I’d greatly appreciate all the help about my problem to setup network in a net café.
I have a Mikrotik routerboard RB850Gx2, with the following setup :
Eth01 : WAN
Eth02 : switch (S) 24 ports for LAN network of my pc
I have created 3 ip addresses,
Eth02 : 192.168.0.5/24 for pc in room A, with DHCP
Eth02 : 192.168.10.1/24 for pc in room B, statics ips at the moment
My questions :
- can i have 2 dhcp server link to 1 interface Eth02?
- i have a network printer with static ip : 192.168.0.100, how do I allow all pc in room B, with ips 192.168.10.x access the printer?
Recently I’ve added 1 wireless router TP-LINK, connected to the switch (S), to allow clients accessing wifi. It has a static IP 192.168.0.150. Any wifi successful connections have Ip addresses 192.168.0.x But I don’t want them to be in the same network as the pc. Thus, in Mikrotik I’ve created another IP address 192.168.20.1/24 and the dhcp server. But when I tried changing the ip of the router from 192.168.0.150 to 192.168.20.150, no device can connect to the wifi.
What should I do? I’ve setup the wireless router manually on the router device, is it possible to have it connected and manageable by my mikrotik routerboard also?
Many many many thanks in advance for all your help and support!
Regards,
