Need yours help, about two months ago I bought RB2011UAS-2HnD-IN
(and began to learn, and this is my first router MikroTik),
I configured the router until yesterday everything worked fine until
users have started to copy itself wirelessly large files size of ~ 1GB or more
(now I'm using ROS v6.0) so:
With LAN upload files to a laptop with a large size such as 1 GB 1.5 GB ...
on any connection speed on a laptop, the router begins to heat up,
it can be seen from WinBox "System-> Health" first temperature of 35 degrees Celsius
(normal operating temperature), then it is heated to 47 degrees and restart,
sometimes it occurs between 47 and 55 degrees, and it happens on this router
only when the transmission over a wireless connection, it heats up and reboots,
and so constantly, not just download something large through a wireless network,
but when receiving, all right, even with different file size, temperature 34-36 C
with This router and it works fine!
So this is the reason "RouterOS", if I bought a router and a production flaw?
Please help understand this situation, because some clients can not download the files,
because the router is constantly heated and restarts!
Sorry, english is not the best, I'm just learning
