bakra
Redirecting IP Address
Fri Mar 09, 2012 12:02 pm
I hope this will be simple :)))
I need to redirect users who type www.test.com (or just test.com) in web browser, to be redirected to 192.168.x.x
thanks in advance :)
netWorm
Re: Redirecting IP Address
Fri Mar 09, 2012 12:27 pm
kirshteins
Fri Mar 09, 2012 12:28 pm
You can use this method: http://wiki.mikrotik.com/wiki/How_to_Bl ... sing_Proxy
You will need to specify redirect-to.
TheWiFiGuy
Fri Mar 09, 2012 1:34 pm
Could you not just set a static DNS entry?
bakra
Fri Mar 09, 2012 2:17 pm
perhaps I explained badly...
I installed forum on a local network PC (address: 192.168.2.33) and by typing this address in web browser you are entering this forum, but I want to change IP address with name (f.e. forum.com, this address already exists). So I thought, is it possible to drop request for "real" forum.com and redirect this request to 192.168.2.33 so by typing in web browser www.forum.com I could enter my forum which is in a local network (192.168.2.33).
bakra
Fri Mar 09, 2012 3:51 pm
This is exactly what I want to do.
So, you tell me how to do it.
If possible with CODE.
jackman
Thu Mar 15, 2012 10:53 am
As TheWiFiGuy, already mentioned. If this possible for you to set static dns entry on your RouterOS? And let the Client use RouterOS dns server?
In this case you could set static dns entry on winbox :
ip/dns
or look at
http://wiki.mikrotik.com/wiki/Manual:IP/DNS
Users browsing this forum: No registered users and 11 guests
