100% load
hello,
i have a problem with RB2011UAS-2HND-In using ROS 5.22
router cpu load 100%
unclissified more then ~60 usage
management ~30% usage
allready sent rif’s files to support
tried to reboot router
tried to disable all firewall rules and add input/forward accept for/from all
tried to disable all interface’s except eth1-gateway
ticket number: Ticket#2013011566000681
here are screens:
I’m not sure what kind of answer you expect to get from the forum about unclassifed process.
However your ticket was replied,
Supout.rif files are not completely generated and there is missing configuration
export, but I assume you have enabled SNMP for monitoring. Is the Dude used for
monitoring this router?
snmp was not enabled. i replied to that email with new rif’s files and screen with snmp.
Sergej, i allready got answer from Janis B.
updated to new ros, now load is ~20%
thanks for the help.
Hi there,
I had the same problem today, same RB with same ROS.
I was unable to reboot it.
Regards,
Branko
