Sure.I will test that it is working.
I'm not 100% sure what you meant, but we do not complain about low performance we're just testing. We know it's in beta. I was a bit disappointed to see that the CCR isn't really faster than the RB1100AH (at this point). I'm sure it will get better...This tell to less to conclude annything other than mikrotik is working to get a 100% systeem running. its still to be consider as a beta test system.
Mikrotik are furiously working away on a new routing engine that will make use of massively multicore architectures like the Tilera processors in the CCR.It looks like the load doesn't get balanced over multiple cores. This is what I suspected. It's too bad that we can't use the full potential of this CPU.
I'm running RC10 built on 15 Feb. and it definitely doesn't work in this version. I've got a Cisco and a Brocade router connected to this CCR and both session don't work with MD5." MD5 passwords don't work"
With latest RouterOS version MD5 should work
I thought it's because of that. But at some point I wasn't able to filter on routing protocol, etc. Only Dst. Address was visible. At the moment it works. Well, like I wrote above, I will update to the most recent version and keep an eye on this." MD5 passwords don't work"
"As soon as I get more than about 200k prefixes, the "Routes" windows doesnt show all filter options and routes"
It is made so that bandwidth is not flooded with enormous amount of winbox data to display route updates.
Hi razHi Mat,
thanks for sharing!
Your BGP Sessions are up with Fulltables? I plan to use Mikrotik in my Edge with 3x Uplinks, but i miss 10 GbE Support over SFP+.
But, if there was more corses to do the bgp. would it be speeded up? Whats really nice, is that each port, don't share internal recourses like the 1xxx series. 1Gig strigt into the core (kernel).Hi razHi Mat,
thanks for sharing!
I'm running one full table, one part table and one table from the local IX (~50k). The downstream router gets the "mix" of all tables.
But I don't see any problems to run 3 full tables. It's just a matter of ram and at the moment I've got ~3.25G free of the 4G installed in the CCR, so there's room to grow. If not, we could upgrade the ram.
I also think the CCR needs some more carrier grade features like I mentioned in another thread, but it's a platform with a lot of potential.
The only negative point I see so far is, that the CCR can only use one core to process BGP. Compared to a 1100AH or 1100AHx2 (which can also only use one core), it's not much faster if it's any faster at all. Sure, the positive side effect is that the packets running trough the CCR don't get delayed, which is what a carrier would expect from such devices, but it would be nice if the CCR could use multiple cores for BGP to speed up this process. If it could use a user configurable amount of cores would be awsome of course.
- Mat
Sure would it speed up the building of the routing table. Especially when more peers with full routing tables are connected to the CCR.But, if there was more corses to do the bgp. would it be speeded up? Whats really nice, is that each port, don't share internal recourses like the 1xxx series. 1Gig strigt into the core (kernel).
http://www.mikrotik.com/download/share/ ... .0rc14.npkWhere did You get RC14?
Why cant you use ccr for bgp? unless you need the vrf function, a "simple" ebgp is no deal for the ccr.Hello guys!
I just wonder if it's possible to run 2xBGP Full View with 100 Mbit each on RB1100AHx2? I have routing and NAT. For current 100M load cpu utilization is about 30%. Does full view increase CPU utilization and make impact for latency?
I need time until CCR became suitable for BGP production and don't want to feed cisco
Yesterday I replaced one of my BGP routers with CCR. So far everything runs smoothly, there are 7 peers, 3 full routing tables. I took the risk, because of full redundancy for this device, so if you have such possibility, I say try CCR now. Only problem I observed is with reboot, I wrote about it in CCR topic.Hello guys!
We see this too. It's because BGP runs on one core only.Do you also experience one core almost always at 100% load? How much does it take a route state-change to be applied? On my CCR (3 IPv4 full views and 3 IPv6 full views) it takes almost 20 minutes.
Yes, in fact above CPU graph is showing cores reaching 80% in a daily view, here they are averaged. Full route state-change depends on type of router on the other side of link. In my case there are 3 Quagga's, and this takes 1-3 minutes, it's pretty quick. But with Cisco routers used by my IP Transit provider it can take up to 5 minutes per link, sometimes quicker. So it's pretty close to what you experience, comparing it to Quagga, it's pretty much the same.Do you also experience one core almost always at 100% load? How much does it take a route state-change to be applied? On my CCR (3 IPv4 full views and 3 IPv6 full views) it takes almost 20 minutes.
no problemszastan, thank you for reply!
No, this is not a problem since traffic is ~equally divided between coresDoes one core full utilization makes influence on traffic flow?
It depends as some of nexthops are in same city, some are in totally different places. I guess what you ask is, is CCR causing higher latency than previous x86 system? The answer is: no.What is the latency to nexthop via your bgp router?
This 100% usage is jumping between cores and yes, all the time one core is 100% loadedIs one core have 100% utilization every time or for some times?
Unfortunately, yes. In my case (config above didn't change, only traffic went up to >500 Mbit / interface, ~3 Gbit full router passthrough) all routes are learned in about 5-10 minutes, and that occured on v6.3. Now on 6.7 once my router stuck on learning BGP routes for about an hour. No solution I'm aware of though.Hello
I have the same performance problem. Two BGP connection and a very long time rebuilding routing configuration. One of the core loaded to 100 percent. There is a some solution? currently I'm using version 6.4 of the software.
YesSorry to jump in last minute...
I am using 1000's and 1100AHx2's ..(just added in a CCr1036)
Is bgp still only being done on one core? Has Mikrotik addressed this?
Other 35 can do packet processing.If only one core can do the bgp process... the other 35 are not as usefull
also
1.2 like 1100AHx2Is there benchmarkes on the CCr cores? 1.2ghz ?
Of course. But be aware of stability ROS ox X86. I have very bad experiences with ROS runing on several different configurations. Mikrotik is always a lottery. You can win once something really good for cheap price, but then missed everything.If I can Build my own 4ghz quadcore it would perform much better.
