Zorker
Ubiquiti SR9 support
Fri Feb 24, 2006 12:28 am
Anyone know if the SR9 card is going to be supported by Mikrotik? (900Mhz Atheros)
http://ubnt.com/supper_range9.php4
I haven't seen anything on the forums regarding it.
eflanery
Fri Feb 24, 2006 2:02 am
It's been discussed around here, just search for sr9.
I think it's very likely that it will work fine, since it appears to be a standard Atheros AR5413 (same as the EMP/SMP cards, and I think the R52 as well), just with a custom RF stage.
--Eric
Giepie
Tue Mar 28, 2006 12:28 am
We've been using it on 5.8GHz. Working very well, being 400mw and all. It does get a bit more hot compared to a CM9 or normal Atheros card, but its worth having. It works on any 2.9.x ROS. (Haven't yet tried it on 2.8)
Regards, Giepie
eflanery
Tue Mar 28, 2006 12:42 am
Somehow I doubt that, it being 900Mhz and all. :wink:
(Not to mention that no one I know of has seen anything more than a prototype as of yet.)
--Eric
uldis
Fri Apr 07, 2006 5:39 pm
We have tested it and it is really working at 900Mhz. As I understant they are converting the 2.4Ghz to 900Mhz....
Next week we will test in real enviromet (few km distance) and then we will have some results.
For now we can get approx: 5Mbps using 5Mhz channel; 10Mbps using 10Mhz channel; 20-25Mbps using G mode; 7Mbps using B mode.
For now in the RouterOS to get is working you should use these frequencies:
2422Mhz -> 922Mhz
2427Mhz -> 917Mhz
2432Mhz -> 912Mhz
2437Mhz -> 907Mhz
It is a workaround for v2.9.x till the v2.10. In v2.10 you will be able to select the 900Mhz frequencies directly.
ericsooter
Fri Apr 07, 2006 7:29 pm
Wow, that is good news. Keep up the good work.
-Eric
cmit
Fri Apr 07, 2006 11:02 pm
Now if only we could use this in Germany ;) ...
Best regards,
Christian Meis
wildbill442
Fri Apr 07, 2006 11:22 pm
How about the SR3? Will support for that also be included in 2.10?
uldis
Mon Apr 10, 2006 1:47 pm
we haven't received the SR3 cards so we don't know yet.
ghmorris
Mon Apr 10, 2006 9:51 pm
2422Mhz -> 922Mhz
2427Mhz -> 917Mhz
2432Mhz -> 912Mhz
2437Mhz -> 907Mhz
I may be reading this wrong, but it seems the sequence of frequencies doesn't match between 900 and 2.4. 2.4 ascends, 900 decends.
Is this right?
George
uldis
Tue Apr 11, 2006 11:50 am
Correct.
taloot
Sun Apr 16, 2006 4:03 am
i m really want to know the range of the 900mhz NLOS, how many KM we expect if its NLOS, please plece your post guys
eflanery
Mon Apr 17, 2006 7:50 pm
As with all radios, NLOS performance will be entirely depend on what is causing the NLOS. Trees?, Buildings?, Hills?, Walls?, Multiple?, Thick obstructions?, Thin obstructions?, Fully blocked Fresnel?, 50% blocked Fresnel?, etc....
It is pretty much imposable to pre-determine NLOS performance, without knowing _exactly_ what is in the way. And even then, it isn't easy.
That said, 900Mhz will be better than 2.4Ghz at getting around things. Also OFDM helps compensate for multi-path, so in theory, it _should_ perform better than existing 900Mhz systems.
--Eric
taloot
Mon Apr 17, 2006 11:18 pm
ok in case of blocked fesantal zone 50% only
aviper
Tue Apr 18, 2006 2:02 pm
You've got the answer in the upper post.
Just buy equipment and test ... Nobody can say for sure.
taloot
Tue Apr 18, 2006 8:30 pm
i will but i m looking for estimation
example i have link @ 6mbps arround 12km @ 2.4ghz 200mw 20db antenna both sides
if i replace it with the 900mhz 700mw whats the expected speed i will got? if we consider my antenna is somthing like 15 db
taloot
Wed Apr 19, 2006 1:09 am
another word guys, can i install it from car to car?
ericsooter
Thu Apr 20, 2006 5:52 am
I'm thinking bicycle to bicycle might work.
taloot
Fri Apr 21, 2006 2:48 am
its not a joke u have to understand what i mean 1st
i sent e-mail for them to buy the SR9 a, waiting for the reply
sdrenner
Thu Jun 01, 2006 11:01 pm
I thought you said that after 2.9.10 you would select 900 channels
cmit
Fri Jun 02, 2006 1:26 pm
No, that was a "2.10", so the next major release...
Best regards,
Christian Meis
Hammy
Forum Veteran
Forum Veteran
Sun Jun 04, 2006 3:07 am
I'd recommend that they figure out everything ubiquiti plans on doing and supporting it, whatever it is.
Beccara
Long time Member
Long time Member
Sun Jun 04, 2006 3:51 am
Well that would be nice but back in reality UBNT is a PITA to deal with direct, getting support directly from them is a mission and i doubt they would be willing to hand out details of their plans to MT.
I know of a group of people in my country tring to get some samples on loan to test for a country wide deployment, all up they were looking at buying 10k unit's+ of SR2 and SR5's, UBNT took a month to reply to their phone calls or e-mails and then insisted that they buy 100unit's - needless to say the group didnt and looked at other options
jdmarti1
Mon Jun 05, 2006 7:39 pm
First of all - UBNT has been awesome to deal with as far as we were concerned. I do not know about your friends and what they were proposing, maybe there was some mis-communication, I don't know. Do you think that maybe they were trying to protect their dealer stucture that is in place? That is what a good company does. We have dealt with their support when MT was overdriving the SR2 cards. They were more than helpful, and helped to prove to MT that the problem was with them. They could have said it was MT's problem, and went on. They worked directly with MT to solve the issue. A rep from UBNT also occassional visits the forums to see about any comments that are made, to be proactive. You will see him post - although very rarely. His goal is to make sure the product is working properly - not increase sales. I have talked to him and have been very impressed with the company. I am not saying they are perfect, they have had troubles with production. Initially they did have some problems with a few cards, but they have corrected the issues. Try dealing with Engenious if you want to see PITA, they have no answers, and really don't care.
jarosoup
Long time Member
Long time Member
Tue Jun 06, 2006 3:04 am
I'm surprised that UBNT hasn't tested their cards with Mikrotik already (from another forum it's obvious they haven't)...seems like it'd help them get the word out.
Anyway, where are the speed, range, and overall tests and opinions people? Looking forward to hearing how these do in the real world. Want to try some out but kind of holding back to see how the first round goes.
Ubiquiti
Tue Jun 06, 2006 11:10 am
Beccara -- if it is true, I feel very embarrased as the president/founder of the company. Please e-mail sales@ubnt.com or support@ubnt.com anytime with what you need and reference this post. We'll make sure you are taken care of.
Sorry for the trouble.
Ubiquiti
sdrenner
Tue Jun 06, 2006 9:57 pm
Any ETA on 2.10? or at least a Beta?
Also when it comes out will there be more channels to use?
normis
Wed Jun 07, 2006 8:48 am
which more channels do you want? we already support all channels that card can give you.
beta of 2.10 is planned for end of summer
interexus
Unable to get SR9 to work
Thu Jun 08, 2006 7:40 pm
Can someone that has the SR9 working please send me a basic config so I can test distances.
sergejs
Fri Jun 09, 2006 8:48 am
interexus,
Uldis already wrote about frequency configuration, as well sticker is provided with SR9 frequency chart explanation.
You have to set correct frequency channel, and other configuration is the same as for regular a/b/g links.
interexus
Fri Jun 09, 2006 3:39 pm
Yeah I have tried that, but for some reason I don't see the other side. The two units are less then 10 feet apart.
sdrenner
Fri Jun 09, 2006 4:23 pm
Well how about the ablity to select any of the channels not just 4.
Here are just a few thoughts.
900
901
902 5Mhz Ch
903
904
905 10MHz Ch
906
907 Now
908 5Mhz Ch
909 20Mhz Ch
910 or 20 MHz ch
911 or 20 MHz ch
912 Now 10MHz Ch or 20 MHz ch
913 or 20 MHz ch
914 5Mhz Ch or 20 MHz ch
915 10MHz Ch or 20 MHz ch
916 or 20 MHz ch
917 Now or 20 MHz ch
918 or 20 MHz ch
919
920 5Mhz Ch
921
922 Now
923 10MHz Ch
924
925
926 5Mhz Ch
927
928
jsuter
Sun Jun 11, 2006 3:53 pm
You do realize the "free" band starts at 903, not 900.
I've found this page very informative about who's-using-what:
http://www.jneuhaus.com/fccindex/spectrum.html
surfnet
Tue Jun 20, 2006 4:07 pm
so I just got my SR9 and have been playiong around.
When I put the unit right next to each other I get great signal and get great throughput.. around 24meg UDP.
When I take them about 25 feet apart into another building.. IT falls to pieces and I can barely keep a connection, with ping times in the 500+ range
My noise floor for all channels is around -78.. uhg..
I use 900 canopy in other palces.. but the interface sucks.. I want MK!!
I also have a Avlan 900 P-t-P setup and that works perfect.. but it is only p-t-p
I am using 9db yagi antennas and mini-itx board that work great with any other cards.
My card is set to B/G
I played with all 4 channels
2422
2427
2432
2437
2437 was the only channel that I could maintain a connection but I cant get any ping across
what does this mean
-----------------For now we can get approx: 5Mbps using 5Mhz channel; 10Mbps using 10Mhz channel; 20-25Mbps using G mode; 7Mbps using B mode.-----------
Im alittle confused.. I thought we were in 900mhz space? THis makes me think we should treat it like B or G in which case I can say that B always seems to work better than G for outdoor long range shots.
SHould I set it to B and have 11meg bitrate?
uldis
Wed Jun 21, 2006 9:52 am
Which band have you tried? Try out 5Mhz band or 10Mhz band.
What antennas are you using?
surfnet
Wed Jun 21, 2006 3:17 pm
I tired all the different bands, and the only one that would work at the 25t distance was B.
THe noise floor is a bit concerning, I took the unit and drove it all through the mountains with no antenna plugged into it and my noise floor never changed from around -80.. it went as low as -83 and as high as -78.
this noise floor seems like it would make it impossible to work at any distance. the SNR would just be to bad.
the card is rated to goto -93
Is the noise floor reading perhaps wrong?
Hammy
Forum Veteran
Forum Veteran
Wed Jun 21, 2006 4:39 pm
Are there paging towers nearby? Your card just could be faulty as well.
surfnet
Wed Jun 21, 2006 8:46 pm
I have 3 card in 3 different boxes
1 Wrap
1 RB500
1 Mini-itx
I drove the unit through the mountains and down to town. I think the noise must change in a 15 mile drive into valleys and such. and for this test no antenna was connected.
Also I have a Avalan 900 p-t-p that works perfect and a Motortolla canopy that works. So that makes me think that if it was noise then those would not work either
In my drive I covered 15 miles and went from 2500ft elevation down to 500ft elevation. Im sure the noise should have changed somewhere in there if it wa a pager 900 tower.
ghmorris
Wed Jun 21, 2006 11:07 pm
1 Wrap
1 RB500
1 Mini-itx
You are shooting yourself in the foot. Connect an antenna and get the radio/antenna out of your vehicle into the open air. Your mileage will improve and your life will become golden.
Wandering around with 27dB radios with no antennas is not a good idea.
George
surfnet
Wed Jun 21, 2006 11:10 pm
when only checking for noise.. having no antenna is the best way to see the local noise
an antenna will only make it more
ghmorris
Wed Jun 21, 2006 11:30 pm
Hmmm. Don't think I'm going to bite on that one, so that would suggest the main difference between us right now is that I have a working 5.4km SR9 link through fairly heavy trees and an obstructed fresnel and you have a radio with no antenna attached? :P
George
surfnet
Wed Jun 21, 2006 11:32 pm
that is great you have a link up.. what is your config????
please could you let me know your exact setup :)
what is your noise floor?
what is your signal and SNR?
ghmorris
Wed Jun 21, 2006 11:58 pm
I just happen to have a little data. This is an area with a lot of Trango and WaveRider 900 operating.
This is a production shot we set up June 13th, 5.4km or a little more than 3 miles long. Been running like a top ever since. RSSIs drop about 4dB in the rain, which considering the number of trees its going though seems about right. Throughput is about 3Mbit in each direction or 1.5 in both at once.
This shot is across water and treed land. Tree heights are 20-30M.
The customer, Donelda, has about 30M of trees from her house to where the land drops off down to the lake. This is dense deciduous forest crowns. In addition, the lower half of the Fresnel is obstructed by trees growing on two ridges between the customer and the AP.
frequency: 2437MHz
tx-rate: 24Mbps
rx-rate: 24Mbps
ssid: "CandleLL"
bssid: 00:15:6D:90:02:70
radio-name: "LL 900 120 H Sec"
signal-strength: -74dBm
tx-signal-strength: -76dBm
noise-floor: -88dBm
signal-to-noise: 14dB
tx-ccq: 57%
rx-ccq: 72%
p-throughput: 20968
wds-link: no
nstreme: yes
polling: yes
framing-mode: none
routeros-version: "2.9.23"
last-ip: 10.20.115.11
802.1x-port-enabled: yes
authentication-type: none
encryption: none
compression: no
current-tx-powers: 6Mbps:28,9Mbps:28,12Mbps:28,18Mbps:28,24Mbps:28,
36Mbps:26,48Mbps:23,54Mbps:21
notify-external-fdb: no
status: running
duration: 9s
rx-current: 3.2Mbps
rx-10-second-average: 3.3Mbps
rx-total-average: 3.3Mbps
random-data: no
direction: receive
status: running
duration: 41s
tx-current: 3.1Mbps
tx-10-second-average: 3.0Mbps
tx-total-average: 3.0Mbps
random-data: no
direction: transmit
status: running
duration: 16s
tx-current: 1783.9kbps
tx-10-second-average: 1684.3kbps
tx-total-average: 1681.8kbps
rx-current: 1783.9kbps
rx-10-second-average: 1695.8kbps
rx-total-average: 1707.9kbps
random-data: no
direction: both
AP is an RB532 with SR9, customer is a RB112 with SR9. It has been running June 13th with zero problems so far. Its running on horizontal polarity, Superpass 9dB horiz 120* sector to M2 17dB yagi.
We are very pleased!!
George
surfnet
Thu Jun 22, 2006 12:08 am
wow that is great to see.. I see your noise floor is around -88. The card specs at -93 so that is a little high.. but I am encouraged to just go out and set mine up and see how it goes.. thanks so much for the info
one question though.. what band did you choose? that is not noted in yoour config
ghmorris
Thu Jun 22, 2006 12:19 am
In reality, if you can find a noise floor as good as -88 in the 900 band you are doing REALLY well. We are just lucky here and are using horizontal which eliminates much of the V-pol noise that is ubiquitous in 900, pun intended.
Here are the full radio card configs. We are using 2GHz-5MHz channels.
name="wlan2900HSec" mtu=1500 mac-address=00:15:6D:90:02:70 arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name="LL 900 120 H Sector" mode=ap-bridge ssid="CandleLL" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=2437 band=2ghz-5mhz scan-list=default rate-set=configured
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power=28 tx-power-mode=card-rates
noise-floor-threshold=default periodic-calibration=default
periodic-calibration-interval=60 burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=no
allow-sharedkey=no
name="wlan2LilyLake" mtu=1500 mac-address=00:15:6D:90:02:6D arp=enabled
radio-name="Donelda" mode=station ssid="CandleLL" area=""
allow-sharedkey=no
George
surfnet
Thu Jun 22, 2006 12:21 am
awesome!
I will post my results when I get them in place :)
ghmorris
Thu Jun 22, 2006 12:24 am
awesome!
Best of luck!! I will be really interested to hear how you get on.
George
uldis
Thu Jun 22, 2006 10:13 am
Haven't you tried to increase the data-rates up to 54Mbps or it is not so stable at these rates?
ghmorris
Thu Jun 22, 2006 12:45 pm
This really isn't a beta topic any more, I've moved the reply to Wireless Networking.
"Thoughts on 900MHz tactics in an MT/Ubiquiti SR9 world"
miahac
Long time Member
Long time Member
Mon Aug 21, 2006 6:03 am
with more channels, why not 90 degree sector to reduce noise?
Users browsing this forum: Amazon [Bot], Google [Bot] and 143 guests
