So yea, I accidently disabled Ether 1, and can no longer connect to it. The last thing I did was switch it from station to AP Bridge mode. However, I left the Freq to " Auto "
I have another SXT that I scan and find this other one, I know the SSID and security keys, and try to connect to it, but does not connect.
The problem is, that the SXT with the disabled Ether 1 port is on a tower.
What I cant figure out why it will not connect. When I put my second SXT is AP Bridge mode, I have one of the clients that connected to the tower SXT connect to the one I am testing the connection with. So I know the keys are right etc, otherwise this one client would not connect. It is within close range to my test SXT. I figured I would just connect to it wirelessly and enable Ether 1 again, slap myself, and never do it again.
Any other ideas how to get access to the device to enable ether 1?
p.s. I have tried with no security keys as well, thought that maybe I changed that bu accident too. But it does show up with a " APRB " when scanning with the test SXT. so there is keys used, and the only one that I had configured in there are known.
