und3ath
6.22 routeros wireless high cpu usage
Thu Nov 20, 2014 4:58 pm
I have upgraded many routers (911G, 433AH, 912UAG, 435G) to ROS 6.22 and I see constantly high cpu usage cca 20-30% even when very small traffic flows(cca 1Mbps). The wireless package makes this high cpu usage.
Also when making bandwidth test directly from these routers, throughput jumps from 5Mb to 70Mb(before the upgrade it went constantly 100+ Mb).
Has anyone else noticed this behaviour?
honzam
Re: 6.22 routeros wireless high cpu usage
Thu Nov 20, 2014 5:16 pm
And have you wireless or wireless-fp or wireless-cm2 package instaled ?
I dont see this problem on 6.22 with wireless package
und3ath
Thu Nov 20, 2014 5:19 pm
wireless-fp. And there is also cca 10% usage from unclassified.
honzam
Thu Nov 20, 2014 11:35 pm
This is question for support Mikrotik
sonny
Sat Nov 22, 2014 6:00 pm
From which version ROS? you have upgraded to 6.22?
n21roadie
Sun Nov 23, 2014 8:48 pm
................or wireless-cm2 package instaled ?
Wireless-cm2 package ?
Lakis
Forum Veteran
Forum Veteran
Sun Nov 23, 2014 10:49 pm
High CPU usage by "no" reason cased by wireless package
This is OmniTik cpu graph
this is happening from time to time I dont know whats triggering hight cpu usage
have the same problem on 3 OmniTiks U-5HnD
jarda
Mon Nov 24, 2014 8:54 am
Had the same problems. Downgrade to 6.18 with wireless-fp helped to me on omnitiks.
Lakis
Forum Veteran
Forum Veteran
Mon Feb 09, 2015 8:41 pm
In Interface Queue set wireless Queue type=wireless default if this option is already set, also set ether devices queue type=ethernet-default, that solve my high cpu problem.
deanMKD1
Fri Feb 13, 2015 2:10 pm
Please downgrade to ROS 6.20. It works stable for me several months.. :)
Users browsing this forum: dervomsee and 33 guests
