I have this use case where I need something I dont know MT can do.
Three locations, one master with a NOC software and two sites with servers.
Each location has a public IP but all internal servers use src-NAT to access the Internet.
I have to set a VPN between the NOC and each of the two sites so the NOC monitors the servers behind.
The two sites have the same private IP segments and the NOC software does not support overlapping IPs.
Talked to the NOC software people and they advised me to implement NAT at each of the two client sites so that the NOC software sees two different private networks without having to change anything on the servers.
The only requirement they have is that the NAT table is permanent at the sites, meaning that the translated IP should be always the same.
To illustrate, the IPs are like this:
NOC Public IP: 1.1.1.1
NOC Private Subnet: 192.168.100.0/24
Site 1 Public IP: 2.2.2.2
Site 1 Private Subnet: 10.0.0.1/24
Site 2 Public IP: 3.3.3.3
Site 2 Private Subnet: 10.0.0.1/24
I would need a translation like this:
Site 1 NAT Pool for VPN with NOC: 192.168.200.0/24
(Server 1 with IP 10.0.0.10 should always be translated to 192.168.200.10)
(Server 2 with IP 10.0.0.11 should always be translated to 192.168.200.11)
etc
etc
Site 2 NAT Pool for VPN with NOC: 192.168.300.0/24
(Server 8 with IP 10.0.0.10 should always be translated to 192.168.300.10)
(Server 9 with IP 10.0.0.11 should always be translated to 192.168.300.11)
etc
etc
Im somewhat familiar with simplistic NAT and PAT on Mikrotik, but not sure on this one.
Thanks a lot for the help.
