joegoldman
Forum Veteran
Forum Veteran
CCR1072 Availability
Fri Jun 20, 2014 9:03 am
Hi Forum,
Hopefully looking for a staffer to answer this one, but with the release of CRS226-24G-2S+RM, very keen to get these + the CCR1072-12S+ (which I believe is the reported format).
CCR1072 at the core with 10gbit uplinks to switching, all mikrotik, would be absolutely sweet.
I'm also keen to know if CRS ranges with only SFP/+ ports are expected to be released? Or is it not possible to get the SFP ports into switch chips?
I have a big fitout for a new ISP coming soon and I'd like to make it Mikrotik throughout but need all these devices available to do it! :D
snons
Re: CCR1072 Availability
Thu Jul 03, 2014 9:03 pm
https://www.facebook.com/pages/Mikrotik ... n=timeline
72-CORE powerful mikrotik Router will be released in Quarter 3 of this year...
The model is CCR1072-1G-8S+
It will have the following:
- 72 cores at 1.2 GHz.
- 16GB ECC DRAM,
- 8x 10Gb SFP+ ports,
- 1x 1Gb RJ45 port,
- Up to 80Gbit/s throughput,
- dual power supplies,
- Smartcard,
- color touchscreen LCD,
- RouterOS L6
Whatta a good idea if the 72-core processor will be used in smartphone too...
phuang3
Fri Jul 04, 2014 4:22 am
8x 10Gb SFP+ ports !!! Wow...
johnvam
Fri Aug 08, 2014 11:45 am
Any estimated release date?
normis
hopefully this year
TLoecher
Wed Sep 17, 2014 6:06 pm
Normis,
Regarding the dual power supplies, will there be DC options? Or only AC?
mspeed
Fri Dec 05, 2014 6:19 am
I'm waiting to purchase a large quantity of CCR1072-1G-8S+ .. any chance we'll see them before year end?
keefe007
Tue Jan 27, 2015 5:23 am
I guess not
MusicCog
Mon Mar 02, 2015 11:16 am
Any ETA yet?
johnvam
Wed Apr 01, 2015 6:54 pm
Any update?
doneware
Trainer
Trainer
Thu Apr 02, 2015 11:20 am
Any update?
The ones displayed at MUM Prague were "production" ones. whereas the black one previously was a prototype.
as far as i remember, Janis said they needed to change something in the hw, so they need to re-run, and after this they can announce the final price. not even the distributors have any insight on the price, nor on the ETA.
sodMetaldream
Sat May 02, 2015 4:58 pm
You can't be serius! A product this potent MUST! have dual power inputs. How can't you locate this beasts in redundant A+B powers racks otherwise?
Is this something you are considering?
alexjhart
Tue May 05, 2015 4:41 pm
sodMetaldream, it does have dual power supplies. They are removable too.
chechito
Thu May 07, 2015 10:55 pm
i think without rOS v7 will be no CCR1072, the multicore limitations of rOS v6 will be a problem on 10 gigabit interfaces
alexjhart
Thu May 07, 2015 10:57 pm
While I agree v7 will be a great improvement, 1072 can exist without it. Although, they might both end up landing around the same time anyway.
paoloaga
Fri May 08, 2015 3:18 pm
Unless there are hardware bugs, I think it would be worth to release the 1072.
We could already place it in future-proof installations. For example, now I am delaying several tasks waiting for the 1072.
It could be possible to install it anyway keeping in mind that it may not reach full performances until v7 will be available.
paulct
Wed May 20, 2015 2:16 pm
*sniff* *sniff* I need 4 please soon! Really hard to upgrade to a 10Gbps network without these
spectrasurf
Sat Jun 13, 2015 4:35 am
Any word on this??
We need to buy some ASAP. Otherwise will have to buy Crisco... :-(
mhugo
Tue Jun 16, 2015 12:01 pm
I would also say it would be ok for us if the 1072 was released with ROS 6 and have performance limitations. We are delaying builds where we would like to place 1072s to make it futureproof.
Clbh
Tue Jun 16, 2015 3:25 pm
When I asked Janis about CCR1072 availability at the AU MUM, he reckoned it was 2-3 months away at most. That puts us in the July-August range if he turns out to be correct.
Apparently Mikrotik had to redesign the SFP+ interfaces because they found that older modules would not function properly in them (they apparently were originally designed to some newer standard that was a bit over-ambitious?).
Anyways, I'm just going off what I recall..
In other words, it's not a ROS 6.x vs ROS 7.x thing. They will definitely release the CCR1072 on ROS 6.x without any problem.
temenug
Wed Jun 24, 2015 10:54 pm
I would like to understand if someone knows that will be possible SFP+ ports of CCR1072-1G-8S+ to support SFP (1.25G) modules like CCR1036-8G-2S+EM does (Supports both SFP (1.25G) and SFP+ (10G) modules).
It will be great if device has release in July.
43north
Thu Jul 02, 2015 8:18 am
honzam
Thu Jul 02, 2015 2:17 pm
i4jordan
Fri Jul 10, 2015 4:01 pm
It has arrived!
http://routerboard.com/CCR1072-1G-8Splus
Pricing is fair US$ 3050
StubArea51
Trainer
Trainer
Fri Jul 10, 2015 5:46 pm
Here is a review of the CCR1072 with pics (based on the pre-production model). Production pics are coming soon.
http://www.stubarea51.net/2015/07/10/mi ... use-cases/
sterling
Sun Jul 19, 2015 1:44 am
I need one or two of these.
Does anyone actually have one yet I can actually buy right now?
Or is this just wishful thinking for another three months?
StubArea51
Trainer
Trainer
Sun Jul 19, 2015 2:53 am
check with Tom @ roc-noc.com.
StubArea51
Trainer
Trainer
Sun Jul 19, 2015 2:55 am
Preview of our BGP testing on the CCR1072-1G-8S+
1.69 Million routes in under 3 minutes from 4 peers :-)
http://www.stubarea51.com/2015/07/18/mi ... e-preview/
StubArea51
Trainer
Trainer
Sat Jul 25, 2015 4:29 am
Here is Part 2, which is the full BGP review on the CCR-1072-1G-8S+. Enjoy!
http://www.stubarea51.net/2015/07/25/mi ... rformance/
andersonlich
Tue Aug 25, 2015 2:13 am
Is it support using sfp-optic 1ge or sfp-copper 1ge on the sfp+ port ?
It has arrived!
Users browsing this forum: Bing [Bot], sch and 109 guests
