We are looking at a requirement where we can only fit a single 802.11 card and RB493AH into the mix. The design looks like it requires shooting between two wireless links that are located exactly opposite of each other at 180 degrees apart. The distance is enough that an Omni may be problematic. My questions is whether or not this is a configuration that would be successful. Essentially it would be:
Remote AP 1 ===>WiFi Link<====(antenna1) (1)R52Hn&RB493AH (antenna2)===>WiFi Link<====Remote AP2
I look forward to any info you share, ask questions as needed.
Thanks!
candersonmailbox
