100% CPU Usage on RB 111/112
Is this bug confirmed by MT yet? Every single RB 112 I have tested the beta on has exhibited this same problem, everything is fine for a short while then the CPU hits 100% and stays there for extremely long time, sometimes causing watchdog to reboot the system. The high CPU continues even after a reboot, the two beeps after startup even seem affected as it continues for several additional beeps.
I have some clients that require public IPs and without wanting to use PPPoE, I really could use the station-pseudobridge mode, however the 100% CPU usage issue just causes the beta to be completely unusable on routerboard hardware. Yes, I know the beta shouldn’t be in production use, but I really don’t want to take a gamble and buy a bridge from another vendor as Ive had great results otherwise with routerOS and routerboard. Is this going to be fixed any time soon, as it has been around for several betas.
never seen this problem. check your traffic with torch, disable interfaces etc. see : http://wiki.mikrotik.com/wiki/CPU_Usage
i have tested ALL beta versions on RB112 and seen this problem and solved it by removing disabling packages i do not intend to use (almost everything)
please go and read links provided by normis - they do solve the problem
It’s almost impossible to use the device once the CPU problem starts, it takes many minutes to even login with telnet and trying to use Winbox is impossible. I’ve disabled the wireless interface and had only my PC directly connected to Ethernet and still has the CPU usage problem, so it’s definitely not traffic related. I don’t think I tried disabling packages, maybe I’ll go through one by one and see if I can figure out which one is misbehaving when I have enough patience to try it :slight_smile:.
uninstalling them is better - if you don’t use it, you don’t need it.
I just did a netinstall of b6, removed old settings. I installed dhcp, ntp, advanced tools, routerboard, system and wireless. No CPU problem on first login. Enabled DHCP client on wireless. Opened wireless, scanned for AP, hit connect. Set mode to station-pseudobrige. Moments later, constant 100% CPU usage.
I disabled dhcp and ntp, rebooted again to 100% CPU. I noticed in the files window, autosupout was constantly changing time, I guess something caused an automatic supout generation and this is where the CPU time was going. I disabled watchdog, after 4-5 minutes the autosupout apparently finished and the CPU load was normal again. I noticed I also had an autosupout.old, so perhaps the whole CPU usage problem is something causing supout generation to happen constantly.
I’m going to reenable DHCP and NTP and see if that has any affect, maybe the watchdog timer is going crazy.
EDIT: DHCP worked fine (didn’t try NTP yet), I re-enabled watchdog and at the 5 minute uptime mark, autosupout creation started even though the “Watch address” was disabled. Autosupout creation took 5mins 5 secs at 100% CPU. I can’t say for sure if this was the problem until I try again with the other boards I have here, but it certainly looks like this may be either the problem or a significant contributor to the problem.
could you check ram usage? maybe 5 minutes is the time in which ram gets filled up and then kernel just kills something.
actually there is a problem with the current beta, you should wait for the next release, or use 2.9.41
What is the scope of the problem you mentioned? I’ve had the system I setup last night connected to my LAN router since then and not a single problem (so far…). Would beta5 be any more stable than beta6?
if you open interface menu, it tries to get some information but can’t, so CPU usage climbs
Doesn’t seem I could reproduce that on my beta6 setup (which is still going strong - ~10mbps @ 70% CPU in bridging mode). The only time the CPU hits 100% is immediately after logging in on winbox, it settles down after 10-15 seconds back to a normal value.
I just got a bunch of RB133s in today, I’ll perhaps play around with beta6 on one of those too and see if the CPU / supout / watchdog bug happens on them or not.
I repeated the setup on an RB133c board, immediately disabled the watchdog and no CPU problems. This time I was adventurous and enabled NTP, CPU hit 100% constantly, no supout generation was occurring. Problem disappeared after I disabled NTP package. Seems like there are definitely a few more bugs to work out in there somewhere.
I’m having the same problem with 112 board running 2.9.41 and I can’t stay logged into the router very long. I’ve disabled all packages that are not needed but CPU still hovers at 100%. Router needs reboot about 4 times a day now just to keep it working. I can’t even winbox into it now, it’s in a fairly remote area that’s not easily accessible.
I couldn’t even get a complete supout file to send to support. It seems to work a little better with the wireless interface turned off (of course I can’t use it like that since it’s a hotspot)
re-read this topic please. it’s not the same problem as you use 2.9 and the situation changes with a disabled interface. see the wiki link about CPU usage.
The RB133 has begun exhibiting 100% CPU now, despite no configuration changes. All that has happened since setting up is a bunch of DHCP renewals and standard traffic. The only packages enabled are adv-tools, dhcp, routerboard, security, system and wireless. Is there no way to see what components are using CPU time, ala top or ps in Linux?
It is poitively a problem with the NTP package. Which is sad becasue it is so critical. But I have notcied this exact same problem now from 2.9.39-2.9.41 I thought it was some hotspot code that I was trying out on my home MTunit for testng purposes and then I started to notice this exact same problems at other locations. I think it may be in conjunction with hotspot or the DHCP package.
It would always take a reboot to get me out of this stuck 100% CPU stage but now I have disabled my NTP and eveything is flowing. I am going to try a local NTP server and see if that resolves the problem.
I am pretty sure that NTP in 2.9.39 or so has problem.
I really wish there was a way to do an CPU process check to confirm this but oh well. The MT guys do so much already.. Any ways great product !
I hope this find is some what correct and ueful to everyone else.
cheers!
DesertAdmin
everyone who is seeing the NTP package problem, please make a supout.rif file while the package is enabled and CPU usage rises. Send the file to support
Here is a resource pr from ours with this problem, I am attempting to generate a supout; it took several minutes to get the resource pr out of it. Its been 3 or so minutes since I typed sup-output, and so far its only echoed back the s. (I’m ssh’ed in, winbox isn’t working at all with it at this point).
uptime: 3h37m
version: “2.9.41”
free-memory: 1828kB
total-memory: 14224kB
cpu: “MIPS 4Kc V0.11”
cpu-frequency: 175MHz
cpu-load: 100
free-hdd-space: 29920kB
total-hdd-space: 61440kB
write-sect-since-reboot: 457
write-sect-total: 155597
bad-blocks: 1
Normis, I have read that thread about the CPU already, believe me, if there’s something that we could do to drop CPU usage on the router, I’d do it. We’ve tried many things.
The reason for my post was to inform you that I see similar things happening on 2.9.41 as well as the beta. Just running hotspot and userman, no rules, queues, etc. I’ve looked at the traffic in torch and there’s nothing significant, only 2 wireless users assiciated at the time the CPU pegs 100%. One user has very low signal. He keeps getting disassociated due to weak signal. We’ve tried to limit anyone connecting below 5.5mbs but that hasn’t worked either. If we disable wlan the cpu usage does drop, but of course that doesn’t help us as it’s a hotspot. I can’t get a proper supout because the router is overloaded and either crashes or has to be rebooted. I’m trying again after removing ntp package, I couldn’t get a proper supout file, what I did get I sent already to support. I was starting to wonder if there was something wrong with the board, but if others are having the same problem ???
The board was installed around 4 months ago.
RB500 with hotspot i presume
