1000mW mpci
http://xconcepts-me.com/downloads/66_pa_7.pdf
anyone used this in MT ?
Haven’t seen them. Not sure I’d be enthusiastic about a manufacturer that sticks a paper label on a heat-sink as a matter of course.
Hi all, I want to warn any one from the mini pci card, that card have an amazing power strength, but all of that only for short run, but in long run its power abssorbs very quickly, but if you want a card for long run without suck problem you should use XR2 600mw its power is good and more stable.
Note: that information is given to me by someone who is work from a master distributor for that product.
:open_mouth:
These cards are nowhere near their advertised power level. They work good, but are little more vulnerable to static than most. I had 2 of them go deaf in single storm, while some CM9’s and other generic Atheros cards on that same tower survived.
who can name a card that wouldnt burn after sometime ???
i worked with most of the brands , for different reasons they die easily ..
what about some cards which die after working with its properties in the winbox ? ( not TX power )
this card is working good for us for months …
