can anyone tell me what is the maximum CF card we can put in 1000U and if anyone had tried it with some particular make of CF card please share…
regards
Mankomal Singh
regards
Mankomal Singh
I used 8GB sandisk extreme II. I think 16 GB will be ok too.
I read from Normis that sandisk it’s fully compatible, kingston have some problems.
regards,
can we put 16gb X 2 cards
any suggestion on what card to use ?
anyone try this? http://www.sandisk.com/Products/Item(2678)-SDCFX4-016G-901-SanDisk_Extreme_IV_CompactFlash_16GB.aspx
normis,
there are many cards which are not even detected by RBs any specific reason ???
rgds/MS
I tried 8GB Sandisk and works fine. Sandisk is cheaper that Lexar.
In the wiki you have many working cards:
http://wiki.mikrotik.com/wiki/Supported_Hardware#Memory_cards
Regards,
We also found that A-data Speedy 16Gb works fine.
