100 Mb Wireless Link
Hello Guys,
Is it possible to achieve 50-60Mb/s Full Duplex wireless link with RB433Ah and R52Hn over 15 Km Aerial distance? If anyone can share stats of his feild installation, and equipment details it will be very helpful. :slight_smile:
Thanks and Regards
12 km, I have 50/50 Mbps TCP with rb411AH, r52Hn and UBNT dish 60cm on 20 MHz channel.
if you only need 60mbit full duplex you should try using plain 5ghz turbo in a dual nstreme configuration.
can you please tell me the UBNT dish model ?
they have only one model…
30 dbi
https://www.xconcepts-me.com/product_details.asp?ProdId=286
34 dbi
https://www.xconcepts-me.com/product_details.asp?ProdId=408
Anybody used any of the above antennas with R52Hn with MIMO setup and two pigtails with the dish?
Sorry if I ask something very basic, I am not an expert in wireless :slight_smile: especially Mikrotik. So any help in this regard will be highly regarded.
I have managed to get a very stable link at 15km using RB411AH-RB52HN><RB52HN-RB600.
Both dishes are noname, dual-pol 30db 5Ghz, 80cm. Horizontal pol is perfect, but vertical is not well at all (fresnel, baby) it connects at 216/216mb HT and I get an average tcp>50-60mbit with ping fluctuating at aroud 10ms.
During havy raining… we can divide it all by half, but still workable.
I am more worried about my 2.4 setup, but I heard good news about integrated 5ghz N solution, so as soon as I get it, things will get to order.
