Hello ,
i need to run 10.000 clients with best hardware to run iso and buy license on it and use it because i have like bunch of CCR1036 and CCR1072 but i want one PPPOE server to run them all with my all other config’s
Regards .
Ten clients should not require multiple routers/switches.
10k PPPoE on one machine? Is there any particular reason for not splitting the load? With this amount, you must have automated provisioning anyway (don’t tell me you configure those 10k entries manually) so it won’t make much difference if the automated provisioning runs on one machine or multiple machines.
You dont want one hardware failure taking out so many clients, given how cheap Mikrotik hardware is compared to other big platforms, I’d go with up to 5x 36cores with the intent of 2k per router, that way if one fails each router can just go up to 2.5k and handle the load easily.
i meant 10K clients
i just wanted a way or a device that can handle 10k clients , BTW i have SAS RADIUS ti manage my users i does not configure them manually , the reason i wanted one server to unify my network and try like a new method
i understand you and i am working as the same as you said ,but in my case the CCR1036 can up to 600 user and i have alot of servers and i just asking if there is anew platform or router i can use with a high quality
we are using 1036 with 1k user and there is no problem.
