Hi All,
Just an FYI here (and I have sent supout to support@mikrotik).
EDIT to Comply with reporting bugs rules:
- Previous verison: 6.47.1
- How to reproduce: Click tools profile, select all and then press start.
- Reproducibility: Always
- Extra info: /export and screenshots below.
This is a hEX with defconf removed and only a DHCP client running:
[admin@MikroTik] > /export
# aug/11/2020 17:30:31 by RouterOS 7.1beta1
# software id = 9TIA-AJFX
# model = RouterBOARD 750G r3
# serial number = 8AFF08414D3C
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
/interface lte apn
set [ find default=yes ] ip-type=ipv4
/ip hotspot profile
/ip vrf
add list=all name=main
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
set enabled=no
/ipv6 settings
set disable-ipv6=yes
/ip dhcp-client
add disabled=no interface=ether1
/ip dns static
add address=192.168.88.1 name=router.lan type=A
/system clock
set time-zone-name=Africa/Nairobi
/system ntp client
set enabled=yes
/system package update
set channel=development
/system resource irq rps
set ether1 disabled=no
set ether2 disabled=no
set ether3 disabled=no
set ether4 disabled=no
set ether5 disabled=no
[admin@MikroTik] >
