 11:52 pm
Whenever I have tried this it never allows me to have 2 with the same tunnel ID.
Also quite a lot of overhead.
goodbye
Wed Feb 07, 2024 2:07 am
This, a trillion times, this.
Also, make the vAPs for secondary SSIDs auto-populate and map on local bridges correctly.
There really should be "configuration parity" between wifi-qcom-ac and wifi-qcom.
Configuring and managing wifi-qcom-ac CAPs is a process that's entirely too manual right now in a way that the AX-generation driver doesn't seem as bad.
CAPSMAN is supposed to mitigate the challenge of managing a growing and/or complex infrastructure, not simply "dampen" the the linear increase of time/labor a bit.
UpRunTech
Thu Feb 08, 2024 12:17 am
You can't as the tunnel number can't be the same for 2 interfaces.
It's the same story for VLAN interfaces - it's the networking equivalent of the Pauli exclusion principle - you aren't allowed to have more than one VLAN interface with the same bridge and VLAN ID.
Mikrotik: Request - allow more than one VLAN interface to share the same bridge and VLAN ID. It will allow for some interesting modes mixing bridge filtering and routing.
<edit> Holy crap MACVLANs solves this problem! Cancel request!
rolling
Thu Feb 08, 2024 8:46 am
Hi!
I try access to link in fisrt post but it's broken.
Perhaps this has been requested before, sorry.
A printer server for share a printer connected to a USB port of devices i think it would be very useful for many users.
Regards.
jp
Long time Member
Long time Member
Thu Feb 08, 2024 4:12 pm
Regards.
The Mikrotik would be an excellent place for a print server!
I used to have to use a SSL vpn on my PC for work, and it broke local lan access which included printing I needed to do for work breaking network printing. It did allow access to my gateway IP, so that would have been ideal place for a printserver that's not affected by the PC VPN that routes everything except default gateway. Because I had a Mikrotik router, I setup a port forward to my network printer, internal accesible only, so that I could print.
A print server should be configurable to be blocked from the outside by default.
Amm0
Thu Feb 08, 2024 4:22 pm
I don't know about that. I'd think some mDNS support be more useful, than a print server, in 2024?
pe1chl
Thu Feb 08, 2024 4:43 pm
Indeed! This is just a general "VPN setup in the wrong way" issue. Put your VPN range in a different IP range and it all works fine.
Maybe the "automatic discovery of the printer" would be more difficult but mDNS support would improve that.
jp
Long time Member
Long time Member
Mon Feb 12, 2024 5:45 pm
One other request...
Make a din rail mounting option for the 5-port sized Mikrotiks. (hex, hex-s, hap-ac2, etc...)
I used to be in the ISP/WISP world, and Mikrotiks went on a rack shelf or zip tied to a cabinet.
Now, I work on boat ethernet systems and it would be real handy to snap a mikrotik and a few other items like data converters and power supplies to the wall with a din rail system. Mikrotik is a good fit for this market because of it's low power and wide input voltage. I mostly use them as a glorified switch for their logging/management features.
spippan
Tue Feb 13, 2024 1:54 pm
some VPN clients do tunnel all traffic and block local access (e.g. Checkpoint client vpn)
and there is not much you can do against it on your gateway (e.g. mikrotik router)
m4rk3J
Tue Feb 13, 2024 2:30 pm
+1, this is a must-have feature. You can't reasonably manage APs without it. Currently I have to have a static VAP in bridge and set the VLAN ID there...
UpRunTech
Fri Feb 16, 2024 11:12 pm
I agree. I have done some testing in this regard. With VLAN-Filtering turned on on a qcom-ac device it does indeed dynamically add the wireless interface, but to the wrong VLAN! Why!? It feels like it's a solved problem but for this unless there are other technical issues as yet unrevealed.
I think the issue though is that the method of setting up an AP client differs for AX devices and AC devices. The former doesn't need VLAN-Filtering and the latter does. Also there is the issue of how VLANs are tagged and how frames are promoted based on DSCP markings. The former it seems the AX devices have a hardware feature that adds and strips VLAN tags and also sets WMM priority based on DSCP. The older AC devices don't and you get a warning if you try use those options.
If the AC and AX devices all just used VLAN-Filtering and allow dynamic Wifi interfaces that'd be swell.
nicolap
Wed Feb 21, 2024 7:24 pm
- the old wiki page is missing, please update the first post!
+1 mac address list viewtopic.php?p=1057990#p1057990
Valerio5000
Wed Feb 21, 2024 8:16 pm
+1 mac address list !
Netstumble
Wed Feb 21, 2024 10:54 pm
[FEATURE REQUEST]
Please consider adding support for the MAP-E (RFC7597) transitional protocol
(preferably accelerated for the socs that support so).
Recently my isp (Cosmote, the major ISP in Greece),
began implementing MAP-E on its latest cpes for residential/soho (xdsl/FTTH) connections,
and some users find themselves having an ipv6-only connection.
I suppose the plan is for the ISP to move away from dual-stack.
For now, its deployment is rather limited,
and if the customer call support and ask for dual-stack they revert the change,
but this is bound to change sooner than later.
Now, cosmote usually is the testbed for DT (it's a member of the group),
and as far as I know DT also begun transitioning to MAP-E,
so, the change can possibly affect large part of EU,
and can render the use of mikrotiks/ros problematic.
m4rk3J
Thu Feb 22, 2024 10:02 am
wifi wave 2 qcom-ac:
Is there any chance you will add dynamic client VLAN assignment again?
It would also be nice to see the EAP identity in the registration table like before.
ahmedramze
Sat Feb 24, 2024 6:17 pm
Hello Mikrotik.
please allow the Mac-Telnet from WAN ether1 on default configuration we have very big problem when we reseting factory or installing new router all any access to router from ether1 disabled.
we tired from using ether2 or any other interface to first time login.
and some routers installed in places can not reach it.
Mac-Telenet required physical access to neighbor router and which its done locally
some one with me ? or I'm wrong.
pe1chl
Sun Feb 25, 2024 12:24 pm
The allowed interfaces for MAC-level access can depend on the model of the router, and possibly on the software it first came with.
However, usually it is enabled on all ports and when it is not, it is because you changed that yourself before.
ahmedramze
Sun Feb 25, 2024 7:31 pm
Yes but firewalls drop every thinks from WAN which its ether1 even the MAC discovery in almost router types, if we have client or any new router need to install two cables one for POE ether1 and 2nd for login to remove the default configuration , normally we do reset without default configuration but when do reset from Reset bottom its big problem , all our customer we use hAPacˆ3 with Power over POE ether1 and PowerBox Pro as POE switch all APs are on celling or in Higher place.
including new router need also two cable one for POE and 2nd connected to ether2
MAC-telnet its my lovely option in world of IT since 2005. :D
I think its easy to make the WAN from last interface such as ether5 or4 or make default WAN bridge and all interfaces in LAN bridge after first login user he can assign the WAN from interface list.
this was option and also its easy to except the MAC-Protocols from firewalls
Regards.
pe1chl
Sun Feb 25, 2024 8:17 pm
No, the firewall does not affect MAC level access.
I recommend you to do a full reset to defaults on the type of device that you have, and examine the configuration of MAC level access.
zax
Thu Feb 29, 2024 11:20 pm
Feature request: let us save graphs on USB/SD card finally!
spippan
Mon Mar 04, 2024 10:47 pm
+1 HA clustering with configuration preferably on the main node and config sync (like CARP from opnsense)
robmaltsystems
Long time Member
Long time Member
Mon Mar 04, 2024 10:54 pm
Double click on an entry in Winbox to connect.
pe1chl
Mon Mar 04, 2024 11:31 pm
Already works!
robmaltsystems
Long time Member
Long time Member
Mon Mar 04, 2024 11:37 pm
Never has here. Double click on that line and all it does is populate the top box.
gigabyte091
Tue Mar 05, 2024 6:27 am
Please Mikrotik, implement PPSK already...
Jotne
Tue Mar 05, 2024 8:12 am
RouterOS do support syslog so you can send any logs externally and graph everything. Look at my Mikrotik for Splunk.
Juliku
Tue Mar 05, 2024 9:20 am
Feature request:
IKEv2 Mobility (MOBIKE)
pe1chl
Tue Mar 05, 2024 12:09 pm
On the "managed" tab it works. I do not know about the "neighbors" tab, rarely use that.
robmaltsystems
Long time Member
Long time Member
Tue Mar 05, 2024 12:31 pm
I always wondered what managed tab was all about! Yes, double-click does work there. Same in Neighbors tab then :-)
Paternot
Forum Veteran
Forum Veteran
Tue Mar 05, 2024 2:21 pm
Yes, we can. But I agree with him: why not allow this? It must be a one liner change: In pseudo code, something like "write logs in /logs or /usb/logs?"
pe1chl
Tue Mar 05, 2024 2:35 pm
Likely the reason for not allowing such things is that users would configure it to use USB storage and then pull the USB key at an inappropriate moment, then complain about things crashing or otherwise failing.
robmaltsystems
Long time Member
Long time Member
Tue Mar 05, 2024 3:06 pm
Okay, added a few entries to "Managed" tab. Version, board and uptime are missing columns. Prefer Neighbours.
pe1chl
Tue Mar 05, 2024 5:27 pm
Did you enable "advanced mode"? It does not provide those fields, but it provides some other useful features.
millenium7
Long time Member
Long time Member
Wed Mar 06, 2024 12:13 am
Unless I've missed it somewhere...
Please for the love of God add a command or hotkey toggle to show all 'sensitive' fields in the console and not have them blocked out
When typing or pasting in a command that contains a password, it will blank that entire line out as soon as the enter key is pressed. Was there a typo in there? Were all commands on that line present? What exactly was typed? Who knows it's a total mystery BECAUSE THE DAMN LINE DISAPPEARS
It's made significantly worse when its part of a larger block or code, the entire block gets turned invisible. It's an absolute nightmare to work with
robmaltsystems
Long time Member
Long time Member
Wed Mar 06, 2024 10:46 am
Yes, I think you've missed it - settings show/hide passwords? Unless I'm missing something :-)
Paternot
Forum Veteran
Forum Veteran
Wed Mar 06, 2024 2:37 pm
You can't fix stupid. Let it using the onboard storage by default, but allow the user to change this. The Linux kernel already fails gracefully, when some block device goes away - there's even an mount option to control this. They only have to make sure the logger used fails gracefully too.
pe1chl
Wed Mar 06, 2024 5:33 pm
As it is now, RouterOS does not even properly close some files after using them (or forgets to "chdir").
I have an open bug where I have an NFS-mounted directory (the router mounts a directory on a server) where I put backups so they end up in the backup made from that server.
When I do a /user-manager/database/save name=nfs/umbackup overwrite=yes it correctly makes the backup but then the directory can no longer be unmounted (file in use).
So when I have done that I cannot even reboot the router anymore (e.g. as part of an upgrade), it hangs in the reboot.
It was claimed to be fixed, but it isn't.
pe1chl
Thu Mar 07, 2024 10:32 pm
Feature request for "ups" package: allow to set a script to be executed when UPS state changes between on line / on battery.
(to enable sending an e-mail or other alert when power fails)
robmaltsystems
Long time Member
Long time Member
Fri Mar 08, 2024 1:09 am
Winbox - better way of configuring the columns in all the dialogs. Certainly be able to right-click on a column and remove it.
rhn007
Wake On Lan in winbox leases context menu
Fri Mar 08, 2024 8:41 am
I think, it will be usefull to have context option "Wake On Lan" in ip / dhcp-server / leases.
I'm using this mostly to connect home with my home computer off (energy saving).
I have to lookup MAC address, start terminal and type (or lookup from history) command to start computer.
(too lazy to setup a script and I prefer typing before clicking)
Interface selection:
  • I recommend to select interface from related server section.
  • Other option is to offer interface (combobox) - anyhow not all interfaces are for internal/dhcp use.
Interface identification:
  • get Server column from leases list (Wake On Lan option can be located bellow Make Static)
  • lookup interface in corrensponding DHCP server
I also wrote several scripts to wake computers with parameter to lookup in /ip dhcp-server lease (IP or Comment lookup or hostname).
According to limited functionality to use parameters in scripts, it must be in eval form in global variable and global variables are not consistent across router reboots.
robmaltsystems
Long time Member
Long time Member
Re: Wake On Lan in winbox leases context menu
Fri Mar 08, 2024 12:03 pm
I tackle this another way - I've got a couple of cheap IoT plug sockets. PC is configured in BIOS to power-up if the power fails. So I go in the app on my mobile, turn the socket off, wait a minute and turn it back on. I gave up on WOL years ago when it never seemed to work!
millenium7
Long time Member
Long time Member
Sat Mar 09, 2024 2:04 am
More context options for DHCP leases would be nice. Especially right clicking and choosing mac-telnet, winbox, SSH, HTTPS etc
I'm almost exclusively looking in DHCP leases for a particular device that I need to do something with by connecting to it. Cutting out those extra steps of them opening putty/browser/winbox and typing in the address would be very welcome
lanslot
Mon Mar 11, 2024 3:17 pm
Currently UPnP and Hairpin NAT does not work together. It is because the dynamic dst-nat rules created by UPnP has the in-interface=<external> filter. It would be nice to remove this filter from dynamic rules created UPnP, either by default or via a configurable option. See this discussion thread for more details: viewtopic.php?p=1062302
Paternot
Forum Veteran
Forum Veteran
Thu Mar 14, 2024 1:55 am
There are some mainboards that don't work with WOL. Just a BIOS bug, I guess. I had one of those: an Asus, M5A97 LE. WOL just didn't work. As soon as I used another one (Intel or AMD, didn't matter), it worked alright.
i4ko
Thu Mar 14, 2024 3:11 am
A version of routeros 7 that has reduced footprint (and reduced functionality) but works comfortably on 16mb flash devices. I started a separate thread viewtopic.php?t=205735 if anybody wants to comment and discuss what functionality the small flash devices can go without
zax
Fri Mar 15, 2024 1:31 pm
Feature request: Register DHCP leases in the DNS Resolver, providing local name lookups for any DHCP client, static or dynamic.
I know it can be worked around with scripts, adding static entries on each lease but its bad solution that wears out flash memory.
hoboristi
Mon Mar 18, 2024 11:47 pm
nope, I want just the existing feature in wifi-qcom driver, like this:
pe1chl
Tue Mar 19, 2024 10:48 am
That is not a required feature, you can assign the VLAN in the bridge.
What is missing is the dynamic assignment via RADIUS or bridge filters.
emunt6
Sat Apr 06, 2024 3:26 pm
Request:
- New "CCR2004" rackmount hardware ( 24x1G, 4x10G port) with external 2x USB ports, internal 2x M.2 Storage port
The current CCR2004 lack of USB and Storage connection ports ( no LTE modem connection), this is ridiculous.
Mikrotik loves "cheap" SOC so use the "RTL9301-CG" chip with the ARM64 CPU with external USB and internal Storage ports.
pe1chl
Tue Apr 16, 2024 5:53 pm
Request: some function to "compact databases" so that the size of the databases again corresponds to what you would have after a
"reset configuration" and an "import" of the current configuration (plus things like certificates etc).
As it is now, the databases size tends to increase over time, resulting in large backup files and problems with storage on 16MB flash.
optio
Long time Member
Long time Member
Sun Apr 21, 2024 4:02 pm
Not sure if this is already asked, please put configuration change log into separate topic, for eg. system,info,configuration to have ability to filter it out without filtering other logs from system,info topic. When configuration change logging was introduced into system,info topic, log can get bloated with these records for eg. in case when some shceduler is changing configuration multiple times during the day and it would be nice to have ability to filter this out.
pe1chl
Sun Apr 21, 2024 7:59 pm
Or more general: add an extra topic to each and every unique log message, which is some numeric code that uniquely identifies that particular message.
That allows us to easily log or exclude particular messages.
Users browsing this forum: Heyman3 and 20 guests
