100% Usage after restore of settings -x86 - v3.22
Hallo,
I upgrade my x86 router from 3.13 to v.3.22 and it worked good. I had to change some settings but with these new settings I had problems so I had to restore the old settings.
After the restore of the old settings I have got 100% CPU-Usage all the time. Maybe I took settings which backup is from version 3.13. So I downgraded the router to 3.13 but still 100% CPU-Usage also when there is no traffic.
Is this a known problem? Is there something like a task manager to see which process causes the high cpu load?
Should I send Supout.rif to support? When yes, how to do this?
if you disconnect winbox and use ssh is it still 100%? try clearing the ‘load previous session’ checkbox on winbox loader before you connect.
Yes still 100%. All the time.
