100+ DHCP servers on a CCR1036-12G-4S possible?
I need to setup 100+ remote sites with DHCP servers configured whitin a Mikrotik, this box is also in charge of the whole routing for each of that remotes sites with very large access lists, the remote sites have a dhcp relay working.
The configuration will be:
Servers:
[admin@MikroTik] /ip dhcp-server> print
 #   NAME                                                           INTERFACE                                                         RELAY           ADDRESS-POOL                                                         LEASE-TIME ADD-ARP
 0   dhcp1                                                          ether5                                                            10.0.1.2        TRST_PILO                                                            10m
 1   dhcp2                                                          ether5                                                            10.0.2.2        FALA_PZVP                                                            10m
Pools:
[admin@MikroTik] /ip pool> print
 # NAME        RANGES
 0 TRST_PILO        192.168.200.10-192.168.200.250
 1 FALA_PZVP        192.168.200.10-192.168.200.250
 2 SODI_CERR        192.168.200.10-192.168.200.250
 3 TEST_TEST        192.168.1.10-192.168.1.250
So my questions are:
-Each server is a different process or is just a process that servers all the pools?
-How the process affinity works in this multicore box?
-Does anyone tested a similar configuration or at that scale including routing and big access lists?
-Any recommendation about?
i have 25 dhcp servers on a ccr1009
