zong
limit bw for download
Tue Jun 27, 2006 12:14 pm
Dear All,
If I have bw 64 kbps and then the speed for download is 64/8 = 8 KBps
is it possible to limit downlod speed became 4 KBps and for browsing stil 64 kbps??
Need your kindly assist...
thx & Regards,
zong
Biggs
Tue Jun 27, 2006 3:55 pm
I'm using the burst function for that kind of stuff.
http://www.mikrotik.com/docs/ros/2.9/root/queue
dritoni
try this
Tue Jun 27, 2006 4:56 pm
Web browsers open the 'save as'(download) dialog box when they can`t open something in the browser. MIME type of a binary file (mos of the download is like this) is application/octet-stream so all you have to do is mark these packets and limit.
add chain=forward in-interface=INTERNET content=application/octet-stream action=mark-connection new-connection-mark=down-2 passthrough=yes \
comment="" disabled=no
add chain=forward in-interface=INTERNET connection-mark=down-2 action=mark-packet new-packet-mark=down-3 passthrough=yes comment="" \
disabled=no
add name="download" dst-address=0.0.0.0/0 interface=all parent=none packet-marks=down-3 priority=8 queue=default/default limit-at=8000/8000 \
max-limit=8000/8000 total-queue=default disabled=yes
zong
Thu Jun 29, 2006 11:48 am
Dear All.... thx for all your reply..
where do I put the command ?
is it under Ip firewall rule forward ???
thx
Zong
sergejs
Thu Jun 29, 2006 11:54 am
Two rules in mangle, 'ip firewall mangle' for 2.9 (dritoni provided with 2.9 syntax).
Third rule 'queue simple'.
sergejs
Two rules in mangle, 'ip firewall mangle' for 2.9 version's (dritoni provided with 2.9 syntax).
zong
Wed Jul 05, 2006 6:51 am
i am using MT 2.7x
can i use it ??
I have tried using ip firewal > add chain=forward
ERROR : No such argument (chain)
sergejs
Wed Jul 05, 2006 7:36 am
zong,
2.7 version is too old, I don't even know correct syntax for it.
2.9 version is much better. :wink:
Users browsing this forum: No registered users and 80 guests
