favincen
[Solved] Use of externally defined global variables inside import scripts,
Fri Aug 28, 2015 4:38 pm
Hi all,
When I import a rsc file, the code executed can't access global variables defined in the rOS main /env .
And the script can neither access variables defined in a subscript (loaded by a /import within the import script).
Here's my test code:
[admin@MikroTik] > /file print detail where name~"test"
 0 name="test.rsc" type="script" size=504 creation-time=jan/03/2002 00:12:20
   contents=
     #Cmd to run before importing this rsc file: :global GlobalVar "VALUE_of_GlobalVar"
     :put "GlobalVar value is: $GlobalVar"
     :put "Importing test-inc.rsc..."
     /import test-inc.rsc\t
     :put "SubScriptGlobalVar value is: $SubScriptGlobalVar"
     :global ImportedScriptGlobalVar "VALUE_of_ImportedScriptGlobalVar"
     :put "Just defined var ImportedScriptGlobalVar with value: $ImportedScriptGlobalVar"
     #Cmd to run after importing this rsc file: :put "ImportedScriptGlobalVar value is: $ImportedScriptGlobalVar"
 1 name="test-inc.rsc" type="script" size=135 creation-time=jan/03/2002 00:12:20
   contents=
     :global SubScriptGlobalVar "VALUE_of_SubScriptGlobalVar"
     :put "Just defined var SubScriptGlobalVar with value: $SubScriptGlobalVar"
Running the test gives:
[admin@MikroTik] > /import test.rsc
GlobalVar value is:
Just defined var SubScriptGlobalVar with value: VALUE_of_SubScriptGlobalVar
Script file loaded and executed successfully
Just defined var ImportedScriptGlobalVar with value: VALUE_of_ImportedScriptGlobalVar
See that test.rsc can't get the value of $GlobalVar (which is defined global at a upper level) nor the one of $SubScriptGlobalVar (which is defined global at a lower level).
Test done on rOS 6.29 and 6.30.4, on a RB951G-2HnD.
BTW, as shown below, it appears that $SubScriptGlobalVar, which is defined in the subscript test-inc.rsc and not readable within test.rsc, is well propagated to the upper level at the prompt.
[admin@MikroTik] > :put "ImportedScriptGlobalVar value is: $ImportedScriptGlobalVar"
ImportedScriptGlobalVar value is: VALUE_of_ImportedScriptGlobalVar
[admin@MikroTik] > :put "SubScriptGlobalVar value is: $SubScriptGlobalVar"
SubScriptGlobalVar value is: VALUE_of_SubScriptGlobalVar
So, $SubScriptGlobalVar, defined global in test-inc.rsc, imported from test.rsc, imported from CLI, is readable from test-inc.rsc and from the CLI, but not by script that propagated from one to the other !
What a strange behavior !!! :oops:
Is this a bug, a known (undocumented ?) limitation, or am I missing something :roll: ???
In http://wiki.mikrotik.com/wiki/Manual:Sc ... #Variables , I read: "global - accessible from all scripts created by current user, defined by global keyword"
Thanks for your attention and feedbacks.
Fabrice
favincen
Re: Use of externally defined global variables inside import scripts,
Mon Aug 31, 2015 2:29 pm
Hi again,
I encountered a similar issue when using a function within a import script !
Here's a test code:
:global myFunc do={:put "INSIDE a function, GlobalVar value is: $GlobalVar"}
$myFunc
:set GlobalVar "NEW_VALUE_of_GlobalVar"
:put "NEW GlobalVar value is: $GlobalVar"
$myFunc
Running it directly on the CLI, it works as expected:
[admin@MikroTik] > :global GlobalVar "VALUE_of_GlobalVar"
[admin@MikroTik] > :put "GlobalVar value is: $GlobalVar"
GlobalVar value is: VALUE_of_GlobalVar
[admin@MikroTik] > :global myFunc do={:put "INSIDE a function, GlobalVar value is: $GlobalVar"}
[admin@MikroTik] > $myFunc
INSIDE a function, GlobalVar value is: VALUE_of_GlobalVar
[admin@MikroTik] > :set GlobalVar "NEW_VALUE_of_GlobalVar"
[admin@MikroTik] > :put "NEW GlobalVar value is: $GlobalVar"
NEW GlobalVar value is: NEW_VALUE_of_GlobalVar
INSIDE a function, GlobalVar value is: NEW_VALUE_of_GlobalVar
But putting the very same code in an import script, and running it, I get:
[admin@MikroTik] > /import test-env_in_func.rsc
I'm puzzled to observe that myFunc is not able to get the variable value anymore ! :(
I'd love to hear I do something wrong, with explanation on how to do it right...
My context: I'm currently writing a script to initialize rOS boxes the way I need, and these strange behaviors get in the way !
I need to rewrite my script to have everything in one file (while I was planning to split config and code in separate files) and cannot use functions to make an easily readable and refactored code... :cry:
favincen
Mon Aug 31, 2015 4:55 pm
I answer to myself with a workaround: I need to pass variables as arguments of my functions. Not that handy, but it works.
Still, why is it working as expected (or as I would expect) when ran from the CLI and not when the same code is executed from a .rsc script ???
favincen
Wed Sep 02, 2015 1:22 pm
Anybody to confirm they get the same behavior (or not) ?
Anybody to explain if I'm doing something wrong, or another way to do it that works ?
favincen
Fri Sep 04, 2015 4:22 pm
Hi all (despite I feel quite alone on this topic... :-o )
I found the good answer to my issue ! :mrgreen: :lol:
To make it short: to read the value of a global variable from within a .rsc script or a function, just declare it again in that local context, using ":global MyExistingGlobalVariable".
I discovered that in the manual, looking at the Nested function example.
wcsnet
Re: [Solved] Use of externally defined global variables inside import scripts,
Wed Mar 02, 2016 10:17 am
Had just about the same issue, i have global variable for thing used across a number of scripts, for example email addresses .
So i have a file "post configuration load.rsc" to basically send just a email but this did not work
with a exec "post configuration load.rsc" or import "post configuration load.rsc"
This works
:do {[:global emailnotificationsto;:global emailnotificationscc;/tool e-mail send to=$emailnotificationsto cc=$emailnotificationscc subject="$[/system identity get name] loaded configeration" body=""]} on-error={}
This doesn't
:do {[/tool e-mail send to=$emailnotificationsto cc=$emailnotificationscc subject="$[/system identity get name] loaded configeration" body=""]} on-error={}
So seems like global vars has to be declared similar to scripts that uses global vars :-)
Users browsing this forum: No registered users and 32 guests
