Hey everybody,
i’ve a problem. How can i reach the server at the same time via dsl line 1 and dsl line 2? This is the export of my firewall:
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=\
5s tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=spi comment="Bereits vorhandene Verbindungen akzeptieren" connection-state=established disabled=no
add action=accept chain=spi comment="Related Verbindugen akzeptieren (z.B. ICMP-Meldungen)" connection-state=related disabled=no
add action=drop chain=spi comment="Mikrotik Empfehlung: Pakete mit Invalid-Mark gleich loswerden" connection-state=invalid disabled=no
add action=return chain=spi comment="Zurueck, die restlichen Regeln sind Chain-spezifisch" disabled=no
add action=jump chain=forward disabled=no jump-target=spi
add action=accept chain=forward comment="PPTP-Negotiation erlauben" disabled=no dst-address=192.168.1.2 dst-port=1723 protocol=tcp
add action=accept chain=forward comment="GRE erlauben" disabled=no dst-address=192.168.1.2 protocol=gre
add action=accept chain=forward comment=Website disabled=no dst-address=192.168.1.2 dst-port=80 protocol=tcp
add action=accept chain=forward comment="Alles ueberall hin vom LAN erlauben" disabled=no in-interface=ether3
add action=drop chain=forward comment="Alles andere verwerfen" disabled=no
add action=jump chain=input disabled=no jump-target=spi
add action=accept chain=input comment="Ping immer annehmen" disabled=no icmp-options=8:0 protocol=icmp
add action=accept chain=input comment="Alles aus dem LAN annehmen" disabled=no in-interface=ether3
add action=drop chain=input comment="Alles andere verwerfen" disabled=no
/ip firewall mangle
add action=mark-routing chain=prerouting comment="Client 1 ueber DSL B" disabled=no new-routing-mark=dslB passthrough=yes src-address=192.168.1.4-192.168.1.99
add action=masquerade chain=srcnat comment="NAT fuer DSL1" disabled=no out-interface=pppoe1
add action=masquerade chain=srcnat comment="NAT fuer DSL2" disabled=no out-interface=pppoe2
add action=masquerade chain=srcnat comment="-> Server NAT" disabled=no dst-address=192.168.1.0/24
add action=dst-nat chain=dstnat disabled=no dst-address=!192.168.1.3 dst-address-type=local dst-port=80 protocol=tcp to-addresses=192.168.1.2
add action=dst-nat chain=dstnat comment="PPTP Negotiation -> Server" disabled=no dst-address=!192.168.1.3 dst-address-type=local dst-port=1723 protocol=tcp to-addresses=192.168.1.2
add action=dst-nat chain=dstnat comment="GRE -> Server" disabled=no dst-address=!192.168.1.3 dst-address-type=local protocol=gre to-addresses=192.168.1.2
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
The server has the ip-adress 192.168.1.2 → He goes via DSL1 (DSL A) in the internet. The server is reachable via the WAN-adress of DSL1, but not via WAN-adress of DSL2. But what’s my mistake? Can someone help?
