i have some devices that supports only some OID. they all are behind a low bandwith gateway. therefor i have to reduce snmp-traffic.
if i chose a snmp-profile for a device, dude creates automaticaly some requests about interfaces and standard snmp-oids. to switch them of i set snmp-profile to no-snmp. for monitoring some internal values i created data-sources with snmp-v1-public-profile. so far seems all ok.
To get some informations on limits i made some probes with v1-public-snmp-profile. if i set device profile to v1-public or v2-public the probe works. but if the device is on no-snmp the probe does not work even the data-sources on the same device do.
then i got a "local problem" status on this probes.
How can i use snmp-probes if i dont want to set entire device to snmp?
