InoX
RB951Ui-2HnD with external antennas
Sat Sep 28, 2013 7:51 pm
http://i.imgur.com/d6i7AHO.jpg
http://i.imgur.com/zhGQS7q.jpg
Signal is excelent through 2 concrete walls (-51 on android phone) and also higher than an standard RB951Ui-2HnD with 2-5dbi. With standard tplink 841 signal was very poor and loose conectivity very often.
This is just a testing projects, maybe someone needs this infos.
djdrastic
Re: RB951Ui-2HnD with external antennas
Sat Sep 28, 2013 9:54 pm
I assume a solder job ? Good job , looks pretty solid.
ohara
Re: Odp: RB951Ui-2HnD with external antennas
Sat Sep 28, 2013 10:08 pm
Nice
InoX
Sat Sep 28, 2013 11:42 pm
Solder pigtails, and also a thin piece of steel plate on the antenna side. Also I'm proud to see that wireless sped is 98mbps on an online speedtest.
honzam
Sat Sep 28, 2013 11:48 pm
see us photo from inside :) thanks
c0d3rSh3ll
Long time Member
Long time Member
Sun Sep 29, 2013 9:31 am
+1
I have a rb751U-2hnd and I want add a external antenna for more gain.
InoX
Sun Sep 29, 2013 9:02 pm
Can't do. Ruter is already sold.
Elgro
Sun Oct 20, 2013 11:15 am
InoX, please show me photos of the inside boards (antenna connection)
kasus
Thu Nov 21, 2013 10:27 pm
Hi, can you make a little manual where to solder connectors on the pcb?
sch
Fri Dec 06, 2013 4:52 pm
Can you post some more pictures and manual ?
b3h3m07h
Sat Dec 28, 2013 3:09 am
+1 for some photos. I would like to do this to one i have to get a little extra range :)
almaFia
Sun Apr 27, 2014 4:40 am
Why you can't it's easy to do?
I think this use that part for solder or install for two external antennas left and right. I will try to do it for my RB951Ui-2HnD. Then I post new subject for my test to know how to do that.
c0d3rSh3ll
Long time Member
Long time Member
Sun Apr 27, 2014 6:36 am
http://forum.mikrotik.com/viewtopic.php ... 49#p335449
sent from my mobile phone using tapatalk
almaFia
Mon Apr 28, 2014 12:45 am
This model is completely different .. but this model RB951Ui-2HnD works I try it.
DmitryAVET
Fri Apr 03, 2015 1:13 am
Mikorist
Mon Aug 31, 2015 2:52 pm
that is nice !
i have mine working like this over year without issue .
best result if is distance between two MIMO antennas are about 12.5cm ;)
wavelength is about 12.5cm for 2.4 GHz.
you can remove Integrated antennas (there is no need to be 4 antennas)
especially if you put all in the metal box on the roof. :D
DmitryAVET
Fri Sep 18, 2015 12:59 am
Internal is disabled )
use capacitor ;-)
robertEIT
Thu Dec 01, 2016 7:42 pm
Hi guys,
I also did the mod on my recent RB951Ui-2HnD,
Took the pigtails from a dead TP-Link 941nd and soldered them on the unpopulated (ufl?) connector pads, and moved the small (pain the arse) capacitor on the right track at the Y circuit trace.
I'm currently testing it with 2x10 dbi antennas from Qoltec but I don't see very much improvements, not as my other RB951G-2HnD wich is insane in terms of signal strenght and range compared with the default integrated 2.5 dbi ones. I'll try other antennas I have lying at my lab.
Any tips for what wifi settings would help?
Here are some pics (I know, it looks savage, but I don't care about the looks)
https://postimg.org/gallery/wzq72ceo/
null31
Fri Dec 23, 2016 10:37 pm
Hi.
Yesterday, i did the mod in two rb951ui, using pigtail u.fl to rp-sma. It was necessary to remove both internal antennas to get the real value of signal.
I compared it with another router and signal is the same through three walls and 16 meters from the Access points (d-link dap-2310 and RB951ui-2hnd with ROS 6.37.3).
Has a print screen from my phone that demonstrate how was the signal strength.
The pigtails have a length of 11cm each.
Here is some prints from mod and App Wifi Analyzer: https://imgur.com/a/GMNP2
