I have 4 smaller sites, which have some local systems that need layer 2 connectivity to a main site. Therefore I need routerboards which can handle 1 Gbit/s of EoIP traffic (without any IPSec). Which hardware do you recommend for
Re: 1 Gbit/s of EoIP
I don’t think you are going to find any Mikrotik hardware/motherboard that can handle that kind of a CPU load.
I can’t even get 300 meg EoIP on any Mikrotik products and I have tried many times.
I would guess/try an Intel 3 GHz or faster Xeon based motherboard with lots of CPU cache running ROS x86. You will need one on both sides of the EoIP tunnel.
