jormerod
PPPoe fast download, slow upload
Mon Feb 23, 2015 6:11 pm
I have a strange problem which I need some help or guidance.
If I connect a user via PPPoE and run a speedtest, we get 50Mbps download and 9Mbps upload.
If I connect the user directly to the mikrotik without PPPoe (i.e. assign the IP direct), I get a 50Mbps download & 50Mbps upload.
What would cause this issue with PPPoE?
Any help would be appreciated.
James
sergejs
Re: PPPoe fast download, slow upload
Thu Feb 26, 2015 2:16 pm
Make sure queues are not configured on your router, that limits traffic of PPPoE client. Login to your router and check queues configuration.
kujo
Sat Jun 18, 2016 11:24 am
Some problem with CCR1009, slow upload speed.
how you resolv this trabl?
kujo
Sun Jun 19, 2016 2:52 pm
Have a progress, put gigabit interface(wan1 through optic converter) in 100MB/full mode, and upload speed up to near 87Mb/s. I'am connect to router through second wan, and after pppoe client start connect, ccr-1009 slow down all connection on wan2 ? Like a packets lost occur, whiteout high cpu load or any errors on interface. When stop brakes/lost on router we see normal upload!! Problem with pppoe client? Ppp Chiper?
Have a good day!
locodog
Mon Jul 11, 2016 11:08 am
In PPPoE connection on client MT disable MRRU. I've had the same problem and this resolved it.
amt
Long time Member
Long time Member
Mon Jul 11, 2016 1:27 pm
Same Problem at me also.. and same solution.
kujo
Mon Sep 05, 2016 11:15 pm
Hi! Try set interface queue to multiqueue on CCR device.
Have a good day!
kujo
Tue Dec 20, 2016 12:42 pm
Pppoe Provider switch-100mb/s<-->cooper<-->converter-1gb/s<-->fiber<-->converter-1gb/s<-->cooper<-->ccr1009-1gb/s. When provider reconnect my to 1gb/s port on his switch, then full bandwidth on channel appears!!!
Sent from my iPhone using Tapatalk
gabrielcsk
Wed Nov 22, 2017 11:36 pm
This solved my issue in 11/22/2017..
Thanks !!
ChanukaD
Tue Aug 03, 2021 1:29 pm
Hi All,
Is there any update for this issue ? its been 6 years and still this issue exists.
bhartendulal
Mon Feb 19, 2024 7:29 pm
Hi
I am also facing same issue, Download is fine but upload is not going up to mark on pppoe user
From where need to disable MRRU, Can anybody help?
CHUPAPEE
Sun Mar 17, 2024 10:41 am
I can't find the mru and how to disable please help me
CHUPAPEE
Thu Mar 21, 2024 1:33 pm
Helow my friend do you fix your problem do you find your solution to disable the MRU
CHUPAPEE
Thu Mar 21, 2024 1:34 pm
Thanks !!
MY FRIEND please help me
Users browsing this forum: Alakel, Bing [Bot] and 34 guests
