mynetname.net is provided by MikroTik. All it does is maps this DNS name to your public IP address. It has nothing to do with VPN at all.
You must allow VPN connections in your router firewall and do proper configuration for the server and profiles.
Ok, Could you please help me in configuring my hap ac lite router...
This is the configuration :
[admin@Router] > export hide-sensitive
# mar/17/2016 13:32:11 by RouterOS 6.34.3
# software id = xxxxxxxxx
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf
name=bridge
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] disabled=yes master-port=ether2-
master
set [ find default-name=ether4 ] disabled=yes master-port=ether2-
master
set [ find default-name=ether5 ] disabled=yes master-port=ether2-
master
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-
width=20/40mhz-Ce \
country=indonesia disabled=no distance=indoors frequency=auto
hw-retries=4 \
mode=ap-bridge ssid="@net ( b/g/n )" wireless-protocol=802.11
wps-mode=\
disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-
width=20/40/80mhz-Ceee \
hw-retries=4 \
mode=ap-bridge ssid="@net ( a/n/ac )" wireless-protocol=802.11
wps-mode=\
disabled
/ip neighbor discovery
set ether1 discover=no
set bridge comment=defconf
set [ find default=yes ] authentication-types=wpa2-psk eap-
methods="" mode=\
dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.102.2-192.168.102.100
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=wlan2
/interface l2tp-server server
set authentication=mschap2 enabled=yes max-mru=1460 max-mtu=1460
use-ipsec=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=192.168.102.1/24 comment=defconf interface=ether2-master
network=\
192.168.102.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no
interface=ether1
add address=192.168.102.0/24 comment=defconf gateway=192.168.102.1
netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.102.1 name=router
add chain=input comment="defconf: accept ICMP" protocol=icmp
add chain=input comment="defconf: accept establieshed,related" \
add chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=drop chain=input comment="defconf: drop all from WAN" in
-interface=\
ether1
add action=fasttrack-connection chain=forward comment="defconf:
fasttrack" \
add chain=forward comment="defconf: accept established,related" \
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=\
invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-
state=!dstnat \
connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="defconf: masquerade"
out-interface=\
ether1
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-
address=\
192.168.89.0/24
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ppp secret
add name=vpn
/system clock
set time-zone-name=Asia/Jakarta
/system identity
set name=Router
/system leds
set 0 leds=led1,user-led
set 2 disabled=yes
set 3 disabled=yes
set 4 disabled=yes
add interface=wlan1 leds=led4 type=wireless-status
add interface=wlan2 leds=led5 type=wireless-status
add leds=led3 type=on
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
/tool mac-server
/tool mac-server mac-winbox
Is there something incomplete configuration ?
Please help me, thanks very much
