100BaseBX SFP Support
Hi all
We are evaluating RouterBoards as FTTH customer CPE’s and have now a RB2011UAS-IN in our Lab.
We tested serveral 100BaseBX SFP’s but non of them seam to work. They see if the link is up or not, but no traffic is flowing.
Is there any solution to that ?
Regards
Matthias
I have the same problem…
Info from MT support:
RB2011 requires 1,25G connection to board, modules that provide only 100Mbps connection to the board aren’t supported.
If you can find module that have 1,25G connection to board and 100Mbps optical connection it should work.
