10 hosts with the same IP
Help me solve the following problem please?
10 hosts with the same IP must communicate with a server
we have RB960PGS and a SW CRS326-24G
14 VLANs with NAT?
They are 14 old CNC lathes without a license to change the IP.
MECANIZADO.pdf (238 KB)
At first glance, it seems to me that the simplest thing is to add one cheap “hAP mini” to each CNC device, and set up NAT. That way, everyone of them can keep the same address without disturbing each other…
You can find some ideas here:
http://forum.mikrotik.com/t/port-to-interfacing/97096/1
http://forum.mikrotik.com/t/how-to-allow-two-devices-with-same-ip-access-internet/115990/1
There it was mainly to establish connections to same-ip devices. If you’d need connection only from them, it could be simpler.
