I have 2 private networks that I need to keep separate 10.67.64.0/20 and 10.13.0.0/24 all addresses are static
I need to create/assign multiple ip addresses from 10.67.64.0/20 network and map to a specific ip on the 10.13.0.0/24 network
10.67.70.1 = 10.13.0.10
10.67.70.7 = 10.13.0.35
etc…
Ether1 ip is 10.13.0.30
Ether5 ip is 10.67.65.33
If i have a pc on 10.67.64.3 that I need to connect to 10.13.0.10:8500, I want to use 10.67.70.1:8500 to connect
only devices on 10.67.64/20 network will request connections to 10.13.0.0/24 no requests will come from 10.13.0.0/24
RB750Gr3 6.47.2
I want connections from Network 1 to the servers in Network 2 to appear to be part of Network 1 to the laptops.
I do not want any connections from Network 2 to Network 1.
