hi to all gurus
it is possible in 1 ether port let say 4 hotspot setup?
thanks
hi to all gurus
thanks
Yes if you use VLANs. No if you don’t.
thanks fewi for response can you give me a basic example this setup.. my current hotspot is working fine im planning to add another subnet for hotspot in same ether port.
thanks a lot
Can you describe in more detail why you are trying to achieve? Why do you want to add more Hotspots?
Do you know what VLANs are?
You can add second subnet as /ip address to the local interface.
If HotSpot universal client/DHCP/etc. are used, correct used-pool and add new subnet to it.
arrrgg fewi sorry for my previous post i did a wrong explanation ^^ this is what i mean sergejs reply adding another subnet in the same ether.
salamat = thanks
