andriys
Re: New Packet flow diagram
Fri Mar 28, 2014 11:14 am
I propose to consider another option
Awesome!
What diagramming tool did you use?
noviy
Fri Mar 28, 2014 12:53 pm
Fixed small bug
noviy
Fri Mar 28, 2014 1:49 pm
For preview:
efaden
Fri Mar 28, 2014 2:37 pm
For preview:
Nice... PDF or SVG or some sort of vector image would be ideal. Looks great though.
noviy
Fri Mar 28, 2014 3:25 pm
See my previous post.
tomaskir
Trainer
Trainer
Fri Mar 28, 2014 3:42 pm
Any chance for an editable version?
Thanks!
efaden
Fri Mar 28, 2014 4:13 pm
Thanks!
+1
noviy
Sun Mar 30, 2014 12:31 pm
Some changes, for a better understanding of travel of packets.
Fixes:
2014.04.05
- Corrected position 'IPSec Decryption' and 'IPSec Encryption' boxes in ROUTING (gratitude: macgaiver);
- Fixed form blocks 'Bridge Decision' in 'Forward' and 'Output' Chain.
2014.04.10
- Added "Configurable Facilities": Menu items of RouterOS corresponding function blocks;
- Corrected name of block "Decapsulation
(TE, VPLS, VLAN, Tunnel)" to "Encapsulation (TE, VPLS, VLAN, Tunnel)" in "OUT-INTERFACE
LOGICAL" line;
- Corrected name of block "Bridge Adjustm." to "Routing Adjustm." in "Output" chain (gratitude: greek);
- Corrected bloks in "Input" and "Postrouting" chains: "Global HTB" > "HTB Global | Queue tree", added "Simple Queues" (gratitude: greek);
P.S. I am also willing to listen to any comments and additions.
macgaiver
Fri Apr 04, 2014 2:38 pm
Nice one - very informative. Just "IPSec Decryption and Encryption boxes need to be swapped - traffic comes to router and in case it is IPSec it will have policy and will be decrypted, not encrypted
and when leaving if there is IPSec policy it will be encrypted - this fix was also done on the wiki:
http://wiki.mikrotik.com/wiki/File:Pack ... m_v6_b.svg
noviy
Sat Apr 05, 2014 7:21 pm
Thank you, fixed - see updated my post.
greek
Tue Apr 08, 2014 9:59 pm
Why last block in output chain is "Bridge Adjustm"?
In original scheme it's "Routing Adj."
And why "Simple queues" blocks is absent in "Input" and "Postrouting" chains ?
noviy
Thu Apr 10, 2014 2:01 pm
Fixed - see updated my post
Thank you!
normalcy
Sat Apr 12, 2014 10:46 am
This is fantastic. Thanks for the effort as I think this layout helps you connect the layers together better than the original separated diagrams. Hopefully it becomes the official one.
noviy
Mon Apr 14, 2014 12:25 pm
To me the first version of diagrams is easier to consume. Second version is a little bit noise. There is too many arrows. Main content is hidden in the web of transitions! Arrows that define logical layers is too big, it's not the main content.
You can download the source in Microsoft Visio 2010 and disable the extra layers, making it easier diagrams at its discretion.
normis
Thu Jun 19, 2014 2:33 pm
noviy, can we use it in the MikroTik Wiki manual ?
greek
Fri Jun 20, 2014 12:42 am
Why first and last figures in output chain are not a parallelepiped as in original scheme?
As i know, parallelepiped has concretic mining in flowchart http://en.wikipedia.org/wiki/Flowchart
noviy
Sun Jun 22, 2014 1:56 pm
Yes, of course! I'll be glad if it will be useful for Mikrotik project.
avenn
Fri Jun 27, 2014 11:44 am
Excellent thank you for this diagram. I have just got back from a MTCRE course in sunny England and it was causing a positive buzz! Loving it! :D
Regards
Aidan Venn
qwertysqwerty
Sun Jun 29, 2014 7:17 pm
Excellent work. Very useful indeed!
Thank you.
nest
Forum Veteran
Forum Veteran
Tue Jul 15, 2014 1:18 pm
noviy - can you get in touch with us as we would like to print these professionally as posters? :) Email me at shop (at) linitx.com
dendlet
Tue Dec 02, 2014 11:22 am
The new diagram is really good.
It is clearer than the previous diagram.
Buster2
Fri Dec 26, 2014 4:51 am
Nice comprehensive graphics!
May I suggest to stick with english grammar rules for questions: auxiliary verb, then subject, then verb
Decapsulation is needed? -> Is decapsulation needed?
Encapsulation is needed? -> Is encapsulation needed?
It's IP Traffic? -> Is it IP traffic? ("It is IP Traffic" is a statement, not a question)
These changes would give decisions a consistent wording.
noviy
Sun Dec 28, 2014 9:54 am
Thank you for your comments! In the near future I will try to fix it.
b1863515
Fri Jan 09, 2015 10:48 pm
I guess you pros can understand the packet flow but I don't :(. Is there a book or a link that would explain what is actually happening in the individuals steps?
Chupaka
Sat Jan 10, 2015 10:21 am
check http://wiki.mikrotik.com/wiki/Manual:Packet_Flow
b1863515
Sat Jan 10, 2015 2:09 pm
Thanks!
yxudous
Wed Mar 16, 2016 5:24 pm
Trying to implement your double qos suggestions for hotel. I want to proritize traffic in queue tree and limit per user with dynamic simple queues. I can generate the simple queues in dhcp lease but what happens if a customer sets his own static ip? How can I generate his queue so that he does not bypass the limits?
Chupaka
Fri Mar 18, 2016 2:22 pm
1) authorization
2) just create a queue for 'everyone else' (10.0.0.0/16) with hard limits :)
alexkhokhlov
Fri Mar 25, 2016 12:37 pm
I have a clarification question regarding the order of mangle and routing processing of the "output" chain.
I want a script on my router to connect to a fixed-ip website via a predefined WAN connection (in order to get my external ip on that connection).
The set-up is the following:
  1. mikrotik 951G-2HnD v6.34.3
  2. two WAN connections on ethernet ports: first is a default (higher priority in routing), second is a failover (lower priority in routing)
  3. my ip-firewall-mangle rules section contain a rule on "output" chain to mark a non-marked connection to a fixed-ip destination
  4. my ip-firewall-mangle also contain a rule to place a routing mark on all marked connections to a failover WAN (via routing table)
All is working perfectly as planned.
However, according to http://wiki.mikrotik.com/wiki/Manual:Packet_Flow_v6 the output chain does not go through a "routing decision" block (K->L flow). The absolutely fantastic new diagram in this thread also shows that local "output" block with "mangle-output" is located after the "routing decision" block (also K->L flow).
My setup clearly shows that mange-output is before "routing decision" block since routing mark changes the flow to a failover WAN connection (non-default in routing table). Without my mange rules connection goes to a default WAN connection.
And my questions are:
  1. Is it really correct on the diagrams that "output" block from local output is placed after a "routing decision" block in the flow?
  2. Is there a single-mangle-rule solution to mark all traffic (local and forwarded) going to a fixed-ip with a connection/routing mark? [I now have two identical mange rules: one for "output" and one for "prerouting"]
EDIT: is it a "routing adjustment" that actually works in my set-up? Is it not better simply to have a "routing decision" after the "output" block? Why this design decision was made?
NicolBolas
Mon Apr 25, 2016 1:11 pm
Is there any detailed diagram to show how VRFs are processed ? I'm missing something here to fix my inter-VRF tunneling setup.
Thanks !
greek
Fri Sep 23, 2016 10:06 pm
Where is placed "IP - Firewall - Raw" menu ?
Chupaka
Mon Oct 24, 2016 2:31 pm
Guys?..
nest
Forum Veteran
Forum Veteran
Mon Oct 24, 2016 3:12 pm
Exactly where MikroTik said they put it. Just here...
Chupaka
Mon Oct 24, 2016 3:18 pm
Nice joke, thanks. But the topic is Packet flow diagram, not WinBox ;)
mrz
Mon Oct 24, 2016 3:38 pm
It's in the wiki
sergejs
Mon Oct 24, 2016 3:39 pm
RAW is taking action just before two connection tracking boxes in the Packet Flow diagram.
busla
Tue Nov 08, 2016 12:56 pm
As described in the diagram RouterOS must apply dst-nat rules before filter rules. But it does not. Why?
Chupaka
Tue Nov 08, 2016 2:34 pm
it does. explain your problem in details
busla
Tue Nov 08, 2016 5:03 pm
I have service at 192.168.0.2:12345
I added the rule:
ip firewall nat add chain=forward action=dst-nat protocol=udp port=12345 to-addresses=192.168.0.2 in-interface=ether1 log=yes
but the log remains empty
Dst-NAT rule doesn't work when it isn't allow rule in input chain of filter:
ip firewall filter add action=accept chain=input in-interface=ether1 protocol=udp port=12345 place-before=3
According to the diagram packet in general can not get into the INPUT.
nest
Forum Veteran
Forum Veteran
Wed Nov 09, 2016 8:37 pm
busla
Please create a new topic, this conversation is not in any way related to this "New packet Flow Diagram" topic. Thank you.
busla
Thu Nov 10, 2016 11:07 pm
busla
Why?
I create rules based on packet flow. Rules don't work. Either the diagram is wrong or diagram need some comments.
Quared
Trainer
Trainer
Fri Nov 11, 2016 1:28 am
@busla:
this thread about the new packet flow diagram was started 3,5 years ago and packet flow management is a central feature of routers in general
Do you really think, your problem now relates to this packet flow diagram itself ?
Please try to understand the packet flow diagram by reading appropriate information - either here in the wiki or by searching Google.
Your problem is knowledge- and config-related.
I second nest (Ron) => open up a new forum thread, thank you
greets
busla
Fri Nov 11, 2016 10:16 am
The diagram is a part of wiki. I have studied it.
My sample is a sample, not a problem. I want to know a real 'paclet flow' in RouterOS. It solve all my problems.
Chupaka
Fri Nov 11, 2016 2:55 pm
The wiki shows 'real' packet flow. Point.
nichky
Tue Dec 27, 2016 7:32 am
is there any MUM presentation about v6?
noviy
Wed Mar 15, 2017 3:15 pm
This small update with possible can someone help better understand the place of new blocks "RAW Prerouting" and "RAW Output".
download/file.php?mode=view&id=27228
Nemiroff84
Tue Mar 21, 2017 8:56 am
[quote="noviy"][/quote]
Can you place the diagram in visio format too?
bajodel
Long time Member
Long time Member
Thu Dec 21, 2017 4:45 am
@noviy
I noticed only now your 2017/03 diagram update (I know, I'm late :lol: ) .. but I want to thank you for the brilliant work!! Now with new details and raw tables is really complete.
( & "UP" ..many others may have missed it)
NoobJambon
Sat Mar 23, 2019 12:43 am
Hello guys !
I'm looking at those packet flow diagrams and the exemple scenario and I was wondering : where does the traffic originating from the router itself appears ?
For example let's say I bind a dhcp-client to a vlan interface, what would be the path of a DHCP Request packet on those diagram ?
BRMateus2
Sat Mar 23, 2019 1:17 am
Hello guys !
Router originated packets are always output->postrouting.
Look at, where input are packets targeted exclusively to router (or not-NATted for example), and output are exclusively outgoing originated from router.
https://wiki.mikrotik.com/images/2/2f/Pfd.png (https://wiki.mikrotik.com/wiki/Manual:Packet_Flow)
Users browsing this forum: davidvanrensburg, eworm, HansHolgersson, patrikg, sebi099, woland and 92 guests
