wallnas
How configure RB433UAH with modem USB Huawei E173
Sat Dec 10, 2011 6:09 pm
I have a RB 433UAH and modem Huawei E173 of H3G
In the System port i have only serial port 0
How i can configure the modem and use it on my lan ?
Tanks for your help
ojsa
Re: How configure RB433UAH with modem USB Huawei E173
Sun Dec 11, 2011 12:04 am
add PPP interface with details refering to your cellphone provider and connect the PPP to your selected port (port0?)
Could be that you have to add data channel en info channel, but since i don't have this equipment i can not test that.
wallnas
Wed Dec 14, 2011 7:37 pm
Tank you for your information, but my problem is on modem HUAWEI E173s-2
In the system resource USB i see the modem, in the system port, no
What is the problem ?
In the supported hardware http://wiki.mikrotik.com/wiki/Supported_Hardware there is the Huawei E173
My Vers of routerOs is 5.11
Tanks form your help
fjapa
Tue Apr 17, 2012 3:02 am
Wallnas, I am having a similar problem. Did you resolved this problem?
Thanks.
wallnas
Tue Apr 17, 2012 8:27 pm
Thanks.
Modem is switched to wrong mode, that's why it is not recognized by RouterOS.
Plug your 3G modem to Windows or other OS and run AT command to switch it to
correct mode,
AT^U2DIAG=1
http://3g-modem.wetpaint.com/page/Huawei+AT-commands
After command will be applied, modem will be recognized in RouterOS v5.12
bye
phallaccmt
Mon Aug 21, 2017 6:32 am
correct mode,
AT^U2DIAG=1
How to run AT command
Users browsing this forum: Ahrefs [Bot], Bing [Bot], CGGXANNX and 74 guests
