dtoffo
Trainer
Trainer
external editor syntax highlighting
Tue Feb 28, 2012 3:28 pm
I edit my configuration offline the routeros, so syntax highlighting would be a good help.
I use notepad++ and this morning made a "user defined lang" highlighting schema for .rsc files. I attach it (zipped).
Sure it's not perfect, but if anyone has better editor with routeros syntax, let me know!
d
janisk
Re: external editor syntax highlighting
Thu Mar 01, 2012 12:38 pm
thanks for the highlighting, hopefully a lot of people will find it useful, also, maybe even some could add to your initial submission to improve it.
thegink
Wed Mar 07, 2012 1:42 am
I use Textpad for the same thing - I've attached the syntax definition file I wrote for .rsc files.
t
gsloop
Mon Mar 12, 2012 8:34 pm
@dtoffo
Cool! Thanks!
-Greg
senzatempo
Sat Mar 24, 2012 2:24 am
thanks ..
why not put your ros.xml on notepad++ wiki
SENZATEMPO
dtoffo
Trainer
Trainer
Mon Mar 26, 2012 7:07 pm
thanks ..
SENZATEMPO
I didn't find where to put it... can you tell me where or put it there yourself?
d
skot
Long time Member
Long time Member
Thu Apr 26, 2012 8:51 pm
Thanks dtoffo for sharing! I took me a bit to figure out how to add it to Notepad++ amongst all the menus. In case anyone wants to know: Click View > User-Defined Dialogue > click Import button
angboontiong
Mon May 28, 2012 6:17 pm
Hi all...
may i know how to use this?
thanks.
skot
Long time Member
Long time Member
Thu May 31, 2012 5:37 am
Hi all...
thanks.
1. Download Notepad++: http://www.notepadplusplus.org
2. Install Notepad++
3. Download file above: http://forum.mikrotik.com/viewtopic.php ... 61#p305377
4. Open Notepad++, and click View > User-Defined Dialogue > click Import button. Import the xml file you just downloaded.
5. Open a .rsc script, and syntax highlighting will be visible.
angboontiong
Sat Jun 02, 2012 5:59 pm
Hi all...
thanks.
Hi....
appreciated it and thanks a lot...
thanks...
omega-00
Tue Jul 17, 2012 5:33 pm
d
I've made some improvements to the colour scheme (matching what's in winbox) and added a bunch more keywords; do you mind if I upload a copy of my modified version here and host another one on my website?
dtoffo
Trainer
Trainer
Wed Jul 18, 2012 12:43 pm
Any update is always appreciated.
Post it for us and put where you want: there's no copyright nor any other restriction.
just I think it will be good to update this thread for anyone searching it on mikrotik forum
thanks
d
omega-00
Wed Jul 18, 2012 3:04 pm
Here you go!
RouterOS-Syntax-Highlighter.rar
acim
Sat Sep 29, 2012 7:27 pm
Is there plugin for Sublime Text 2? It's a great editor.
ABeepMike
Wed Nov 28, 2012 2:31 pm
I would really like to try this tool, but, I download Notepad++ and try to install the user defined .xml file here , but there is NO entry in the View Menu for User-defined dialouge....
THere are many many entries in that menu...just not THAT one....I am using ver 6.22
Am I missing something here.....
skot
Long time Member
Long time Member
Thu Nov 29, 2012 5:05 am
It must have been moved in a new version...
Now it's in Language > Define your language...
or you can import it by going to Settings > Import > Import style theme(s)...
skot
Long time Member
Long time Member
Thu Nov 29, 2012 5:55 am
I like the improvements! Cool 8)
ndbjorne
Sat Dec 15, 2012 6:05 pm
my editor of choice is VIM and here's my VIM syntax file based on dtoffo's work.
Linux HowTo:
create your own syntax repository
[b]mkdir -p ~/.vim/syntax[/b]
and copy there "rsc.vim", then edit
[b]~/.vim/scripts.vim[/b]
and add lines to let vim recognize them.
Just in case this is your first custom syntax file here's the content for a minimal scripts.vim file:
[b]" Vim support file to detect file types in scripts
" first line check
let s:first_line = getline(1)
"       Mikrotik RouterOS script
if      s:first_line =~ "^#.* by RouterOS"
        setfiletype rsc
endif
unlet s:first_line[/b]
Hope you'll like it.
efaden
Tue Aug 27, 2013 4:11 am
Linux HowTo:
" first line check
        setfiletype rsc
endif
I'll throw my vote in for TextMate 2 or Sublime Text 2/3 ... If anyone has done them yet.
-Eric
jarda
Mon Sep 09, 2013 5:25 pm
I wonder why the syntax check (and debugging) is not already implmented in ROS/WinBox...
boen_robot
Tue Sep 10, 2013 2:59 pm
Syntax highliting and check is kind of implemented in RouterOS already.
You just need to call the "edit" command on a script to open it in the whole terminal window, where you have that. The syntax check stops at the first syntax error though, but still.
mrz
Tue Sep 10, 2013 3:40 pm
Or simply run /system script print.
skot
Long time Member
Long time Member
Sun Sep 22, 2013 2:26 am
Linux HowTo:
~/.vim/scripts.vim
" first line check
        setfiletype rsc
endif
unlet s:first_line
:arrow: To make it a little easier, you can also have Vim recognize scripts simply by the .rsc extension:
Add the folder:
mkdir -p ~/.vim/ftdetect
Create the file: ~/.vim/ftdetect/rsc.vim with contents:
au BufRead,BufNewFile *.rsc set filetype=rsc
Then you don't have to have the "# by RouterOS" comment in each script.
Kentzo
Long time Member
Long time Member
Fri Feb 14, 2014 12:36 pm
See http://forum.mikrotik.com/viewtopic.php?f=9&t=81868.
taduikis
Fri May 09, 2014 1:57 am
Does anyone have a syntax highlighting file (.stx) for EditPlus?
These guys seem to have it: http://bbs.routerclub.com/thread-70366-1-1.html
But their forum is closed for public registration and it's not possible to download attachments.. :(
The highlight scheme is not perfect, but it'd be okay..
JoeriBe
Wed Jun 04, 2014 12:05 pm
Anyone has it for textWrangler ?
Thx.
ofstudio
Sun May 15, 2016 4:43 am
RouterOS script syntax highlighting for Atom editor.
https://atom.io/packages/language-routeros-script
IntrusDave
Wed May 18, 2016 8:09 am
Thx.
+1 for this :)
ZEDA
Mon May 30, 2016 11:43 am
d
javierc
Thu Jun 02, 2016 1:29 am
Hi, I not understand this post... is possible open the script and edit directly from winbox with external editor as notepad++ or any other and check the sintax or always is needed download the file first and after upload again with each modification? I tried with ip smb but only see pub folder and the / folder but I not see the scripts, I see all files that I can see like in Winbox in menu files.
Please can you explain the process, please?
Regards
boen_robot
Thu Jun 02, 2016 2:24 am
When I said "open it in the whole terminal window" I meant it. You can't open the script in an external program, and have syntax highlighting there... Well, not natively at least. There are 3rd party add-ons for various editors in this topic, though they are - by virtue of not being in sync with an actual router - error prone (e.g. newer commands/arguments may not be recognized as valid OR there won't be any sort of validation check at all, which in turn limits the usefulness of the highlighting).
If you open up Winbox, click the "New Terminal" button, and from there, type "/system script edit scriptName source" (replacing "scriptName" with the actual name of the script), the terminal windows turns into an editor with syntax highlighting... A very inconvenient to use editor, but an editor still.
javierc
Fri Jun 03, 2016 12:59 am
Ok, edit option is better that the option in the script window, I think the winbox tool is very good and powerful so I do not think that will prove very complex and it would be much better if implemented to open the default editor windows or associate the user as do the ftp programs or other would be great.
Another option would be that there were scripts like other normal files, so be resolved by SMB like any file.
I was reading the link you say, is like I was doint with notepadd++ and the addon for router os code, so I understand the 3rd party add-ons you say is for copy the code in thats applications, edit and paste in the script windows, it is so or is possible install any addon in winbox to do it?
lukoramu
Thu Mar 23, 2017 7:32 am
Any suggestions how to syntax-highlight RouterOS scripts/configs in LibreOffice or MS Office documents ? :-)
Maybe someone have made a plugin for that? ..
Meanwhile, I'm using THIS post to syntax-highlight some RouterOS config, an then copy-paste it as "Formated text" into LibreOffice document :-)
# There was some code to highlight, but, turns out, it doesn't work that way..
# How in the hell it worked yesterday?? I really saw colored code in my LibreOffice, when I pasted it.. Hmm..
normis
Thu Mar 23, 2017 10:57 am
Don't use Libre or MS Office for code :D
I suggest Visual Studio Code, TextWrangler, Notepad++, Sublime, etc
sreed
Thu Jun 01, 2017 2:06 am
d
This is awesome.
I added dst-host, redirect-to, cache-path and owner as keywords.
alebu
Thu Jan 18, 2018 12:22 pm
I upgraded the old (2012) notepad++ highlitghter with a lot of new keyword (about tool, email, logging, package, ups, radius, capsman, etc, etc, etc,).
Unzip the xml file in your desktop and then in Notepad++ go to: Language->User Defined Language->Import
Close and reopen Notepad++
thanks to dtoffo for his initial work in 2012.
freecowz
Mon Feb 12, 2018 11:34 am
This is really useful - thank you!
Danny78
Tue Feb 13, 2018 1:02 am
Thank you very much!
Joni
Fri Mar 09, 2018 9:02 am
How about contributing the package too... https://notepad-plus-plus.org/contribute/
eworm
Mon Oct 12, 2020 5:13 pm
My editor of choice is vis - a modern, legacy free, simple yet efficient vim-like editor.
I added a RouterOS script lexer, that is now available in git master.
VitaliySte
syntax highlighting for Kate
Thu Jan 14, 2021 2:09 pm
Highlighting for Kate (editor in KDE5)
Create (if not exist) folder ~/.local/share/katepart5/syntax/ and place xml file there
RouterOS.xml
Restart Kate, than open Kate settings and in colors settings in style select RouterOS highlighting and import from file RouterOS.katehlcolor from archive
RouterOS.katehlcolor.zip
(unpack it before!)
You can set you own colors and text style also in this menu
dll2003
Thu Feb 25, 2021 5:34 pm
Hello everyone!
Maybe someone has already done syntax highlighting in UltraEdit?
If so, please share the .uew file.
Thanks.
robmaltsystems
Long time Member
Long time Member
Fri May 21, 2021 7:56 pm
Thanks for this - something I've wished for ages and here it is!
JimGrisham
Re: syntax highlighting for Kate
Wed May 26, 2021 11:45 pm
Create (if not exist) folder ~/.local/share/katepart5/syntax/ and place xml file there RouterOS.xml
Restart Kate, than open Kate settings and in colors settings in style select RouterOS highlighting and import from file RouterOS.katehlcolor from archive RouterOS.katehlcolor.zip (unpack it before!)
Thanks!
For anyone using Kate on Windows, put the RouterOS.xml file here:
%USERPROFILE%\AppData\Local\org.kde.syntax-highlighting\syntax\
(create org.kde.syntax-highlighting and syntax if they do not already exist.)
Reference for that file location:
(If you're looking to install the RouterOS.katehlcolor file on Windows, though, I can't help.)
jousedelano
Thu Apr 07, 2022 2:39 pm
Just use VS Code, someone has made an extension with highlighting. Ain't got time to reinvent the wheel
msatter
Thu Apr 07, 2022 2:47 pm
Which editor(s) do you use?
rextended
Thu Apr 07, 2022 2:56 pm
It act like a BOT:
"Ain't got time to reinvent the wheel"
WeWiNet
Long time Member
Long time Member
Thu Apr 07, 2022 5:39 pm
Atom with highlighting extension from ofstudio
Users browsing this forum: bias89, TosLin and 33 guests
