100G stopped working a while ago // CCR -> Arista
I have an CCR-2216 → Arista 100g link that was working. Noticed it stopped working, so we swapped out the QSFP28-SR4-100G modules and it still doesn’t work! Just ordered a new MPO cable, but the light levels look fine for all 4 lanes.
Messed with all the negotiation/FEC/speed settings I could, and it isn’t coming up. Even upgraded to 7.12.1 from 7.8. Can someone sanity check my settings?
set [ find default-name=qsfp28-1-1 ] auto-negotiation=no comment="why not working" fec-mode=fec91 l2mtu=9570 mtu=9000 name=\
    "qsfp28-1-1 - arista et54/1 - 100Gb" sfp-shutdown-temperature=70C speed=100G-baseSR4-LR4
set [ find default-name=qsfp28-1-2 ] auto-negotiation=no fec-mode=fec91 l2mtu=9570 mtu=9000 speed=100G-baseSR4-LR4
set [ find default-name=qsfp28-1-3 ] auto-negotiation=no fec-mode=fec91 l2mtu=9570 mtu=9000 speed=100G-baseSR4-LR4
set [ find default-name=qsfp28-1-4 ] auto-negotiation=no fec-mode=fec91 l2mtu=9570 mtu=9000 speed=100G-baseSR4-LR4
And on the Arista:
interface Ethernet54/1
   description Core: Hormiga qsf28-1-1 (CCR2216) [100Gb]
   load-interval 30
   mtu 9000
   speed forced 100gfull
   error-correction encoding reed-solomon
   no switchport
   ip address 10.1.128.145/30
#show interfaces ethernet 54/1,54/2,54/3,54/4 transceiver
If device is externally calibrated, only calibrated values are printed.
N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                               Bias      Optical   Optical
          Temp       Voltage   Current   Tx Power  Rx Power
Port      (Celsius)  (Volts)   (mA)      (dBm)     (dBm)     Last Update
Et54/1     33.45      3.30      6.99     0.29      -5.92     0:00:04 ago
Et54/2     33.45      3.30      7.01     -0.01     -0.05     0:00:04 ago
Et54/3     33.45      3.30      7.01     0.08      -3.45     0:00:04 ago
Et54/4     33.45      3.30      7.00     -0.08     0.07      0:00:04 ago
(I did mess with setting the ports to 4x 25G and some of the Lanes started flapping up/down, but it didn’t make sense.)
