This command run on terminal, but I cannot make it to work in “/system script” as a script
:log error [/ip firewall filter get 0 action]
How to convert this command to a script in “/system script”?
Please help
Please help
You cant use ‘get’ in a script very easily. You should use ‘find’ with ‘get’.
:log error [/ip firewall filter get [/ip firewall filter find comment=“rule1”] action]
Getting closer to the answer anyway
With this command, I can make it work in a script in “/system script”
:log error [/ip firewall filter get *8 action]
the *8 is the ID I want to grab, where on terminal *8 is 0
Is there an easy way to know the ID for a particular entry in a script?
I don’t want to do looping using :foreach, waste CPU too much
Hello changeip,
Thanks so much for the response. Now I know how the ‘get’ and ‘find’ works together ![]()
The whole script i am creating now, is about to run every 5 seconds. I don’t want to waste looping while I already know the position of the rule/entry.
Does this "/ip firewall filter find comment=“rule1” do looping?
So the idea of what i need is to avoid looping.
