gajda
July 5, 2010, 1:15pm
1
I have x86 dualcore PC with ROS 4.10. It has one virtual machine (KVM) with another ROS 4.x. After upgrading to 5beta3 CPU is at 100% load. I disabled KVM package and rebooted. After that load was gone. I’ve got same issue with ROS 5b1.
Is this a known issue?
It would be great you can try 5.0beta4 version (which is the latest released beta version), then report about the problem status.
gajda
July 6, 2010, 7:42am
3
OK. I will do that tomorow and let you know.
Just had it happen this morning on 5.0b4 on my RB1000 after SSTP crashed and sent an autosupout.
gajda
July 29, 2010, 11:42am
5
I just upgraded to ROS5 beta 5 and it’s still same (100% CPU). I downgraded back to 4.11 and CPU is fine. I generated supout.rif, what should I do?
send it to support@mikrotik.com with short description
The same problem at 5.0beta6 too?
Ive had it happen at B6 and B7 on my RB1000. I sent a supout yesterday while it was at 100%
Nothing special. Memory leak still exists, to a greater extent than 5.0b5 and CPU usage still randomly spikes to 100%…
