I am facing this problem since yesterday
Please help me as soon as possible
No L7 rules
Ppp client’s over 400
Bandwidth throughput 500 mbps approx
Sent from my Redmi Note 6 Pro using Tapatalk
No L7 rules
Please do reply as soon as possible and the solution urgently please
Please check Tools>Profile and then click on the Start button.
It will show which process is causing high cpu usage.
Then you can check what is going on with that specific process.
Regards,
M.
^^^This
Yes
console is taking over 60 to 80%
Yes sir here it’s snapshot please check out
Create supout.rif and send to support@mikrotik.com. It’s the one and only way to get (quick) support for your specific situation.
Done
But need a solution urgently
There are related topics on the issue:
http://forum.mikrotik.com/t/process-console-maxing-cpu-usage/104027/1 (no solution)
http://forum.mikrotik.com/t/console-hang-with-90-cpu-on-console-process/57594/1 (no solution)
Have you tried rebooting the device? Are there active tasks under System > Scripts > Jobs?
Yes sir i read this one but not solve
In my CCR no script is running
No L7 rules
You need to sort it on (descending) usage, not on name.
I didn’t get you sir what are you saying (sorry but my English is poor)
I assume you have rebooted it??
Yes Sir
The screenshot you posted with the profile running was sorted by NAME, please post one sorted by CPU use ?
Pleas post your config ( /export hide-sensitive ).
(never saw this behavior on my 1009 … )
Pleas post your config ( /export hide-sensitive ).(never saw this behavior on my 1009 … )
Here it is your snapshot it is sold by CPU usage
Sir I can’t send you the configuration because of security reasons but I can tell you we have over 400 PPP uses and aur band with is more than 500 mbps and we have radius server also cloud radius. And v provide our customers services like painting Google YouTube play store bye pcq service in queues.
There are some videos on common mistakes made when configuring PPPoE concentrators on MikroTik.
But I think it must be something else in your case, “console” is not supposed to use much CPU if any.
No idea what it is even doing. Do you have any logging configuration that outputs a lot of info into the log all the time?
Couldn’t this be a compromised device, and the (jobs? scripts?) running on numerous consoles are eating up all the CPUs?
I have no idea what a “console” task even is on RouterOS… I am guessing it may be related to sending output to the serial port which may be logged events.
Those should also appear in the log window. Maybe he has enabled some debug level logging and forgotten to turn it off.
Dear Sir,
There is no output device and debug level logging configured and there is no script also.
I have already send this think to Support last 2 days but no reply from there. What to do Sir.
