Good day…
I would like to know..
let say, i have 1 dual vertical antenna and it connect to 2 Radio (1 as active 1 as back-up).
it’s there any refer to say that, if the Radio1 cannot ping to the gateway, then it will auto disable the wireless card.
Then, When the Radio 2 can ping to the Gateway but cannot ping to the Radio 1, it will turn on the wireless card (same setting with Radio1) to take care the client whoever pointing to this sector and become 1 + 1 hot standby.
thanks.
ang.
