The spec sheet for the SXT 5HND states that the operating temperature range is -30C to +80C but doesn't state how this is to be measured.
I'm in Qatar where summer air temperatures will break 50C and objects in direct sunlight often are 20C higher, there are cases where exposed metalwork is 30C higher.
If I assume that the specification refers to ambient air temperature then there is no issue, if it refers to surface temperature then I may have a problem as the unit gets warm in operation. If it refers to the internal temperature sensor then I definately have an issue as it typically reads 20-25C above ambient.
Maybe I need to install a sunshield above the units.
Can anyone clarify how this specification value was defined?
Also I'd love to hear about experiences in hot and humid climates with the SXT 5HND. Same for effects of temperature inversion layers on links in the range of 1000-2000m.
Andy
