Vaako
RB SEXTANT 5HnD for PtP setup Questions
Thu Dec 15, 2011 2:23 am
I'm about to order two RB SEXTANT 5HnD for a Point-to-Point setup.
They both wil be installed in line of sight and about 370 meters in between them.
What speed wil I achieve, is this predictable?
I already have contacted the Mikrotik Support and they say: We have achieved even 200Mbit real throughput speed.
I dont understand correctly, how can you messure 200Mbit/s if the Ethernet port of the SEXTANT 5HnD is only 100Mbit/s ????
Who is able to explain this me or do I misunderstand the whole concept of this product?
Thx!!!
Regards,
Vaako
cbrown
Thu Dec 15, 2011 2:28 am
You misunderstand. The throughput is from wireless interface to wireless interface. But yes with a 10/100 ethernet that will be your bottleneck.
This is in the same ballpark and gigabit.
http://www.balticnetworks.com/stationti ... k-cpe.html
C.Brown
cbrown[at]mpl.com
MTCNA - MTCRE - MTCWE - MTCTCE
http://training.mpl.com
Vaako
Re: RB SEXTANT 5HnD for PtP setup Questions
Thu Dec 15, 2011 4:52 am
So they should have used this board instead: RB711G-5HnD
It has an Gigabit ethernet port.
http://routerboard.com/RB711G-5HnD
Regards,
Vaako
InoX
Thu Dec 15, 2011 4:43 pm
lan have 100mbps full duplex that means 100down+100up. Go to school and do your homework. :lol:
cbrown
Thu Dec 15, 2011 4:46 pm
What about a one way transfer? Maybe we are running backups. Then we are limited by the port.
C.Brown
cbrown[at]mpl.com
Vaako
Thu Dec 15, 2011 6:59 pm
I can not find anything about 100Mbit/s TX & 100Mbit/s RX in the spects.
I find this stupid.
You have a car that can go 200Kph, the front two wheels do 100Kph and the back wheels do 100Kph, together thats 200Kph.
So the car actualy can go max 100Kph.
Regards,
Vaako
InoX
Thu Dec 15, 2011 7:39 pm
is common sense in networking
Full-duplex data transmission means that data can be transmitted in both directions on a signal carrier at the same time. For example, on a local area network with a technology that has full-duplex transmission, one workstation can be sending data on the line while another workstation is receiving data. Full-duplex transmission necessarily implies a bidirectional line (one that can move data in both directions).
Full Duplex means that if your switch port is 100 mbps - you can upload 100 mbps and download 100 mbps at the same time
Effectively your I/O throughput is 200 mbps
Duplex means two way communication simulataneously
so mikrotik can do 200mbps over wireless, 100 upload+100 download. :D
normis
Fri Dec 16, 2011 9:14 am
I find this stupid.
nope, it still can do 200mbit total, it's called "full duplex" like InoX explained
CCDKP
Fri Dec 16, 2011 5:08 pm
Thx!!!
Sextant's might be a little overkill for 370 meters. At that distance you can use the less expensive SXT's and you will still probably have to turn down the transmit power.
CC_DKP: MTCNA, MTCRE, MTCWE, MTCTCE, part-time packet wrangler
Vaako
Fri Dec 16, 2011 11:04 pm
Yes you better go to school, there is no Bi-Directional signal available!!!
Regards,
Vaako
InoX
Sat Dec 17, 2011 10:15 pm
make one yourself...
:lol: :lol: :lol:
Vaako
Sat Dec 17, 2011 10:37 pm
@InoX
You have decreased my karma, Thx for that!
And the reason that you do that is that I do not listen.
I try to get some simple awnsers on how the 200Mbit/s is achieved and about the 100Mbit/s bottleneck.
I have to listen to you and if I do not agree you decrease my karma, have you ever heard of Freedom of speech ?
Regards,
Vaako
Vaako
Sat Dec 17, 2011 10:48 pm
Full-Duplex is NOT possible with that kind of hardware!
If you want to get Full-Duplex (Bi-Directional) you wil have to have the folowing setup:
Full-Duplex hardware setup:
Transmitter --> Receiver (TX on Frequency X)
Reiceiver <-- Transmitter (TX on Frequency Y)
Two separate channels for Uplink and Downlink.
I now this would be very expensive and therefore only use by professionals.
How the hardware now work is:
TX/RX <--> TX/RX (Tx and Rx on the same channel with or without bigger bandwidth option 20 or 40MHz)
Regards,
Vaako
mahnet
Long time Member
Long time Member
Sun Dec 18, 2011 6:15 am
use 40mhz, ros 5.9 or above with nv2. i have got 100 mbit uni-directional traffic over 5 km
when i run bandwidth test with both TX & RX it shows 50-55 mbit.
sextant is too much for 370 mtr. use SXT.
AND DO NOT WORRY FOR INOX.
he has that habit, did that to me as well. u keep up ur good work.
JorgeAmaral
Mon Dec 19, 2011 5:51 am
Full duplex is for the ethernet port.
Lets imagine that your devices can do 150Mb/s on the air. And you are doing a bandwidth-test on both directions.
You can achieve 75Mb/s up and down.
If you need a cheap full duplex radio link only with 802.11a/b/g support, you can use nstreme-dual.
Hope this helps,
Vaako
Wed Jan 04, 2012 11:34 pm
@mahnet
Thx for your respond, you tell about your bandwidth test.
Is this with the Sextant or SXT devices?
Thanks!
____________
@JorgeAmaral
Thx for explaining and advising to use nstreme-dual!
http://wiki.mikrotik.com/wiki/Nstreme_dual_Step-by-Step
I guess this is for devices that has two wireless cards on board!?
Thanks!
Regards,
Vaako
mahnet
Long time Member
Long time Member
Thu Jan 05, 2012 5:03 pm
i have not used a sextant yet. my tests have been on 1)pair of sxt ptp and 2)r52hn ap and sxt clients
Vaako
Thu Jan 05, 2012 6:55 pm
I was thinking to use two RB711G-5HnD with homemade Dual-Polarization Antenna's.
So I guess I definatly get the speed that you have 50-55mbit.
The R52Hn I use this on an RouterStation Pro and does it's job Perfectly!
Can you advice me software for benchmarking bandwidth a PtP connection but not the internal application?
I want to go out in the field and do some test with two Laptop's and I dont now wich software to use for this testing purposes.
Any suggestions are welcome!!!
Regards,
Vaako
Users browsing this forum: florentrivoire and 10 guests
