Hello, yestreday we received a DDoS attack that caused a 100% CPU usage (it’s a CCR 1072)
and our system was unable to do a blackhole because the router was inaccesible also via API.
We have the IP connection tracking disabled on the firewall.
There is some extra option that we can do to prevent a full CPU usage?
Not too much Mbps nor PPS, just a lot of TCP flows.
TCP flows: 93291
2018-08-06 21:06:39.000000 119.175.73.105:33808 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 90.156.90.38:34098 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 82.154.217.103:37968 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 215.209.28.140:36687 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 30.127.18.65:35167 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 153.68.162.252:36447 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 28.197.181.242:35470 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.167.200.198:36821 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 208.41.216.250:33192 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 14.254.243.53:37078 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.166.51.247:33923 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 210.128.204.140:36005 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 53.175.15.143:34193 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 128.205.59.126:34596 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 53.63.60.162:36465 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 37.189.167.218:33381 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 160.242.67.56:36361 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 60.189.140.41:22165 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 27.54.210.5:34692 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 15.75.54.29:36368 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 197.116.243.121:38286 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 142.234.57.173:36764 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 121.212.131.65:33814 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 143.54.250.132:34935 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 168.159.242.14:38862 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 131.162.209.129:35054 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 216.199.127.216:34424 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 128.81.156.69:36446 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 187.189.217.111:35815 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 210.11.215.144:34700 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 160.29.253.73:33759 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 140.107.25.67:33508 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 121.173.156.55:38493 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 41.210.250.37:38793 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 187.162.226.159:36059 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 54.60.217.170:36211 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 25.205.192.186:37438 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 100.173.181.53:37754 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 105.25.187.66:35034 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 39.57.175.67:37163 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 42.7.99.41:34044 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 199.243.250.210:35724 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 81.165.127.175:37599 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 158.140.197.219:24245 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 15.107.158.25:35769 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 208.63.122.186:36229 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 223.200.41.27:38831 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 128.227.63.37:35403 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 210.102.11.165:37026 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 54.46.106.140:36928 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 5.187.56.244:37424 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 46.131.90.200:33461 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 216.210.66.85:34041 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 128.121.86.166:35599 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 11.187.90.103:37555 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 192.217.65.67:35255 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 117.14.122.11:38391 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 37.96.131.251:34259 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 204.250.212.111:37816 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 90.57.254.145:36682 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 126.126.53.141:34184 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 132.134.217.15:36507 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 128.41.14.227:34861 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 30.140.160.50:33436 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 150.203.53.33:33712 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 33.122.210.253:33810 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 54.125.131.70:36125 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 199.225.7.64:37252 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 150.30.174.108:34102 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 132.192.60.134:37969 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 166.53.54.145:36691 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 47.197.243.75:35169 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 53.26.140.162:36449 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 140.3.54.152:36825 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 64.235.242.243:35471 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 170.105.162.173:39079 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 200.27.9.56:36015 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 70.205.132.156:33930 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 139.111.203.11:34199 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 212.125.162.212:34600 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 111.41.125.170:33382 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 73.168.51.33:36366 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 158.57.223.63:36481 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 200.200.11.18:22167 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 60.173.253.37:34694 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 179.93.216.167:38288 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 182.127.216.143:36773 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 65.181.108.121:39010 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 55.57.70.134:33815 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 105.119.191.51:36378 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 70.66.210.47:34937 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 113.47.198.14:35056 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 77.236.16.167:34425 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 47.41.216.182:36452 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 171.150.28.64:34702 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 145.72.63.5:38494 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 89.242.205.41:35818 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 68.215.171.244:33762 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 122.106.126.145:33512 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 102.150.143.173:38794 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 38.210.200.157:36234 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 53.108.9.152:37439 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 122.234.250.90:36063 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 73.75.16.80:35036 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 132.65.66.47:37755 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 210.205.121.57:35916 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 116.150.162.200:37165 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 197.227.140.86:34050 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 200.86.30.140:37600 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 90.117.86.170:35728 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 156.252.162.82:36531 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 23.93.57.160:35770 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 56.215.173.86:36232 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 141.195.127.35:24254 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 170.47.57.223:38834 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 219.41.191.212:35404 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 67.131.5.25:37028 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 132.144.159.223:37427 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 143.78.249.208:33466 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 102.253.57.216:35608 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 64.42.53.53:34042 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 47.205.85.192:37556 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 64.191.145.60:38390 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 191.90.159.226:35259 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.159.239.41:34261 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 174.54.25.25:37817 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.66.234.122:36693 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 150.136.162.27:34863 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 205.108.28.243:34187 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 89.225.145.128:39128 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 176.125.208.143:36532 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 55.210.112.90:33715 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 187.203.97.23:37255 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 171.108.90.136:36130 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 205.71.121.53:33811 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 41.225.159.69:37080 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 182.197.62.9:34101 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 35.244.6.219:36707 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 105.227.99.160:35168 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 165.217.9.62:37971 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 122.46.15.18:36450 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 81.215.140.152:35472 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 41.139.106.13:36837 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 105.69.111.29:39084 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 121.66.140.153:36036 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 51.200.68.173:33938 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 59.132.157.186:34207 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 97.29.182.42:34602 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 111.171.89.30:36380 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 106.57.204.90:39292 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 80.15.132.107:36501 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 54.217.103.41:22168 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 132.157.208.210:38289 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 200.105.252.145:34697 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 122.68.114.215:39011 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 14.62.97.46:36774 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 197.30.96.150:36451 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 182.200.111.90:33819 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 64.52.105.253:36379 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 157.103.126.69:35058 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 47.37.195.41:34939 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 168.140.175.200:34706 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 132.199.145.53:38496 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 66.66.114.23:35836 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.191.227.171:33767 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 51.210.96.18:33521 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 140.254.132.153:34428 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 66.131.47.245:37441 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 99.139.6.159:36236 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 82.167.57.77:35039 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 141.11.23.252:36075 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 26.70.182.16:35927 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 57.99.26.200:37756 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 197.166.132.126:37164 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 42.150.173.125:38867 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 122.37.11.42:34051 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 81.170.65.78:37603 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 42.28.236.23:36534 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 107.242.221.187:35788 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 81.126.56.216:36250 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 132.131.216.150:24273 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 86.166.217.114:35405 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 37.53.106.111:38837 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 171.236.53.243:36931 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 66.143.187.203:37031 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 26.253.48.69:37430 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 3.13.122.139:33468 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 54.57.126.243:35616 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 113.65.50.134:37557 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 69.51.73.5:34046 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 9.57.82.198:34262 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 150.63.15.74:37818 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 119.37.176.47:38394 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 216.187.243.74:35260 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 15.221.200.28:34865 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.127.28.125:36711 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 187.197.59.23:39135 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 116.70.175.33:34190 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 94.26.23.173:39015 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 132.210.90.205:36533 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 205.200.173.227:37254 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 7.192.236.13:34106 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 42.7.205.60:36710 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 116.93.216.15:37082 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 210.227.84.253:36460 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 191.70.16.157:35170 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 106.114.187.209:35473 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 18.122.158.81:36844 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 171.57.27.73:37973 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 105.81.99.84:34606 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 15.90.176.152:34210 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 152.187.9.188:33934 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 70.182.159.96:36051 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 166.195.182.14:39311 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 57.127.97.253:36518 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 55.112.70.53:38290 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 165.191.70.96:22169 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.62.199.100:34699 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 140.15.54.111:39012 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 38.173.96.42:39091 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 210.108.75.176:33825 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 132.234.188.94:36404 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 205.35.53.89:35057 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 126.141.26.150:34943 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 132.28.192.173:34708 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 166.97.51.217:35841 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 62.121.159.15:38495 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 187.197.113.108:39361 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 188.62.42.67:33531 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 25.143.173.100:36238 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 70.66.131.117:34427 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 106.90.105.253:37442 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 70.41.5.243:35930 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 28.102.102.66:36083 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 9.200.82.81:37757 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 160.7.187.54:37166 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 41.159.68.97:35042 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 37.105.174.157:34057 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 159.90.125.72:38870 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 157.121.252.57:35740 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 15.191.63.47:36569 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 99.136.152.251:36259 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 125.57.250.153:37607 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 131.108.132.217:24297 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 134.134.3.252:35407 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 46.122.112.65:35789 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 78.116.136.217:38840 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 68.197.53.132:37432 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 106.252.64.156:33469 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 72.242.106.66:36932 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 134.108.121.39:37559 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 154.126.215.14:34049 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 106.243.97.129:35631 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 65.126.174.171:39328 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 159.245.5.90:34263 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 82.28.215.160:38797 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 165.132.215.221:38392 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 191.249.106.41:37819 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 102.173.199.140:35261 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 176.245.27.66:34864 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 26.154.9.210:34195 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 126.234.208.152:36720 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 171.81.131.86:36156 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 102.100.50.131:39019 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 216.11.127.209:36550 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 50.145.122.63:37257 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 121.103.216.204:33823 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 210.223.153.90:34105 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 223.210.235.216:36712 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 53.25.244.39:35171 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 57.176.66.157:35474 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 121.252.42.210:37085 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 97.121.39.242:36463 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 112.57.167.140:36848 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 65.57.5.153:37974 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 54.69.132.250:34605 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 186.30.116.215:34214 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 134.28.167.51:36407 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 126.244.191.62:33939 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 39.125.37.67:38291 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 187.18.132.37:36056 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 84.217.113.140:36522 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 30.6.157.154:39013 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 9.226.234.53:39095 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.209.84.99:22170 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 37.28.106.25:34701 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 108.11.121.174:33828 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 90.128.132.5:36411 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 145.235.102.181:36474 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 71.131.78.105:36789 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 131.127.156.188:34945 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 25.89.5.103:35851 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 166.53.243.77:35062 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 11.5.73.252:39376 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 189.105.217.173:38497 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 6.14.218.3:35937 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 41.252.170.59:33539 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 90.170.82.208:36085 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 200.142.89.200:37444 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 159.212.122.54:34061 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 162.47.249.16:37758 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 73.253.105.99:35757 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 121.197.59.127:38874 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 67.57.26.217:36598 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 209.134.74.216:36293 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 60.11.37.122:35044 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 215.33.13.60:37605 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 84.131.121.118:37035 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 51.140.152.152:24298 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 167.244.152.168:35406 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 150.156.225.57:35802 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 14.112.132.15:38842 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 27.150.66.173:37434 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 197.57.70.121:39255 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 200.186.35.134:36934 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 128.9.102.37:35641 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 200.70.215.28:37561 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 69.205.41.52:34060 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 41.3.208.81:39332 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 166.54.144.69:34264 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 7.140.41.18:38393 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 51.198.70.236:38796 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 53.253.106.11:37820 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 132.167.122.77:35262 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 80.81.158.81:34196 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 171.173.90.6:34866 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 114.253.189.173:36157 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 50.72.52.173:36734 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 126.200.150.9:36571 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 48.93.78.166:33826 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 188.165.227.249:37256 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 140.251.125.69:36730 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 53.253.41.173:35477 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.217.126.90:39647 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 128.136.85.253:35172 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 153.187.152.106:36467 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 128.205.48.111:37976 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 85.126.200.96:37089 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.48.74.154:36850 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 200.189.152.145:36421 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 221.67.128.78:34212 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 216.54.42.9:34608 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 108.216.215.129:33946 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.145.25.129:38292 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 105.99.127.160:36081 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.70.50.121:39014 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 143.162.96.234:36528 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 78.198.97.57:39100 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 41.140.69.186:22172 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 86.47.162.122:34705 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 37.77.200.96:34710 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 97.81.38.111:36413 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 70.179.173.46:33829 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 125.174.168.65:36794 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 97.236.200.198:36478 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 102.181.199.41:35857 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 205.150.37.27:34947 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 157.54.16.96:34430 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 26.85.53.131:38499 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 208.63.55.42:35946 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 74.13.152.150:33550 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 71.53.142.209:37167 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 179.47.77.253:35065 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 69.118.139.170:36093 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 125.70.14.144:37447 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 215.173.52.26:36265 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 84.162.111.103:34063 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 97.82.80.27:37760 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 70.77.28.157:35772 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 51.223.127.143:38876 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 200.208.112.105:35047 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 39.67.132.62:36301 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 150.125.41.102:36631 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 216.75.166.225:37033 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 154.90.216.131:24301 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 53.51.57.96:37608 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 128.152.66.106:35408 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 181.27.96.53:35822 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 7.74.99.48:39262 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 26.247.250.15:36936 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 143.173.68.86:38845 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 94.46.126.35:37437 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 210.173.167.100:35650 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 65.72.187.111:37562 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 89.14.179.66:34062 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 122.216.54.16:39334 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 9.54.234.189:38395 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 176.62.14.108:38798 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 46.143.216.252:34266 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 39.188.14.176:37821 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 154.39.253.127:35263 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 42.74.210.162:34197 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 65.181.162.157:34868 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 78.107.97.200:36172 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 221.243.118.102:36737 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 216.74.170.35:36594 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 150.57.243.85:35479 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 105.221.210.97:37258 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 210.54.191.56:39409 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 131.140.244.216:39658 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 103.111.179.247:36743 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 218.118.249.173:39047 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 128.67.39.239:36473 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 73.200.140.131:37092 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 11.56.33.134:39020 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 51.122.9.51:36430 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 116.42.253.26:37977 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 96.242.74.5:36856 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 121.247.14.219:34216 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 203.150.57.162:34612 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 74.90.239.47:38293 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 82.35.225.106:36080 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 119.30.69.105:33954 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.226.55.55:39016 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 108.63.171.143:39105 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 212.210.59.23:36549 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 189.94.223.253:34713 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 187.94.216.28:34704 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 165.107.57.97:36435 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 111.67.6.200:39562 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 63.253.242.86:36796 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.243.105.152:36494 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 29.39.219.250:35859 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 144.132.97.86:34429 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 54.140.159.105:34950 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 52.249.239.171:38500 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 121.54.30.171:35067 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 153.102.54.41:35963 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 86.41.66.171:37168 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 37.113.227.208:39349 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 160.253.173.188:37448 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 132.176.55.41:36102 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 205.111.195.15:36264 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 122.6.150.140:34069 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 144.173.41.41:37761 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 200.227.77.131:38882 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 67.41.171.191:35776 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 145.112.167.100:35048 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 28.66.144.209:36306 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 145.188.11.73:36638 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 93.205.225.181:37042 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 122.41.94.143:24318 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 210.26.134.57:37610 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 126.42.221.252:35829 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 191.111.93.227:35409 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 65.50.26.173:36941 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 175.41.236.119:38847 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 68.235.250.216:37440 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 141.5.69.181:35652 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 80.157.141.103:37567 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 125.69.208.139:34075 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 174.162.182.140:39392 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 131.57.199.128:39341 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 41.171.216.100:39144 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 78.118.47.244:38396 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 51.143.81.212:38799 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 80.208.216.62:37822 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 192.78.57.68:34267 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 121.157.77.103:34201 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 129.216.221.253:34869 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 89.67.205.189:36745 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 62.173.197.162:36599 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 16.25.59.208:37261 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 174.158.65.154:35174 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 63.78.54.90:35481 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 176.205.250.189:36186 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 37.234.119.50:36475 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 131.189.121.251:39052 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 117.225.216.80:39420 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 82.132.118.162:39320 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 57.90.54.53:37091 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 197.81.108.216:36436 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 73.142.41.200:39023 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 90.126.165.243:37978 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 200.106.5.162:34218 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 77.105.216.216:34615 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 200.121.73.28:36862 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 62.235.188.236:35267 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 221.244.174.56:38294 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 175.62.136.14:36748 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 197.247.187.62:36088 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 6.210.142.139:33953 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 96.253.86.236:39018 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 103.111.221.253:36558 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 47.35.132.126:22171 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 122.80.93.25:34707 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 41.251.225.96:36471 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 66.30.126.35:39576 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 159.113.253.171:36806 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 57.253.249.216:36500 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 90.106.53.162:38501 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 96.227.28.218:34431 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 143.200.122.236:35860 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 3.75.210.112:35970 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 41.121.53.121:34951 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 204.62.244.46:35069 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 41.15.227.62:39366 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 70.11.77.93:37170 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 41.126.53.217:37451 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
2018-08-06 21:06:39.000000 173.54.111.97:36116 > x.x.x.x:80 protocol: tcp flags: syn frag: 0 packets: 1 size: 40 bytes ttl: 0 sample ratio: 1
Flows have cropped due to very long list.
